garage door button with pictures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spyshot, Aug 26, 2010.
  1. Aug 26, 2010 at 2:56 PM
    spyshot
    spyshot [OP] Well-Known Member
    Dayton Ohio
    09 TDR OFFRoad
    i wanted to put a button in the blank spot next to the A-Trac button below the HVAC controls. this button activates my garage door using my wireless remote. i didn't find any posts on putting a switch in this location, so i figured I'd post some pics if someone else was interested in doing that.
    i bought a push button switch: B Electrical Inc Model: GSW-22. I recommend this exact model because it worked perfect, you'll see why later.
    start by removing the 4X4 switch knob then pull the 4X4 shroud out. should pull straight out. i used two needle nose pliers to grab behind where the knob was and pull. then reach your fingers behind the HVAC controls and push on the clips that hold the housing in. that pops the left side of the HVAC off and the right comes off with some more tweaking and pulling.
    I put my fingers in the hole above the blank and felt around till i could feel the clip holding the blank in on the top. and after some pushing it popped out.
    as you can see, there is a lot of plastic on the back side of the blank. i used a dremel and other tools at my disposal to remove the excess plastic in order to make room for the switch.
    here's what it looks like after the cutting. make sure you do not cut off the clips. these will be used to hold the blank and switch back in when you're done.
    every garage door remote is different. you'll have to open yours up and determine where to connect your wires to complete the circuit when the new switch in used. here's the circuit board out of my remote.
    then i took the button covers out of the remote and here is my completed setup.
    you'll need to drill a hole in the blank and insert the switch. notice how perfectly it fits? the only thing i did was i bent the brass arms inward a little bit, to allow the clips on the blank to flex in order for it to be inserted back into the dash.
    here is the finished project. be sure to do several tests along the way. you don't want to repeat any of this if you don't have to. after putting the blank back i tucked the remote under the dash just to the right of the steering column. easy access in order to change the battery when needed.
    helper is optional....
  2. Aug 26, 2010 at 2:58 PM
    JohnnyGato
    JohnnyGato God of Thunder ...and Rock N' Roll!
    Vegas Island
    04 TRD SR5 V6 4x4 Off Road
    Limo tint, Sirius/XM radio, Wet Okole's, Weathertech's, Rhino Lining, blacked out badges, shorty antenna, painted speaker (tweeter) covers, blue LED running lights, Icon 3" lift, Pro Comp 17" 7005's, 33" (285/70/17) Good Year MT/R's with kevlar.
    Dude... killer job. I have a background in garage doors so to all you out there who attempt this make SURE you use the right compatible remote.
  3. Aug 26, 2010 at 3:22 PM
    white91formula
    white91formula Well-Known Member
    Boston, MA
    05 6speed TRD OR
    why not just put the remote in the overhead console... theres a spot for it withi a button and everything...
  4. Aug 26, 2010 at 3:24 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Damn nice
  5. Aug 26, 2010 at 3:27 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Awesome write-up, but my favorite part was the helper!! What a cute little guy!!
  6. Aug 26, 2010 at 3:29 PM
    WTtoolman
    William
    Omaha, NE
    Not all tacoma's have that. I believe if you have the TRD package with overhead compass, you don't have the garage door opener built in.
  7. Aug 26, 2010 at 3:33 PM
    "OldManTan"
    "OldManTan" Now my Taco is bloody Red, ewww
    Buffalo, NY
    08 Access Cab, Radiant Red
    Pioneer HU, Duratracs on Black stockers, Century topper with custom electronic lock, Illuminated 4x4 switch, Foglight Mod, Always on 12v Plugs, Sub & Amp, LED Interior Lights, Cup Holder Mod, Andres Devil Horns, CB radio, steps, relocated trailer harness, blacked out everything!!
    Very nice job, and great write up! it looks like your little guy was happy that the job was done right!! I hope he wasn't too tough of a supervisor!
  8. Aug 26, 2010 at 3:37 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    correct.....compass/temp>garage door button
    on that note, i'm trading my sunglass holder for a garage door button...lol
  9. Aug 26, 2010 at 4:15 PM
    tx_shooter
    tx_shooter This place is a cesspool of bfo and spacer lifts
    Because my garage door opener doesn't work in that little "one size fits most" compartment. This is a pretty cool write up - thanks.
  10. Aug 26, 2010 at 4:20 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Nice work!
  11. Aug 26, 2010 at 4:30 PM
    TerryS
    TerryS Well-Known Member
    Terry
    Cape Cod, Mass.
    '10 SR5 AC 4x4
    WeatherTech floor liners and wind deflectors; shorty antenna; OEM tow hitch & wiring; bed mat; accessory meter console w/temp & compass; 4WD switch lighting mod; Viper 5301 Remote Start; TRD front tow hook and aluminum skid plate; color matched door handles & grille; FJ fog light switch with on/off indicator light; fog light anytime mod; N-Fab steps; Extang tonneau; Blu-Logic bluetooth, and; TRD OR alloy wheels.
    Nice work and I also like the assistant. I wonder though, I've seen quite a few garage door opener mods here in the short time I've been reading the forum. Some are very inventive, but wouldn't it be easier and cleaner to use a Flash2Pass opener? See http://www.f2ptechnologies.com/ It takes about 5 minutes to install.
    Terry
  12. Aug 26, 2010 at 4:31 PM
    JohnnyGato
    Vegas Island
    That "garage door button" is known as "Homelink." It should be compatible with most contemporary garage door openers.
  13. Aug 26, 2010 at 5:16 PM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    The baby made the thread. LOL
  14. Aug 26, 2010 at 5:18 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    I got a gentex homelink rear view mirror...just haven't had the time to install it...
  15. Aug 26, 2010 at 5:21 PM
    jhodge83
    SC
    17 XLT Sport
    05+s w/o TRD have a garage door opener holder in the center roof console instead of the compass. the garage door button at least i was referring to was this, not mirror buttons
  16. Aug 26, 2010 at 5:28 PM
    spyshot
    Dayton Ohio
    09 TDR OFFRoad
    that's correct. i have an overhead compass and two map lights.
  17. Aug 26, 2010 at 5:32 PM
    spyshot
    Dayton Ohio
    09 TDR OFFRoad
    if it's anything like homelink, i have another vehicle with homelink that would not work on this opener. plus all this cost was a $3 switch. it was kind of fun too!
    adam
  18. Aug 26, 2010 at 5:39 PM
    spyshot
    Dayton Ohio
    09 TDR OFFRoad
    [quote="OldManTan";2107517]Very nice job, and great write up! it looks like your little guy was happy that the job was done right!! I hope he wasn't too tough of a supervisor![/quote]
    not too bad at all. Easy way to keep Brendan entertained for a little while.
    adam
  19. Aug 26, 2010 at 6:23 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Verynice job and use of the switch location. Gotta love Bumbo chairs!
  20. Aug 26, 2010 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Well done!
