Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Feb 20, 2019 at 12:12 PM
    #201
    scocar
    scocar hypotenoper
    I like having both. I like having a clean, well-lit place where I can do detail and clean work, plus a rollaround beater work table that is lower so I can get over and lean into stuff, fuck it up, and not care. Can also roll it outside for messy work like sanding, sawing, rattle canning, etc. I need to rebuild my current one that has done me so well over the years, and am going to scavenge my maple top from another bench I'm going to trash. If I did any welding, I'd have a steel rollaround for that, too.
    I like one home base bench, then everything else on wheels.
  2. Feb 20, 2019 at 12:32 PM
    #202
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Are you cutting aluminum with your miter saw? What sort of blade do you use for that? Do you use the same saw for wood?
  3. Feb 20, 2019 at 1:17 PM
    #203
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Any carbide tipped blade works good for cutting aluminum.
    I cut all the pieces for my aluminum drift boat build using a miter saw and a circular saw.
    It will dull them faster than just cutting wood. Maybe dull a third faster or so.
  4. Feb 20, 2019 at 1:53 PM
    #204
    scocar
    scocar hypotenoper
    Yes. 80T. Yes.
  5. Feb 20, 2019 at 3:51 PM
    #205
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    This is my small little garage shop setup. I wrench a decent amount but I do a lot more metal fabrication so my garage is more setup for that. I have the big Husky tool box. I like it. Couple of the things that I’ve purchased semi recently that have been game changers for me are the fixture style welding table and the CNC plasma table. I have a pass through garage which is great for ventilation and also helps with extra space. I do all my tube bending in the backyard.
    Last few pics are the fill plates done on the Plasma table for some sliders
  6. Feb 20, 2019 at 6:27 PM
    #206
    The Real Moondog
    The Real Moondog Well-Known Member
    Moondog
    Somewhere in the SE USA
    2017 Quicksand Tacoma TRD Off-Road (Sold :()
    I just bought that one, along with the breaker bar. I haven’t used it yet but look forward to trying it out. It seems nice and sturdy but we will soon see.
    Correction, mine was 10-150. My bad.
  7. Feb 20, 2019 at 6:48 PM
    #207
    mlowber
    mlowber Well-Known Member
    Lyons, CO
    2007 TRD Sport
    Id love to see your bending setup. And how much you have invested into it. I have that press in a box about to be assembled.
    Shmellmopwho[QUOTED] likes this.
  8. Feb 20, 2019 at 8:52 PM
    #208
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    I’ll take a better picture tomorrow if I remember but I have a JD2 model 3 bender with a 1.75” tube die (the one I use most, also have a 1”). I made my own rolling stand. It has a Swag Offroad hydraulic cylinder clamp with a Harbor Freight 10 ton long arm ram for running air over hydro setup. I use a digital angle finder and a plane of bend bracket to make sure that I can keep a nice plane of bend to get flat parts.
    Tube bender $300
    Tube die $325
    Swag clamp $150
    Long arm ram $100
    Digital angle finder $30
    Plane of bend bracket $25
    Total $930
    Paid for itself soooooo many times over I can’t even count that high. Well worth it.
    I love that little press. Great tool to have at home. You should check out swag Offroad for their DIY press brake kit. I have one and it’s great to have if you wanna bend plate.
  9. Feb 23, 2019 at 4:19 PM
    #209
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Added a new tool to the arsenal this week. An HTP Invertig 221:welder:.Just finished the cart today.20190221_180052.jpg 20190223_140810.jpg 20190223_145828.jpg . Now just to get it home and put my mig on top. Hopefully next werk my tube bender should be here.:dancingbacon:
  10. Feb 24, 2019 at 6:05 PM
    #210
    suppra87
    suppra87 Well-Known Member
    Tim
    MD
    15' Black DCSB TRD OR
    Nice welder and custom welding cart! Doesn't matter if you're a Novice or Professional, new welder = build a welding cart for your new toy.
  11. Feb 24, 2019 at 6:08 PM
    #211
    desertrunner24
    Jake
    Fresno , CA
    Some
    Yeah I just cant justify buying a welding cart for 150 +/-. When you can throw some scrap steel together and make one that accommodates all your needs.
    Edit: thank you @suppra87
    PzTank and Crodell6 like this.
  12. Feb 24, 2019 at 6:35 PM
    #212
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    You can also get little clear sticky plastic (bi-focal) lenses that you can apply right to your safety glasses. I'll post, if I can find them again.
  13. Feb 24, 2019 at 6:38 PM
    #213
    Tacorific
    NE Iowa
    https://smile.amazon.com/gp/slredirect/picassoRedirect.html/ref=pa_sp_atf_aps_sr_pg1_1?ie=UTF8&adId=A07828182GMEB3BPGO8RT&url=https%3A%2F%2Fsmile.amazon.com%2FHydrotac-Magnifying-Magnifier-Koala-Magnification%2Fdp%2FB06X9LWCSS%2Fref%3Dsr_1_1_a_it%3Fie%3DUTF8&qid=1551062246&sr=8-1-spons&keywords=bifocal+sticky&psc=1&qualifier=1551062246&id=2123877061617498&widgetName=sp_atf
    OPTX 20/20 Hydrotac Stick-On Bifocal Lenses | Magnifying Adhesive Reading Lens Sticker | Sunglass Magnifier Add On | 1 Pair | Bundle with Koala Glasses Cloth & Case,...
    by Koala Lifestyle
    4.0 out of 5 stars 516 customer reviews
    | 44 answered questions
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    • [​IMG]
    About the product
    • 3 ITEM BUNDLE: Includes 1 Pair (2 lenses) Hydrotac Stick On Lenses (sealed in plastic carrying case), 1 Koala Kloth Microfiber Cleaning Cloth, and 1 Koala Kase Soft Vinyl Eyeglass Case
    • LIKE MAGIC: Hydrotac stick-on lenses convert any eyewear into magnifying reader bifocal glasses | Just peel, press on, and stick | Superior, no bubble, distortion-free, optical grade clarity
    • EASY & LONG LASTING: 1.2 inch diameter | Removable, reusable, and can be trimmed to size with sharp scissors and positioned anywhere on inside or outside of lens | Just add water and adhere
    • MANY USES: Great magnifier to add to eye wear like your sunglasses, safety glasses, sports, cycling, and shooting glasses
    • KOALA PROMISE: We only sell great products. If you're not 100% satisfied, contact us for a full refund.
  14. Feb 24, 2019 at 6:48 PM
    #214
    Tacorific
    NE Iowa
    Several years ago I got a sample pack if Heat Shrink Tubing. I got a bunch of samples from about 0.5" to 1.5" I shrunk it onto the outside of my sockets and my air chucks. Works like a charm. Takes paint marker well too.
  15. Feb 24, 2019 at 6:48 PM
    #215
    mwrohde
    Sugar Hill, GA
    Ordered. Thank you. Until I get cataracts and they replace my real lenses I'm stuck with solutions like this.
  16. Feb 24, 2019 at 7:08 PM
    #216
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    That’s a good idea.
  17. Feb 24, 2019 at 7:10 PM
    #217
    koditten
    Kirk
    Central Michigan
    That's a great idea as long as that HS tubing is free. It's stupid expensive if you have to buy it.
    Tacorific[QUOTED] likes this.
  18. Feb 25, 2019 at 2:35 AM
    #218
    Tacorific
    NE Iowa
    SummitLink 415 Pcs Black Assorted Heat Shrink Tube 10 Sizes Tubing Wrap Sleeve Set Combo
    by SummitLink
    • 415 Pcs Black Assorted Heat Shrink Tube 10 Sizes Tubing Wrap Sleeve Set Combo
    • Sizes: 1mm, 2mm, 3mm, 4mm, 6mm, 8mm, 10mm, 14mm,20mm,30mm
    • Covers all gauges of wires you'll need in RC hobbies and many other applications.
    $7.99
    Free Shipping for Prime Members
    PzTank and T4RFTMFW[OP] like this.
  19. Feb 25, 2019 at 2:49 AM
    #219
    Tacorific
    NE Iowa
    Mr. Heater Big Maxx Natural Gas Garage/Workshop Unit Heater — 50,000 BTU, LP Conversion Kit, Model# F260550
    Northern Tool
    Sale $399.99
    Order today to guarantee this price
    Save $100.00
    • Power exhaust allows for vertical or horizontal venting
    • Designed for right or left side piping, electrical and flue connections by simply rotating 180°
    • Tubular heat exchanger and spark ignition 3 Amp draw
    • Horizontal venting kit, Item# 29794, and vertical venting kit sold separately
    • Thermostat sold separately — Item# 173641
    ejl923[QUOTED] likes this.
  20. Feb 25, 2019 at 2:24 PM
    #220
    scocar
    scocar hypotenoper
    OP I just zoomed out from your toolbox pic
