FX-R Output
Discussion in 'Lighting' started by tunedx, Mar 21, 2010.
  1. Mar 21, 2010 at 7:17 AM
    tunedx
    tunedx [OP] Well-Known Member
    X-Runner
    I ran ls430 projector retrofit on my Tacoma X-Runner for a couple years which had amazing width and ton of foreground but no flicker (bling factor) I replaced the lens with tsx-r and had a nice blue cutoff and increased the output. I'm interested on memebers that are running the fx-r are they satisfied with the foreground light, did u space the bulb and hows the flicker (color band)? I know this projector has a mountian below the cutoff. Does this bother anyone?
  2. Mar 21, 2010 at 6:20 PM
    tunedx
    X-Runner
  3. Mar 23, 2010 at 12:08 AM
    elephatitis
    elephatitis Member
    why not keep the ls430 and be different? with the clear lens and the spacer, you have a flicker similar to s2k projectors.
    The fx-r has a more focused beam, but you cant beat 165 degrees of width.
  4. Mar 23, 2010 at 9:13 AM
    tunedx
    X-Runner
    I sold them and looking to start my 2nd retro and would like some input with the members that are running these projectors on a truck?
  5. Mar 23, 2010 at 9:43 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    To be honest I don't know a whole lot about the FXR's, I ended up paying yosh2000 to assembly my setup. He could probably answer your questions about mine better than I could but what exactly are you trying to find out?
    I love the output of mine
  6. Mar 23, 2010 at 1:20 PM
    elephatitis
    elephatitis Member
    what you need to know?
  7. Mar 23, 2010 at 2:39 PM
    tunedx
    X-Runner
    Do these produce enough forground light( light on the road) factory or was spacing the bulb needed. Also hows the light flicker (color band, bling factor)?
  8. Mar 23, 2010 at 4:39 PM
    elephatitis
    elephatitis Member
    in my opinion beam is instense, flicker is nice, no upgrades are needed
    arent you a member of hidplanet? there are millions of output pics on there
  9. Mar 23, 2010 at 6:22 PM
    tunedx
    X-Runner
    Yeah I would just like some real input with these mounted on a truck
  10. Mar 23, 2010 at 7:36 PM
    1BlkT
    Ty
    90603
    Here's a quick cell phone pic of mine
    The wall slopes to the right a little as well
  11. Mar 25, 2010 at 11:53 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ^ that is w/ the included 1mm spacer TRS supplies, FYI.
    as seen in the hidplanet output shots, the FX-Rs have a little strip down the middle that i think will help w/ the trucks...i'll let you know for sure one day when i finally finish my set!
