FWP Fab Teardrop Trailer Build / Restoration #overlandAF
Discussion in 'First World Problems Fabrication' started by Zac of all trades, May 18, 2018.
  1. May 21, 2018 at 8:03 PM
    Zac of all trades
    Zac of all trades [OP] FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    How wide is your trailer?
    ETXTacoma likes this.
  2. May 22, 2018 at 5:37 AM
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    When I built mine I did the inside of the box 4’ so I could use it as a good utility trailer when not camping. It’s 53” wide measured from the outside of the frame side to side
  3. May 22, 2018 at 5:58 PM
    Zac of all trades
    Zac
    fwpfab.com
    Nice a little dual purpose.... I looked up hubs for the axle and they are about $50 each so for another $20 i can get a new axle and hubs... But if the axle will work then i can save $20.
    I have a line on a couple wheels for $40. Still looking around though...
  4. May 22, 2018 at 7:18 PM
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    Yeah at that point it’s almost be worth getting the new axle.
  5. May 23, 2018 at 2:20 PM
    Zac of all trades
    Zac
    fwpfab.com
    Yea but if your axle works and we can get TW express to deliver then that $20 would pay for the rear LEDs...
  6. May 23, 2018 at 5:06 PM
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    I like the way you think.
  7. May 23, 2018 at 6:39 PM
    Zac of all trades
    Zac
    fwpfab.com
    I figured i would move this to here...
    I will check them out and see what they have for my trailer. Not sure if i will need electric brakes though. What is the weight limit that requires electric brakes? I just need to get the tires outside the frame so i can get larger tires and tow faster than 65mph
    When i towed the trailer from dallas to canton i didnt even feel the trailer. And it tracks very well.
  8. May 23, 2018 at 8:08 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Legally you do not need them but both me on 35s and the trailer loaded it’s night and day with the brakes on there. Going through Colorado and the mountains I had no issues with the truck brakes since I put more power to the trailer to help slow me down.
  9. May 23, 2018 at 8:12 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Might work for whenever I come back down to help do some 63s for someone. Or build joe a trailer :D
    Zac of all trades[OP] likes this.
  10. May 24, 2018 at 6:37 AM
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    The list for 63s is growing :sawzall::welder:
  11. May 24, 2018 at 5:16 PM
    scocar
    scocar Patron of the Farts
    Check your state vehicle code. The limit here is 1500 lbs. The dry weight of the trailer was specifically pegged at a bare bones 1499 from the maker to avoid this. Wet and geared up for a big trip (plus other as-built options), it's probably 1750. My 01 V6 manual had no issues (except for maybe very strong headwinds and uphill gradient...FU US 6 in Utah between Green River and Soldier Summit). I strongly doubt your trailer will be required to have them, nor need them with your 2nd gen.
  12. Jun 5, 2018 at 6:20 PM
    Zac of all trades
    Zac
    fwpfab.com
    New wheels & tires are ready for the trailer!! Still need that wheel (@Tundra2Play ) from @ETXTacoma So I can mount that 3rd tire as a spare. Also looking for a cheap basket rack to put on top of the trailer.
    • 17" wheels - Width: 7.5", Offset: +18mm, Backspacing: 5", Hub Bore Diameter = 106mm
    Wild Crow, ETXTacoma and Drainbung like this.
  13. Jun 7, 2018 at 2:25 PM
    Zac of all trades
    Zac
    fwpfab.com
    Just ordered the new trailer axle!
    Cabin exterior is 48" wide but i have to order a 64" long hub-face axle to to fit this +18mm offset and have a 2" gap between the cabin and tires! 6" to the out side of the tire!
  14. Jun 11, 2018 at 3:07 PM
    Zac of all trades
    Zac
    fwpfab.com
  15. Jun 14, 2018 at 8:39 PM
    #35
    Zac of all trades
    Zac
    fwpfab.com
    Picked up the new axle today!
    Bigdaddy4760, ETXTacoma and Drainbung like this.
  16. Jun 21, 2018 at 11:12 AM
    #36
    Zac of all trades
    Zac
    fwpfab.com
    Couple updates on the trailer....
    • New 3500lb axle installed
    • 17" tundra wheels on 265 70 17 KO2s installed.
    • old cabinets ripped out
    • cardboard cabinets mocked up on the inside rear wall and above the head on the front wall.
    Got a huge lift. Its leaf over axle right now, thinking about going leaf under axle to drop it about 3"
    Wild Crow and Bigdaddy4760 like this.
  17. Jul 5, 2018 at 8:10 PM
    #37
    Zac of all trades
    Zac
    fwpfab.com
    ETXTacoma and tacomavoyager like this.
  18. Jul 5, 2018 at 8:13 PM
    #38
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Trailer looks badass with those wheels and tires under it.
  19. Jul 5, 2018 at 8:26 PM
    #39
    Phoosa
    Phoosa I never saw nothing.
    Truck
  20. Jul 5, 2018 at 8:47 PM
    #40
    Zac of all trades
    Zac
    fwpfab.com
    Thanks! I should be building the fender flairs for them soon. Going with square over the rounded ones.
