Fully polished TuRD
Discussion in '1st Gen. Builds (1995-2004)' started by slander, Apr 12, 2014.
  1. Jul 23, 2023 at 1:04 PM
    #1581
    slander
    slander [OP] Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Well I was getting ready to start the parts gathering and planning to link this thing over the winter, but my wife quit her job (awesome for her!) So I can't go dropping money on coilovers and shit LOL!!! Gives me more time to piece meal buying brackets and stuff as they come on sale and learn the calculator. In the mean time, figuring out how to get the steering to run cooler..
  2. Jul 30, 2023 at 2:19 PM
    #1582
    slander
    Hickory, NC
    In with the new cooler:
  3. Aug 13, 2023 at 5:42 PM
    #1583
    slander
    Hickory, NC
    Went wheeling at good evening ranch in WV this weekend. The new steering cooler works way better than that heat sink style one. Great weekend of hard wheeling, the damage report is I ripped off one corner of the rear bumper, a rear axle hub seal started leaking on the drive down there, put a hole in a sidewall and an airbump finally died. The park is awesome and glad I was able to finally wheel a decent chunk of it!!
    Supposedly this guys leading the WE rock series. Fun watching a west coast comp guy getting denied on east coast sloppy muddy rocks!! Badass 4steer buggy on spidertrax axles.
    unstpible, -Rorschach-, jubei and 4 others like this.
  4. Aug 13, 2023 at 5:43 PM
    #1584
    slander
    Hickory, NC
    unstpible, sparkystaco and Justinogo like this.
  5. Aug 14, 2023 at 7:10 AM
    #1585
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Looks awesome, bet the drive up there is gorgeous too
  6. Aug 14, 2023 at 7:10 AM
    #1586
    slander
    Hickory, NC
    Yea it is!!!
  7. Aug 14, 2023 at 7:38 AM
    #1587
    cynicalrider
    cynicalrider #NFG
    Jersey
    Learning that east coast slippy sloppy is key.
    slander[OP] likes this.
  8. Aug 14, 2023 at 11:06 AM
    #1588
    slander
    Hickory, NC
    That and having a rig setup for it as well. A quad steering, super low slung, low geared buggy on sticky treps with a small V6 isn't really the right rig for hardcore east coast obstacles. Worked awesome on the dry rocks and for cone dodging!
    sparkystaco likes this.
  9. Aug 20, 2023 at 3:23 PM
    #1589
    slander
    Hickory, NC
    Well the new front shaft didn't last long, I knew I should have just built a square one.
    Justinogo, sparkystaco and allenfab like this.
  10. Aug 21, 2023 at 9:18 AM
    #1590
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    How thick is the tube?
  11. Aug 21, 2023 at 7:12 PM
    #1591
    slander
    Hickory, NC
    .095 I think.
    I should have shipped these off to hi angle driveline, he doesn't seem scared to make thick tubed Toyota shafts. I used a local "go to" offroad driveshaft shop.
  12. Aug 21, 2023 at 8:29 PM
    #1592
    betterbuckleup
    Ian
    Concord, CA
    I think that's what mine might be as well. haven't messed it up yet, but then again I haven't sat on it on a an obstacle.
    Gonna go .120 now? Dunno how that would do on the street
  13. Aug 21, 2023 at 8:32 PM
    #1593
    slander
    Hickory, NC
    It's a front shaft and realistically this truck will never be in 4wd on the street again. I'll probably just build a square shaft for it at this point.
  14. Aug 21, 2023 at 8:34 PM
    #1594
    betterbuckleup
    Ian
    Concord, CA
    Oh well nevermind then. Easy
  15. Aug 24, 2023 at 10:03 AM
    #1595
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Do you put around 5.5 qts in it during an oil change? I couldn't find a clear recommendation due to all the forums on the HiAce being in Japanese haha.
  16. Aug 24, 2023 at 11:26 AM
    #1596
    slander
    Hickory, NC
    I had to trim mine down a lot due in the front to some mistakes I made when I did my SAS, I put 5.5qts in it and run the larger filter on it. I imagine it holds the 6qts a 3.4 takes though.
  17. Aug 24, 2023 at 2:29 PM
    #1597
    ForestRunnerFrank99
    Josh
    Woah how did I end up on your thread! Well thanks for the info, that's kind of what I figured it'd take.
    slander[QUOTED][OP] likes this.
  18. Sep 2, 2023 at 4:21 PM
    #1598
    slander
    Hickory, NC
    Built a new.bumper:
    Finally decided to fix my most hated mod, this is what I get for listening to TTORA back in the mid 2010s on how you can't fit 12s without hacking up the bed.
    Fired up the tig welder to stack some dimes.....
    Which is exactly what I didn't do, hit up my local truck stop for a patch panels:
    A few self tappers later and holes fixed
    Words cannot express how happy I am not to have straps hanging down or worrying about shit falling out of those holes!!! I should have done this a long time ago!!
    Currently the truck is on jackstands awaiting parts to repair my leaking hub and a tap for bigger rear hub bolts.
    sparkystaco, jubei, Justinogo and 2 others like this.
  19. Oct 6, 2023 at 10:53 PM
    #1599
    slander
    Hickory, NC
    So the truck has been down for a month. My rear hub was puking gear lube all over, so I had to replace the outer axle seal and I figured while I was in there I would upgrade the hub studs to 7/16 12pt ARPs. Well that project took forever, wrong taps, parts delays, wrong size bolts etc.... I also decided to fix my driver side spring and shackle mounts that were 1.75" further forward than the pax side. Also got my rear air bump cans finally mounted up and made some landing pads. Truck should be out of the garage this weekend FINALLY. Onto the pics:
    Tiny Asian stud, big black American bolt
    Bump cans:
    Driver's side landing pad
    Pax side:
    All I left after that before an end of the month wheeling trip is to build a square front drive shaft, but I have all the parts for that and it should go quick.
    Dave41079, jubei, ToyRyd04 and 3 others like this.
  20. Nov 2, 2023 at 5:55 AM
    #1600
    slander
    Hickory, NC
    Went wheeling at hawk pride in Alabama last weekend. Truck worked great, no complaints. I really need to push this front axle forward to get some more up travel so it rides better. As usual I drove 75mph there, wheeled hard for 3days and drove it home.
    compressed_1698676110101.jpg compressed_1698676152221.jpg IMG_20231028_134102943_HDR.jpg IMG_20231031_095934_606.jpg IMG_20231029_152245766_HDR.jpg
