G scotts PreRunner(soon4x4)
Discussion in '1st Gen. Builds (1995-2004)' started by G scott04, May 4, 2011.
  1. Jul 5, 2011 at 8:29 AM
    #81
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    hes pretty busy with work and some deal with the fire dept, so its all good but he said he will be done with that soon and have plenty of time
  2. Jul 5, 2011 at 8:52 AM
    #82
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    good cause im ready for this to be 4wd!
  3. Jul 5, 2011 at 8:54 AM
    #83
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i went up to strawberry yesterday and we were out around fossil creek and there were 2 jeeps and a little rhino that i got stuck with... i want my effin truck back on the road!
  4. Jul 5, 2011 at 1:34 PM
    #84
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    yo brian you find out your work schedule?
  5. Jul 28, 2011 at 8:25 PM
    #85
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Pictures moved to OP
  6. Jul 28, 2011 at 8:28 PM
    #86
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Moved to OP
  7. Jul 28, 2011 at 10:13 PM
    #87
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
  8. Jul 28, 2011 at 10:26 PM
    #88
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    It's getting there!
  9. Jul 28, 2011 at 10:59 PM
    #89
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Moved to OP
  10. Jul 28, 2011 at 11:39 PM
    #90
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Great job. hope it all goes smoothly
  11. Jul 28, 2011 at 11:55 PM
    #91
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Thanks man everything has gone well so far so hoping tomorrow works out just as well, the last few days have been long ones lol
    been puttin in some hard work!
    except for brian, he just stands around and says hateful things about my automatic :(
    jk :D
    HUGE shout out to Brian (BFA)
    He's a great guy if you haven't met him yet,
    and this project wouldn't have gone half as well or even been possible without his help.
  12. Jul 28, 2011 at 11:58 PM
    #92
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Very nice soon to be 4x4 prerunner!
  13. Jul 28, 2011 at 11:59 PM
    #93
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I havent met him yet, mostly because ive been in Yuma all summer and havent been able to hang out with any of you guys. He sounds like a hell of a guy if he's helping you out with your big project. Props!!
  14. Jul 29, 2011 at 6:20 AM
    #94
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    yup yup! and im up again this morning already we gotta get my truck on the trailer and be at the lift by 8, today ill find out if its driveable :D
  15. Jul 29, 2011 at 7:13 AM
    #95
    97yota4wd
    Eric
    Mesa, AZ
    sweet dude! yeah brians a great guy, he helps everyone! including me lol
    dude this thing is sweet! im stoked for you!
  16. Jul 29, 2011 at 9:40 PM
    #96
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Ran into some problems today after installation.
    Today Me, brian, and robert rented a bay with a lift and installed the transmission succesfully in good time, the tranny jack, lift and air tools the shop had made 200%percent difference in the labor.
    And the transmission/ transfer case has full operating range, P R N D 2 1, and the 4hi and lo all engage.
    the only problem is the t case (j shifter ) does not have a speed sensor either, so I tried to drive it home without it, and the truck drove fine the parking lot, but when I went on the main road and slowly accelerated, it shifted a little clunkily into 2nd then 3rd.... and wouldn't shift any higher, it just rev'd up in third gear. so I thought it might be cause of the speed sensor, so I called the local transmission shop who has have been extremely helpful to me for this project, I have been calling and asking questions, and I called him and told him all of the symptoms
    and that I didn't have a speed sensor, he said that he believes it is the cause and because the computer
    doesn't know how fast I'm going it won't shift into overdrive.. and he thinks if I can get a speed sensor
    it should fix the problems...
    I'm hoping that will be the solution and I'm trying to not let myself get stressed about it yet but my truck isn't driveable...
    also I have a few other strange symptons, nothing on the dash seems to work I know the RPMs and MPH
    is because of the speed sensor, but the engine temp needle doesn't do anything either? and also the RR DIFF LOCK light is on and i don't have the TRD never even knew I had the light... and the ECT power button doesn't work either..
  17. Jul 30, 2011 at 8:30 AM
    #97
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Ill be calling around today, anyone know of anywhere I could call for a speed sensor?
  18. Jul 30, 2011 at 3:42 PM
    #98
    G scott04
    G scott04 [OP] ...
    Garrett
    Mesa
    04 PreRunner
    Ok Napa luckily had one in stock and it was about a hundred dollars cheaper
    than what the dealer wanted, but unfortunatley napa or nyone else sells the speed sensor with the gear and pin thing in it, so I have to buy one separately from the dealer, I think its only 30 though.. but
    they are a special order so i have to figure out how many teeth I need, 31, 32, 33
    and call him up by monday to get the order in, I think he said it will be in tuesday on the phone, forgot to ask when I went in in person.
  19. Jul 31, 2011 at 11:28 PM
    #99
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    fuck your automatic..
    jk but not really jk i still hate autos lol but no problem dude lemme know when you get your speed sensor and im pretty positive it will solve all your problems
  20. Jul 31, 2011 at 11:37 PM
    #100
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    The anticipation is killing me!
