FX-R Retro progress...
Discussion in 'Lighting' started by AsianAnts, Jun 14, 2011.
  1. Jun 18, 2011 at 10:07 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
  2. Jun 18, 2011 at 10:13 AM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    The two wires in your pic plug into each other. You will have to attach the silver prongs to the wires then put the prongs into the male black connector (pictured on the right) then plug it into the female connector (pictured on th left)
  3. Jun 18, 2011 at 10:30 AM
    AsianAnts
    AsianAnts [OP] just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    ok! i think i got it.. but in the end, im short a pair of those 'wires w/ prongs at the end' as a part of the harness
  4. Jun 18, 2011 at 10:48 AM
    08PRELB
    Adam
    805
    08 Prerunner LB
    The wiring harness should just have the female end of the connection. When I did mine Just had to put the silver prongs on the wires coming from the projector and then put the black male connector onto the wires. Once I did that all I had to do was plug the connectors together.
  5. Jun 18, 2011 at 11:03 AM
    AsianAnts
    AnT
    im soo confused:confused:.. the harness has no female... the only female are the 2 that goes into the ballast... other than that its just prongs or the wires with a washer shape at the end to connect to the battery....
    from top left going down:
    retro in the making w/ 2 prongs sticking out projector
    male connector (under retro in the making)
    female connector (under retro in the making)
    From top right going down:
    Finished retro w/ male connector at end of projector
    harness w/ 2 prongs sticking off to lower left side of pic.
    i figured we didnt need the rest of the harness in the picture because the rest of the harness is just the 2 female connectors that plug into the ballast.
  6. Jun 18, 2011 at 11:52 AM
    AsianAnts
    AnT
    on a different note from the harness,
    do these shrouds need trimming?? it seems to fit fine... LOL
    oh gosh im soo nuub:eek:
    NVM I SEE IT!!! YAY
    (i looked very closely to the finished one... and im gonna mirror it)
  7. Jun 18, 2011 at 9:15 PM
    08PRELB
    Adam
    805
    08 Prerunner LB
    Man I'm really not sure what to tell you about the wiring harness. Where did you get this kit from? Did you buy someone on here or from a vendor?
  8. Jun 19, 2011 at 10:43 AM
    jdmbb6
    jdmbb6 Member
    Sounds like your wiring harness does not have the high beam wired in. I would either call Matt at TRS to get one wired up or just hardwired it yourself.
    You can see the ends of the harness it has the high beam attachment built in.
    Good luck Bro...
  9. Jun 19, 2011 at 10:45 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    i might have to hit you up to help me when i do mine :thumbsup:
  10. Jun 19, 2011 at 11:31 AM
    AsianAnts
    AnT
    I got the kit from Matt @ TRS... i shot him an email so im just waiting for a reply.
  11. Jun 19, 2011 at 11:32 AM
    AsianAnts
    AnT
    :D
    trying to get aaron to assist with this whole process ;) maybe i can bring my smoker and smoke ribs and shiet... :D
  12. Jun 19, 2011 at 12:12 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Cool for sure!! Ive been going to aarons alot lately so let me know :D
  13. Jun 19, 2011 at 12:26 PM
    AsianAnts
    AnT
    i really feel like taking the other headlight apart and tinting the signal/dtrl lens yellow along with the one i already have apart.
    hmmm...... sounds like a good idea: LED gauge done by you, lights by aaron... and ill smoke ribs and bring some brewskiessss :p hahaha
  14. Jun 19, 2011 at 12:28 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Hahaha. For sure :thumbsup:
  15. Jun 19, 2011 at 12:36 PM
    #35
    AsianAnts
    AnT
  16. Jun 19, 2011 at 12:37 PM
    #36
    Jerez
    Rod
    Ontario Ranch
    Estock
    Not sure man...but pm RAD (ray) he should be able to tell you what to use;)
  17. Jun 19, 2011 at 1:14 PM
    #37
    AsianAnts
    AnT
    havent glued anything yet... but i finished painting yesterday
  18. Jun 19, 2011 at 3:38 PM
    #38
    08PRELB
    Adam
    805
    08 Prerunner LB
    Looking good man. Yah I would say getting a hold of Matt at TRS would be your best bet about the wiring harness
  19. Jun 19, 2011 at 7:35 PM
    #39
    AsianAnts
    AnT
    :typing: im on it! :)
  20. Jun 22, 2011 at 8:00 PM
    #40
    08PRELB
    Adam
    805
    08 Prerunner LB
    Hey man any progress did you figure out whats up with your wiring harness?
