Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Dec 10, 2020 at 1:42 PM
    #3101
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Can confirm. I've used mine so many times, thankfully never on my truck, but a group 31 makes that pretty much a non issue. So much better than dragging the cables out and potentially blowing fuses every which way
    2008taco and deekyn[QUOTED] like this.
  2. Dec 10, 2020 at 2:17 PM
    #3102
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
  3. Dec 10, 2020 at 2:56 PM
    #3103
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I have 2ah and 6ah batteries. I tried both and the power output is definitely lower on the 2ah. So I'll be buying a few more 6ah.
  4. Dec 10, 2020 at 4:01 PM
    #3104
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    Ok, you got me on this one. What is it and what does it do?
    Drainbung and Blkvoodoo[QUOTED] like this.
  5. Dec 10, 2020 at 4:10 PM
    #3105
    Blkvoodoo
    Kevin
    Near Clayton NC
    the wire in center is solder, the wheel moves the solder in and out, the uprights are spring loaded grips....
    Drainbung and CXYyuppie[QUOTED] like this.
  6. Dec 10, 2020 at 4:29 PM
    #3106
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    hold the wires and apply solder with one hand and hold the iron in the other
    personally I think I'll wait for the HF knock-off
  7. Dec 10, 2020 at 4:34 PM
    #3107
    CXYyuppie
    Craig
    SE.LA
    My soldering skills are poor. I just don't do it that often. I could have used this many of times.
    Blkvoodoo[QUOTED] likes this.
  8. Dec 10, 2020 at 4:35 PM
    #3108
    Blkvoodoo
    Kevin
    Near Clayton NC
    Matco guy told me to buy solder elsewhere, that $9 cost is for the bit you see in the handle on the demo. its not "special" just needed to be certain size to work well 2.5mm or something like that.
    CXYyuppie and Drainbung like this.
  9. Dec 10, 2020 at 4:35 PM
    #3109
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Agreed, but that's pretty steep unless you're doing a lot of soldering.
    CXYyuppie[QUOTED] and Blkvoodoo like this.
  10. Dec 10, 2020 at 4:36 PM
    #3110
    CXYyuppie
    Craig
    SE.LA
    It's only money. HaHa.
    2008taco and Drainbung[QUOTED] like this.
  11. Dec 10, 2020 at 4:36 PM
    #3111
    Blkvoodoo
    Kevin
    Near Clayton NC
    I wouldn't say I do " a lot " but enough in awkward positions that this was worth the cost.
    Drainbung[QUOTED] and CXYyuppie like this.
  12. Dec 10, 2020 at 4:38 PM
    #3112
    CXYyuppie
    Craig
    SE.LA
    Like under the dash of a truck or in a bad spot on a forklift, huh
    Drainbung likes this.
  13. Dec 10, 2020 at 4:43 PM
    #3113
    Blkvoodoo
    Kevin
    Near Clayton NC
    yes on both counts, I may even get to use it tomorrow installing impact monitors on a pair of forklifts.
    CXYyuppie[QUOTED] and Drainbung like this.
  14. Dec 10, 2020 at 5:34 PM
    #3114
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    No, you tell tell them to take it off so you can bench solder it, or nothing at all. If your boss find out he can get you to do the shit jobs, he'll expect it more and more.
  15. Dec 10, 2020 at 5:45 PM
    #3115
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Im a dealer tech and I bought that cause I thought I would use it a lot since I dont have a 3/8 drive electric ratchet but I hardly ever use it, granted I already have 2554-20 & 2456-20 for tight spaces, I might have to just buy the 2557-20.
    I will say its a very powerful tool but at least for me the head has been to big to be much use.
    Its great Ive had mine over a year now and I use it every single day, Ive got 2554-20 which is what you said you want, I primarily leave a XC 3.0 or 4.0 in it but if its a tight squeeze I will use the smaller 2.0 battery and itll be fine.
    If I was lost all my tools this would defiantly be one that I would buy right away again.
  16. Dec 10, 2020 at 6:03 PM
    #3116
    Blkvoodoo
    Kevin
    Near Clayton NC
    and here we are.....now you know why I get to install the impact monitors
    below is how you tap into a factory wiring harness to get inputs for a monitoring device and NOT void factory warranty for tapping into factory wiring harness.....
    I did this, and 2 months later I had to claim warranty on the hydraulics, the manufacturer field rep showed up the next morning to inspect, for 3 hours before we finally dove into the hydraulics issue... and then he bought me lunch.
    Top is three jumper harnesses made to tap specific circuits
    Middle pic is the harness I needed to tap
    bottom pic is ignition harness and and oil pressure tap along with the 8pin control everything was duplicated 3x, 1ea for 3 machines. white wires with black box is a diode pack input from 2 sources into one feed, both sources will never be on at same time (direction control)
    27D9A0CC-82B2-4A6E-AD7A-E02D3F46CA13.jpg F1B82779-BED2-4FEA-A010-69DFBE149C5A.jpg
  17. Dec 10, 2020 at 7:57 PM
    #3117
    [TACOMA]
    [TACOMA] Well-Known Member
    SoCal
    '17 DCLB Sport in QS
    Home Depot usually has deals on these with 3ah Xc batteries, is the 3 enough for most task? Thinking that or bare tool and a 6.0 batt. Kinda want the smallest/ lightest combo. I have an old 1/2 IR for the stubborn stuff. Cali residance so no Rust issues. :cool:
  18. Dec 11, 2020 at 8:45 PM
    #3118
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Anybody planning to take advantage of Christmas sales and add some garage inventory?
  19. Dec 11, 2020 at 9:04 PM
    #3119
    mjbtaco
    Michael
    Montclair , so cal
    I ordered a cheap 3/8 drive tekton torque wrench. I was super close to getting an ac/dc tig but the wife shut that down real quick lol
    T4RFTMFW[QUOTED][OP] likes this.
  20. Dec 12, 2020 at 1:58 AM
    #3120
    joeyv141
    New Jersey
    Yeah the 3xc is definitely enough I may have to recharge my 12v batteries once or twice a week, I if I were using it all day to take lug nuts and other large stuff off the battery would run down quicker but I usually keep them to 18mm or smaller.
    I dont see myself buying any bigger then a 4xc, I guess if I had any of the saws or sds hammers I might buy the 6xc but being a mechanic I don't see that in my future, I have a 18v 9hd for my recip and circular saw cause they will eat up smaller batteries real quick.
    Also you can get batteries on ebay for cheep cheep, I bought a pack of 2 3.0xc for like $40 or $50, just make sure its actually Milwaukee in the retail packaging and not a knockoff.
