Garage finish
Discussion in 'Garage / Workshop' started by teamfast, Apr 28, 2012.
  1. Apr 28, 2012 at 7:57 PM
    teamfast
    teamfast [OP] Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Posted and picked up a house with a 21' x 21' x 10.5' unfinished garage. Will park in there in the winter and normally wash vehicles in it with doors open if its really sunny out (for the shade). I will insulate it and am looking for ideas on garage wall/ceiling finish ideas. I have done a few in drywall and have considered other materials than the usual gyprock.
    If i go drywall again i will try this new ultra light stuff and paint it with a gloss to repell water the best. Comments?
  2. Apr 28, 2012 at 8:02 PM
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    probably should use blue board that is made for high moisture areas like bathrooms. At least for the lower half of the walls. I'd love to have a garage to pimp up like that. Oh make sure the drain works well or the floor is pitched to keep the water and snow melt form sitting in the corners.
  3. Apr 28, 2012 at 8:16 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Sheet the walls with 1/2" ply then drywall over that .
    You can hang shit anywhere .
  4. Apr 28, 2012 at 8:26 PM
    1980 Well-Known Member
    The Dust Bowl
    Check your local building code -- most areas require fire-rated wallboard in garages if they are attached to a house.
  5. Apr 29, 2012 at 4:19 AM
    rbishopp
    Rich
    Webster, NY
    Required or not just a good idea. I've seen several house fires that started in the garage.
  6. Apr 29, 2012 at 4:27 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Roofing steel for walls and ceiling, over 1/2 plywood. Lots of color choices, and you can paint, wash, weld... Whatever you want. Super easy to clean too A buddy of mine did it to his garage. Looks and performs great. And, you can still screw into it to hang shit anywhere.
  7. Apr 29, 2012 at 7:10 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    pics?
  8. Apr 29, 2012 at 7:45 AM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    I asked about bldg code in Ontario and the inspector/builder is doing the minimum, OSB and Typar over that. The lower two feet is block construction so no worry about moisture on the lower half of walls, the block concrete will be exposed anyways. This house will only be mine for the next 2-3 until we get posted again so 1/2" ply wrapped in drywall isnt an option (cost). Nice idea for the last house we own though! Would have to move the outlets out to compensate as well.
  9. Apr 29, 2012 at 10:31 AM
    CantSitStill
    FTR
    CNY
    Sorry, no. And he's a long way away and doesn't even own a cell phone
  10. Apr 29, 2012 at 10:56 AM
    OZ-T
    Peter North
    British Columbia
    If you are building it from scratch you can set the boxes at 1" otherwise you can just use box extensions
  11. Apr 29, 2012 at 10:57 AM
    OZ-T
    Peter North
    British Columbia
    Up here , if the garage is attached to the house you need to use firerated drywall , if the garage is detached you don't
  12. Jun 2, 2012 at 6:20 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Im going to check with local code but i think id like to install slatboard/slotboard/slatwall whatever you call it. Its pricey though but function is awesome.
    Ontario Building Code 2007:
    3.2.2.83. Group F, Division 3, Storage Garages up to 22 m High
    (1) A building used as a storage garage with all storeys constructed as open-air storeys and
    having no other occupancy above it is permitted to have its floor, wall, ceiling and roof
    assemblies constructed without a fire-resistance rating provided it is,
    (a) of noncombustible construction,
    (b) not more than 22 m high, measured between grade and the ceiling level of the top
    storey,
    (c) not more than 10 000 m2 in building area, and
    (d) designed so that every portion of each floor area is within 60 m of an exterior wall
    opening.
  13. Jun 4, 2012 at 1:20 PM
    teamfast
    Winnipeg, Manitoba
    '10 DCLB
    Ok slotwall is not going to fly. To cover the walls it will cost me $847 plus tax. Way too much for all that function. Def in my last garage though. Regular old drywall i suppose. 1/2" ceiling 5/8" on the walls. So boring.
