FX-R projector Retro
Discussion in 'Lighting' started by carolinataco, Oct 6, 2010.
  1. Oct 6, 2010 at 7:43 PM
    carolinataco
    carolinataco [OP] Well-Known Member
    Has anyone done a FX-R retro on their tacoma? Is there a write-up any where? How did you mount it to the reflector and keep it plum and level? Did you have to bore out the back of the reflector for the projector to fit through? Pics would be AWESOME....
  2. Oct 7, 2010 at 3:13 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    yes, many others have as well. check out a post by electronman. skillfully and double check before you mount it up (hint: the lines in the reflector are horizontal and vertical...;)). yes, 2.5 hole saw works perfect i have found. dont have any pics other that what i have posted...
  3. Oct 7, 2010 at 3:15 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    x10 of the above
    Yosh and Electronman are both very good to get tips and help from.
    good luck
