Fully polished TuRD
Discussion in '1st Gen. Builds (1995-2004)' started by slander, Apr 12, 2014.
  1. Mar 6, 2016 at 6:01 PM
    #161
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    These are the only pics I have. I just slid it into the stock rail a little bit and welded the top and outside of the 2x3 to the stock frame, then just cut pieces to fit and make the "transition" from the stock frame to the new 2x3.
    unstpible and COMAtized99 like this.
  2. Mar 6, 2016 at 6:53 PM
    #162
    slander
    slander [OP] Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Cool thanks, make sense! Those pics help.a ton, thanks!
  3. Mar 11, 2016 at 3:33 PM
    #163
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Any updates on this thing?
  4. Mar 18, 2016 at 8:23 AM
    #164
    slander
    Hickory, NC
    No, i was playing around with the welder I borrowed on Friday of last week, and then it was house mods all last weekend. I just got back into town last night after a week long work trip and hope to do some work to it this weekend once i wrap up the house project. My 5.29s did come in, and I'm waiting on back ordered knuckle gussets from marlin. I hope to get the frame rails on either this weekend or next week and get the gears setup. Not looking forward to pulling out the rear third with the position the trucks parked in the garage.
    A lot of time was sucked up stripping parts off the truck after the frame was cutoff and removing the usable IFS parts from the old frame, that was like an evening each working solo
  5. Mar 18, 2016 at 10:14 AM
    #165
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Just a heads up bit I've heard the fitment on the marlin gussets is terrible. A buddy threw them away and ordered TG.
  6. Mar 18, 2016 at 10:56 AM
    #166
    slander
    Hickory, NC
    good times, my toyota geek friends told me to get those. Worst comes to worst ill cut some up with a plasma cutter, or ideally my buddy will have his plasma table up and running to make me some.
  7. Mar 18, 2016 at 12:44 PM
    #167
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Heard that. Yeah their design is Awesome, just heard they don't fit well. Hopefully you get lucky!
  8. Mar 18, 2016 at 1:39 PM
    #168
    slander
    Hickory, NC
    I expect to have to modify them no matter what due to the kunckle balls coming off and getting reattached.
    Gear Head likes this.
  9. Mar 18, 2016 at 2:28 PM
    #169
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    You've got a point there lol
  10. Mar 18, 2016 at 3:36 PM
    #170
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Marlin backordered on something....no way ;)
    I'll be in the hood in the next weekend or two of you need a hand
  11. Mar 18, 2016 at 8:00 PM
    #171
    slander
    Hickory, NC
    They showed up, except low range doubled my order.... the gussets look nice!
    Conner give me a call when you are in the hood, i plan to be working on this pos!
  12. Mar 19, 2016 at 6:01 AM
    #172
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    FROR has them too. Give Brian a call.
  13. Mar 22, 2016 at 7:48 PM
    #173
    slander
    Hickory, NC
    Finally had some time to work on this thing. It was a day of setbacks, i dragged the 60 rear into the garage to remove the diff cover to use that for the front. After wrestling with that pos for an includeing an exxon vadez style oil spill, the diff cover wont work. I also stripped that heavy bastard down and yanked the 3rd. Next i figured i would work on something easy and swap the steering studs on the knuckle... well after another 1hr of welding on nuts, applying heat, and impacting them off i got ths studs off, but managed to booger up a hole on each side. Orderd a tap and packed it in for the evening. I did measure for plates for welding on the frame rails. Ill have to order those and get them deleverd tomorrow. I plan on building the frame rails this weekend.
    And i refilled the oil before i forgot, unmodded dipstick in the stock spot read dead nuts on. I wish i knew what truck model the oil pa came off of, its some forgein model, not a t100..
  14. Mar 27, 2016 at 5:48 PM
    #174
    slander
    Hickory, NC
    Fixed the knuckle stud holes today and installed the new studs. I also did some frame mockups trying to decide if i should inboard the front frame rails a bit (.75" or so), if i inboard them he steering box may hit the alternator. I also pulled the rear 3rd out, i cant say enough how much i love full float rear axles, i didnt even have to jack it up!
  15. Apr 4, 2016 at 7:10 AM
    #175
    slander
    Hickory, NC
    I actually started putting stuff back together this weekend (well yesterday). Frame rails and front crossmember are built and heavy tacked into place, and the diff cover is now on my front axle. The frame is a bit narrow, high and tight! This week im going to take my time and mock up and build the reinforcement plates and finish weld the front frame and motor mounts. More tech and pictures coming tonight. Welding 3/16s to the factory tin foil frame SUCKS BTW. The drivers side tacked in fine, on the pax side i kept blowing through the factory frame, while barely burning into the 3/16s, GRRRR....
  16. Apr 4, 2016 at 7:16 AM
    #176
    Ritchie
    Coming along... good news.
    Yeah... the frames are thin for sure. I recommend you add another cross member?
    I have another just in front of the oil pan. It does not go straight across, say parallel to the bumper... it sits at a slight angle. It took away the small amount of flex I had which happened while turning the wheels while parked.
    If you need a pic, I'll snap one later today.
  17. Apr 4, 2016 at 7:25 AM
    #177
    slander
    Hickory, NC
    I was thinking about adding one right under the core support, at the very least to help support my winch. A pic would be cool, i dont know where another crossmemeber would go? All the real estate from the grill back will be occupied by radiator, steering and the oil pan.
  18. Apr 4, 2016 at 3:20 PM
    #178
    slander
    Hickory, NC
    Welded on the diff cover. This is a diff cover off a rear fj 60 that i had, the rears have a removable cover. I could not make this one removable. The stock cover that i cut off this axle had too many gaps to fill with weld. I'm going to clean the cover up and add some plating to it.
    Frame rail tacked on side shot. The rails are 42" long 2x3 3/16 and they go 2" into the factory frame rail.
    The front sticks 8" out from the core support. Thats enough to hold my m8000 with a few inches to work with.
    Front shot. The frame rails are up against the core support on the body and butted up against the radiator mount. I wanted to get them squeezed in and as high as possible.
    Flux core tacked awesomeness, added the angles to get some more surface area on the weld.
    unstpible, esxcli and allenfab like this.
  19. Apr 4, 2016 at 4:26 PM
    #179
    Ritchie
    Nice stuff there...
    Here are 2 pics of my cross member from beneath:
    I still need to paint it and many other areas. If you need measurements, let me know.
    unstpible likes this.
  20. Apr 4, 2016 at 4:32 PM
    #180
    slander
    Hickory, NC
    Was it flexing from the steering box? It looks like how the jeepers would reinforce the frames to prevent the boxes from tearing off.
