Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Jun 21, 2020 at 8:37 PM
    #2021
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Check out Frank Howarth on YouTube if you’re into woodshop porn.
    ohcaltexscar likes this.
  2. Jun 22, 2020 at 3:26 AM
    #2022
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    I was going to gap the plugs with the gapping tool. Then check for accuracy with the feeler gauge.
    The gapping tool I have doesn't have all the measurements I need.
  3. Jun 22, 2020 at 3:55 AM
    #2023
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Running valves is a lost art anymore, a lot of “mechanics” have no idea how
    Even the shim over/under bucket need to be checked, not that I’ve done mine....
    Having the right tools helps the process
    CE5A27C8-9637-4417-9C94-811C73643FAD.jpg 96568417-F345-42E8-83F5-82EA3721EC36.jpg 808229BF-751C-43A9-AD37-9A4C1E640C26.jpg
    Coolerman, mtip and CXYyuppie like this.
  4. Jun 22, 2020 at 4:49 AM
    #2024
    El Chap the Taco
    El Chap the Taco Well-Known Member
    2017 TRD OR MT
    I live in a townhouse with no garage, but recently got a shed to store what few tools I have. I'm excited to have room to store more and expand my collection as I learn more!
  5. Jun 24, 2020 at 9:45 PM
    #2025
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Just wanted to share this little gem. As you can tell by the background of the picture, I have a lot of adhesives and or threadlockers and whatnot. I found out about B700 from a YouTuber that casually mentioned it but it’s worth sharing this info. B700 is the bastard child between rubber cement and crazy glue. Excellent adhesion while remaining a little flexible and gummy. The tube itself and dispensing tip keeps the product sealed and provides a super long shelf life. The cap has a needle built in about 3/4” long that makes sure the glue doesn’t dry in the tip. I k ow this sounds like an infomercial, but if you don’t know about it, order some. It’s pretty awesome. I’m sure it’s handy for crafters so your SO might borrow it but I keep it in the toolbox too. Oh, and the piss poor English translation (Chinese product) is always good for a laugh.
    AD Beads Strong Super Glue for Jewelry Watch Repair Multi-Purpose (B-7000 Glue Adhesive 15ml) https://www.amazon.com/dp/B072FJDCBV/ref=cm_sw_r_cp_api_i_zUc9Eb7HNE58J
    Martyinco, Wyoming09, PzTank and 5 others like this.
  6. Jun 26, 2020 at 4:28 PM
    #2026
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Been wanting this thing for a while.
    Maxcustody, tritip, TK-422 and 5 others like this.
  7. Jun 26, 2020 at 4:34 PM
    #2027
    GHOST SHIP
    GHOST
    How much does it weigh? I have the bigger one and it does the trick but it gets really heavy after a long day.
    Drainbung likes this.
  8. Jun 26, 2020 at 4:36 PM
    #2028
    T4RFTMFW
    They’re all heavy, cordless is great for some reasons but weight isn’t one of them, compared to an Air Cat or similar pneumatic.
    If I was doing it all day I don’t see a benefit to cordless 1/2” or bigger impacts.
  9. Jun 26, 2020 at 6:47 PM
    #2029
    cynicalrider
    cynicalrider #NFG
    Jersey
    I got the medium one and it's awesome for trail repairs.
    mjbtaco[QUOTED] and Drainbung like this.
  10. Jun 27, 2020 at 12:45 AM
    #2030
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    #1 not dragging a hose around with you.
    I see more and more on car shows they are using cordless impacts for their work.
    Lawfarin and Drainbung like this.
  11. Jun 27, 2020 at 6:53 AM
    #2031
    T4RFTMFW
    Shows are sponsored, so makes sense.
    The hose thing is the only benefit of cordless and that’s minor. Pneumatic for $150 that is smaller, weighs significantly less, runs all day long with consistent power and a lot of it makes a lot more sense than $500+ in a cordless setup that is the opposite of all those things but saves you from pulling an air hose.
    Working on stuff all day long that requires an impact is probably 100x more laborious than moving an air hose every so often.
    ohcaltexscar, Wyoming09 and Drainbung like this.
  12. Jun 27, 2020 at 10:04 AM
    #2032
    mjbtaco
    Michael
    Montclair , so cal
    It weighs around 8lbs with a 5ah battery in it. Which bigger one do you have? This is the full size 1/2" drive compared to my 3/8" drive sub compact
    spencermarkd and Drainbung like this.
  13. Jun 27, 2020 at 10:09 AM
    #2033
    mjbtaco
    Michael
    Montclair , so cal
    Also I don't use it for work. This is just a home garage tool so weight really isn't a big deal for me. I have an air setup and its not the greatest. So I just got the cordless since I already have all the batteries.
  14. Jun 27, 2020 at 11:31 AM
    #2034
    GHOST SHIP
    GHOST
    I guess mine is the older LXT model (brushed). Looks a lot bigger. I use mine at home as well so the weight isn’t as much of a pain but after a long day it does get tiresome.
    40D69D6C-BD18-474E-8F7D-D64782FF2155.jpg D750D772-2B17-47A2-AC04-21E6A6D9F916.jpg
  15. Jun 27, 2020 at 1:31 PM
    #2035
    Blkvoodoo
    Kevin
    Near Clayton NC
    cheap but reasonably powerful for a 3/8", fits in tool bag and allows me to do things faster, walking thru various plants and businesses to do a repair gets cumbersome, and tiring.
    Ive also got a 1/2", it won't do lug nuts on the stuff I work on, but then again, I've got air and it'll be near the van when I have to do that.
    I guess you could say I'm a fan too....
  16. Jun 28, 2020 at 4:46 AM
    #2036
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Moot point when you drag welding cables extension cord adding a air hose is no big deal
  17. Jul 1, 2020 at 8:13 PM
    #2037
    mjbtaco
    Michael
    Montclair , so cal
    Love this thing
  18. Jul 1, 2020 at 10:27 PM
    #2038
    tritip
    tritip Well-Known Member
    Drew
    2014 dcsb trd offroad
    I just bought one of those also. :headbang:
    mjbtaco[QUOTED] likes this.
  19. Jul 2, 2020 at 4:29 PM
    #2039
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Ordered me a new box today. I have a 36” husky box now I was given but some of the drawers don't open correctly and I just wanted a new one hahah
    PzTank, TK-422, Snowman and 3 others like this.
  20. Jul 2, 2020 at 4:32 PM
    #2040
    Babybluetaco
    Austin
    09 5 lug
    I like the flag up top. Where did you get that?
