funny noises??
Discussion in '1st Gen. Tacomas (1995-2004)' started by cole47, Aug 2, 2009.
  1. Aug 2, 2009 at 8:06 PM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    Ive been hearing two unusual noises from my truck...the first coming from the front right suspension area, it sounds like a clicking...like metal on metal. its not rele loud. it only happens at higher speeds (45+)....the second is coming from the rear, its a loud clunking sound it only happens when i hit a speed bump...at any speed its like a loud clunk. at first i thought it was my bedliner but i replaiced it with line-x so thats not it.
  2. Aug 2, 2009 at 8:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Rear clunk could be worn shocks....Front could be CV's
  3. Aug 2, 2009 at 8:14 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    im no expert but i was kind of thinking the shocks its like when i come down off of something its like its bottoming out....but not "bottoming" i got 5100s in the rear??? they are new
  4. Aug 2, 2009 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If the shocks are new, check them to make sure no mounting bolts came out.
  5. Aug 2, 2009 at 8:20 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    ok will do tomaro and i guess ill run it by a shop to see if the cvs are bad unless you know a way to tell....i had a local shop install the lift so if a bolt is loose in the rear ill have them look at it.
  6. Aug 3, 2009 at 1:03 PM
    HARDSHELLTACO
    HARDSHELLTACO HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    When i installed my lift i didn't get one of the sway bar links tight enough and it made a clicking noise in the front. However it was only heard at low speeds and when droping off a curb or something. Something you could check anyway!
  7. Nov 29, 2009 at 9:45 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I had just installed used Donahoe's on my front and have the same clunking noise, originally thought the coilovers need recharging. Took them out and replaced them with with my original stock setup and the clunking is still there.
    Now, I am led to believe that when I tried unsuccessfully to remove the lower end of the sway bar drop link I loosened it and could not get it back tight?
    Do you actually need to put a allen wrench in there to tighten it up??
    Any suggestions?
  8. Nov 29, 2009 at 9:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    See if a 5mm allen wrench goes into the threaded part to hold it still. Then tighten with the correct size open wrench (17mm IIRC)
  9. Nov 29, 2009 at 10:05 AM
    RacerP
    Chicago
    2003 4x4
    Chris,
    I started with that, but was worried about stripping the crap out of the set screw. These Chicago winters and road salt are tough on the fasteners on any vehicle.
    The nut does spin freely, so I am guessing I do need to find a way to tighten it. Might have to soak it a few days with PB and have another go at it.
    Now if only I can figure out a way to remove the locking screw on the collar of my Donahoe coilovers. Same problem, wouldn't budge and stripped the hell out of it. Even drilled it out and used a bolt extractor with no success.
    I have read here that the plating that Donahoe used causes some of these and the collars to seize in place. Would like to try my best to figure it out myself before investing the money in shipping and rebuild from ICON.
  10. Nov 29, 2009 at 10:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you strip it, you might have to grip the threads with a vice grip. It will damage the threads, but thats the only other option I can think of right now. :eek:
  11. Dec 3, 2009 at 3:03 PM
    RacerP
    Chicago
    2003 4x4
    Well, I was able to soak it a few days with PB and got a 6mm allen socket on there and was able to tighten it up! That horrible clunking sound is now gone!
    Thanks for the help Chris
    Peter
