Fuse box, Relays, Switches... help a dummy out
Discussion in 'Lighting' started by SandyTaco04, Feb 10, 2020.
Beef or Fish Tacos
Poll closed Feb 25, 2020.
  1. Beef
    40.0%
  2. Fish
    20.0%
  3. You get none
    40.0%
  1. Feb 10, 2020 at 10:07 AM
    SandyTaco04
    SandyTaco04 [OP] New Member
    2018 Black Tacoma TRD OffRoad
    Hello, it's almost Taco Tuesday and I need some learnin before I can enjoy any tacos.
    Here is my question cause I have been looking for about 30 minutes and cant find a good thread...(NOTE: I am a complete electrical dummy. I can replace piston rings, but cant replace a light bulb)
    Anyways, I want to add a few lights to my 2018 Off-Road Tacoma(Ditch, rear facing environment, and light bar), and don't understand the process from going from loser to pro. The main question arises from understanding relays. I want to use this blue sea system (Link: https://overlandequipped.com/collec...for-3rd-generation-toyota-tacoma-2016-present ) that will be wired into some cali raised buttons on their three switch mounting bracket where the coin cubby is currently.
    I know you go from battery to breaker to fuse box, but from there I am lost. What is the relay doing if I have switches inside my cab? Can someone please explain to a dummy how I go from fuse box to lights using in cab switches? Do I need relays for Baja Design/Rigid lights? Do I need to go back to school? Do I even deserve Tacos????
    Monster0Frankenstein likes this.
  2. Feb 10, 2020 at 10:18 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The purpose of a relay is to keep the higher amp/current from flowing through the switches in the cab. Generally the switches in the cab are designed for low(er) current. The relay is a high(er) current switch. If you put high current through a device designed with a low current rating, chances are it will burn out. So you turn the high current switch (the relay) on/off with the low current switch in the cab.
  3. Feb 10, 2020 at 10:27 AM
    SandyTaco04
    So if I have this blue sea fuse box, and I want to go from that to a relay to my switch, to all of these lights... do I need a relay for every light? Seems like a lot of extra wiring, and random relays I now have no idea where to put.
  4. Feb 10, 2020 at 10:27 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
  5. Feb 10, 2020 at 10:35 AM
    SandyTaco04
  6. Feb 10, 2020 at 10:44 AM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Mine sit beside the fuse box;
    CaliRaised makes a holder;
    https://caliraisedled.com/products/2005-2020-toyota-tacoma-4runner-bolt-on-relay-holder
    You want a relay for each use; ditch lights have a relay, driving lights have a relay. If they were all on the same you wouldn't be able to use them independently.
  7. Feb 10, 2020 at 10:44 AM
    rnish
    Tacoma 2nd gen
    You can combine devices/lights in logical combinations upto the rating of the relay. e.g., light1 is 5 amps, light2 is 3 amps. Together 7 amps. As long as the relay is rated at greater than 7 amps you can control both lights through one relay. Note: I would add some head room to the hypothetical relay rating.
  8. Feb 10, 2020 at 11:03 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  9. Feb 10, 2020 at 11:25 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    SandyTaco04[OP] likes this.
  10. Feb 11, 2020 at 10:58 AM
    TacoInTacoma
    TacoInTacoma Well-Known Member
    Tyler
    Tacoma, WA
    2019 Tacoma Off-Road/Super White
    SR-71A likes this.
  11. Feb 11, 2020 at 11:06 AM
    jay993
    jay993 Well-Known Member
    Jay
    09 TRD Sport V6 AC
    bone stock
    leave it to the aftermarket installs to screw it all up
  12. Feb 14, 2020 at 9:18 AM
    Pj40
    Pj40 Well-Known Member
    Washington
    I know it's all probabaly super confusing but once you learn the basics(relay pin out/function, basic fuse layout, grounding) it's all super simple after that. I personally didnt like anything aftermarket, if something failed it wasnt changeable or fixable you had to buy a whole new unit. So I built my own power distribution/fuse box. They're currently arent any fuses in this box because I have to measure the output of my accessories but you get the idea hopefully.
