Fuse for left tail lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AFZ, Jun 20, 2012.
  1. Jun 20, 2012 at 1:54 PM
    AFZ
    AFZ [OP] Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    Well my left tail-light section is out. I checked the fuses, i checked the wire and I'm stumped. I also replaced the bulbs. No turn, no back up and no brake light. Passenger Side only, driver works fine.
    Any idea on what it may be tied too or if this is a common occurrence?
  2. Jun 20, 2012 at 3:51 PM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Problem solved, harness was cut up by the cab... not sure how.
  3. Jun 20, 2012 at 3:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Did you just splice it back together?
  4. Jun 20, 2012 at 6:25 PM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Not yet, but thats the plan. I'll need some solder to do it right.
  5. Jun 20, 2012 at 7:45 PM
    undermoneyed
    undermoneyed aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    You can crimp it and tape over the crimp, it'll work just fine. A lot of guys won't solder because the joint is not as flexible. HTH.
    Mark
  6. Jun 21, 2012 at 5:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Solder and heat shrink is a MUCH better solution than a crimped joint with electrical tape... The only crimped joint that I'd ever consider using would be the crimped joints with the heat shrink on the outside to seal the joint. Electrical tape does not do a good enough job sealing the joint, especially if it's outside of the cab.
  7. Jun 21, 2012 at 6:15 AM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    ^ exactly
    Looks like someone cut it when they apparently stole my spare -__-.
