Fuse Size???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoapw, Oct 11, 2011.
  1. Oct 11, 2011 at 7:20 AM
    tacoapw
    tacoapw [OP] Member
    Northeast
    2011 TRD Sport Access Cab
    35 Watt 6000K HID's, Westin Bull Bar, Westin Step Bars, PIAA 540 Driving Lights, Uniden PRO520XL CB
  2. Oct 16, 2011 at 5:36 AM
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
  3. Nov 9, 2011 at 9:07 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    After looking at a bunch of pictures, I am still unsure as to how the add-a-fuse actually works. I want to tap into the 12V ACC fuse (I believe its for the dual cig lighters) and run a 7,5A fuse for the heated mirror mod.
    Does this replace the original fuse, and just give me another power leg? So basically 1 fuse for both applications?
  4. Nov 9, 2011 at 9:14 AM
    52419 Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    thius is how the add a fuse works you pull the stock fuse and stick it in the black block were it accepts two fuses then you add the fuse for your accesory then you plug the whole deal into the stock location connect your power wire and your good to hook well after you connect the ground that is.
    Kanebutler13 likes this.
