Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Sep 7, 2020 at 2:30 PM
    #2281
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    What's the difference between oiled and oil less air compressor?
    Which one is better?
  2. Sep 7, 2020 at 2:31 PM
    #2282
    Venom
    Kevin
    Massachusetts
    Is it 220V ?
  3. Sep 7, 2020 at 2:54 PM
    #2283
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    it’s wired 120vac, I haven’t looked to see if it has the option on the motor to allow 220vac
    Venom[QUOTED] likes this.
  4. Sep 7, 2020 at 2:56 PM
    #2284
    Venom
    Kevin
    Massachusetts
    Will it work with any household 110V, 15 Amp?
  5. Sep 7, 2020 at 2:57 PM
    #2285
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Typically oil-less are loud and lower duty.
    G.T. and Venom[QUOTED] like this.
  6. Sep 7, 2020 at 2:58 PM
    #2286
    Blkvoodoo
    Kevin
    Near Clayton NC
    Yes, I’d be leery running on an extension cord though, unless it was sized appropriately
  7. Sep 7, 2020 at 2:59 PM
    #2287
    Venom
    Kevin
    Massachusetts
    Then would a oiled be better using it in a house, due to noise level?
    mallege likes this.
  8. Sep 7, 2020 at 3:01 PM
    #2288
    mallege
    mallege Well-Known Member
    George
    SW Idaho
    2019 Tacoma SR Gray SB Auto V6
    Extang tonneau cover, variable speed wiper stalk, hood struts, ScangaugeII.
    Yes, noticeably quieter and cooler running.
    Venom likes this.
  9. Sep 7, 2020 at 3:05 PM
    #2289
    Venom
    Kevin
    Massachusetts
    My friend had a Craftsman compressor on a dedicated 15A outlet. It would trip the circuit constantly. I believe it was a 25 to 30 gallons unit.
  10. Sep 7, 2020 at 3:05 PM
    #2290
    Blkvoodoo
    Kevin
    Near Clayton NC
    oil lube compressors tend to recover faster as well (most are at least twin cyl) so the noise they do make isn’t as long lasting when they cycle.
  11. Sep 7, 2020 at 3:09 PM
    #2291
    Venom
    Kevin
    Massachusetts
    Do you have to add oil to the compressor or are they oil filled but sealed?
  12. Sep 7, 2020 at 3:12 PM
    #2292
    Blkvoodoo
    Kevin
    Near Clayton NC
    just because the outlet had a 15a breaker and outlet doesn’t mean the wiring behind it could support the load. 15a outlet on opposite end of house from panel with 14ga wire run isn’t going to support a 15a device well. Just like a 50ft 14 ga extension cord will also fail.
    Is why when friends and myself were looking for homes I specifically watched for where the power panel was placed. If it’s on the opposite end of the house from the garage or even driveway, you’re gonna have power issues in most places when trying to power big tools in the garage or driveway.
  13. Sep 7, 2020 at 3:16 PM
    #2293
    Blkvoodoo
    Kevin
    Near Clayton NC
    Oil is a service item just like a car, not as often, but it needs to be monitored and changed. Not hard, but yes, it can get messy...
    The Oil lube compressor (Power by gas engine) is 14 years old, oil In pump has been changed once, and it doesn’t seem to loose oil at all.
  14. Sep 7, 2020 at 3:16 PM
    #2294
    Venom
    Kevin
    Massachusetts
    This explain why he was having issues. The garage is detached from the house.
  15. Sep 7, 2020 at 3:21 PM
    #2295
    Venom
    Kevin
    Massachusetts
    Does oil changes goes by hours or monthly interval?
  16. Sep 7, 2020 at 3:22 PM
    #2296
    Blkvoodoo
    Kevin
    Near Clayton NC
    most houses aren’t built with the idea that someone will actually USE the garage as a shop, you want that you specify when you build what you want and pay accordingly. Some houses are able to be upgraded for shop service easily others, not so much.
    I do not have a garage, I have a 16x16 shed that I work out of, I wired the shed and the sent power from house to shed buried under ground across the yard. I have the ability to have 220 in the shed, but split it out into separate 110 circuits to allow other options. Compressor and plasma cutter have their own circuits separate from each other and I have to be selective at I have on when using the plasma.
    Venom[QUOTED] and PzTank like this.
  17. Sep 7, 2020 at 3:26 PM
    #2297
    Blkvoodoo
    Kevin
    Near Clayton NC
    Hours usually, but most don’t have hour meters on them, mine does not. I’ve consider adding one but haven’t got that far. Honestly, most compressors rarely get the oil changed On any regular schedule if ever.
  18. Sep 7, 2020 at 3:27 PM
    #2298
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    More like yearly. There is no carbon coming from the cylinders so the oil stays clean for a very long time.
    Venom[QUOTED] and Blkvoodoo like this.
  19. Sep 7, 2020 at 3:28 PM
    #2299
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    One thing. Oil sealed air compressors will always put some oil into the air. Okay for some tools. But it can effect paint guns if not maintained properly.
    Also, a poorly maintained compressor can put more oil into tires than is good for them.
    If you use an oil sealed compressor make sure you put a coalescing filter on the outlet.
    Gunshot-6A, Venom and 2008taco like this.
  20. Sep 7, 2020 at 3:35 PM
    #2300
    Venom
    Kevin
    Massachusetts
    He built the garage and wired it to accept high draw equipment. I don't know what happen. I used to watch the outside lights dimmed and flickers as the compressor kick on.
    I had a electric upgrade done. The main is on a 200A breaker. I had a few 20A breaker installed in the basement.
    Since I have no shed or garage the compressor would be in the basement. Hopefully I won't have any issues.
