Fumoto drain valve need one
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LEEP, Jan 30, 2009.
  1. Jan 30, 2009 at 3:30 AM
    LEEP
    LEEP [OP] Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    Where is the best place 2 order one from
  2. Jan 30, 2009 at 3:43 AM
    Joe B
    Joe B Well-Known Member
  3. Jan 30, 2009 at 6:42 AM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
    I think he wants you to order it for him too . . .
    :D
  4. Jan 30, 2009 at 6:44 AM
    LEEP
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    Can order it myselfe
  5. Jan 30, 2009 at 7:53 AM
    Joe B
    All I need is his credit card numbers...:p :D
  6. Jan 30, 2009 at 9:29 AM
    LEEP
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    Call 404-505-0163 they are $19.25 each plus shipping for 08 taco p/n is f 103 just ordered mine
  7. Aug 4, 2013 at 5:38 PM
    StanBo
    StanBo Well-Known Member
    Stan
    Central NJ
    10 DCLB - 98 XJ 93 RX7
    They have gone up in price but the promo code still works.
  8. Aug 4, 2013 at 7:16 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    pretty cool. never heard of this stuff before.
  9. Aug 4, 2013 at 7:19 PM
    skygear
    skygear                    
    I got mine off Amazon and installed it today. Get the F-103N the 'N' is for nipple. it allows you to add a hose on the valve for easier draining.
  10. Aug 4, 2013 at 7:51 PM
    StanBo
    Stan
    Central NJ
    I was going to get them off of Amazon as well. Oildrainvalve.com had the springs and little rubber covers for damn cheap. Plus the price is the same with the discount.
  11. Aug 4, 2013 at 7:54 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I've been using them for years.
    I got the F-103. No need for the nipple since I don't have a skid plate, and it provides a little more clearance.
    I had one on my Duramax and Suburban, but the wife's Rav-4 got a Fram Sure-Drain, which is much lower profile (her pan is literally 6" off the ground).
    The drain is on the bottom of the Tacoma pan, but it's tucked up behind the front crossmember so there is no risk of the valve getting hit.
    They do drain a little slow, but it's not a big deal. Just slide a pan under and open the valve, then go around and check your inflation, fluids, air filter, clean up the engine compartment, etc....
  12. Aug 4, 2013 at 8:14 PM
    skygear
    skygear                    
    nice. I take it you ordered already?
  13. Aug 4, 2013 at 8:20 PM
    skygear
    skygear                    
    Those clips are only $1 but shipping is ~$4! ludacris...
  14. Aug 5, 2013 at 7:45 PM
    StanBo
    Stan
    Central NJ
    I ordered two valves, 5 clips, and 10 caps. The shipping was free but I couldn't use the code. So I upgraded the shipping and was able to use the code which made the shipping free again and took some additional cash off of the top of the order.
    I would run the valve on my 240sx but it is going to be pretty low to the ground and I don't want to take the chance.
  15. Aug 5, 2013 at 8:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Fram Sure-Drain will handle that.
    It's only a little taller than the stock bolt.
    Drawback is it's a two-piece item... you unscrew the dust cap/seal, and screw in a fitting that has a "V" wire on it, which opens the valve.
    Haven't seen them in stores for a while, but they are still available online.
