Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Dec 12, 2020 at 6:10 AM
    #3121
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    mjbtaco, Pablo8 and LarryDangerfield like this.
  2. Dec 12, 2020 at 10:33 AM
    #3122
    RichVT
    Rich
    Northern Vermont
    Here are some pictures of a home made socket organizer that I made probably 25 years ago (back when I had more time than money). Base is a scrap of 1/4" plywood painted white. Pegs are dowel pins (cut in half) inserted and glued into drilled holes in the base and the labels are cut from a socket label set.
    Sockets are easy to install and remove and stay in place. It's easy to find the right size socket because everything is labeled. It's easy to see at a glance if any sockets are missing at the end of a job because every space is filled.
    Unlike commercial setups, the are no extra spaces that I don't have sockets for, I don't have sockets that don't have a place and there is no wasted space between sockets. And it's dirt cheap to make and can be added to when your collection grows. I just cleaned it up and added another row for some new sockets that I got.
    Jeff Dartfrog, mtip, Grumpy and 13 others like this.
  3. Dec 12, 2020 at 5:05 PM
    #3123
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I noticed this big time with my stubby impact. It couldn't remove the lugnuts on my car that were torqued to 85 ftlbs with the 2ah battery but it was able to remove suspension bolts that were torqued to 145 ftlbs no problem with the 6ah battery.
    LarryDangerfield likes this.
  4. Dec 12, 2020 at 5:57 PM
    #3124
    mjbtaco
    Michael
    Montclair , so cal
    Tekton 3/8" drive torque wrench came in.
    mtip, rob1208, SoCal_Erik and 10 others like this.
  5. Dec 12, 2020 at 6:03 PM
    #3125
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have the 1/2” and I like it a lot. It’s big af and it’s nice having the increased leverage.
  6. Dec 12, 2020 at 6:20 PM
    #3126
    Taco? Who knows
    Taco? Who knows Well-Known Member
    New England
    2009 DCSB Off Road
    x2 on the 1/2
    x2 on the 1/2, I have used one for several years now and boutght one for my son.
    T4RFTMFW[OP] and mjbtaco like this.
  7. Dec 12, 2020 at 6:30 PM
    #3127
    mjbtaco
    Michael
    Montclair , so cal
    Nice! I have a craftsman 1/2" with digital read out that I bought from sears in 2017. I've had my eye on 3/8" drives for a while, I've needed it a few times so I pulled the trigger on this one.
    Edit: took a pic of the 1/2" craftsman
  8. Dec 12, 2020 at 7:48 PM
    #3128
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Really happy with my Tekton stuff so far. Keep us posted with any other Tekton stuff you guys end up with.
  9. Dec 12, 2020 at 8:21 PM
    #3129
    mjbtaco
    Michael
    Montclair , so cal
    I love all my Tekton stuff. Only some of the extensions and chrome sockets in the foam are tekton.
    Maxcustody, Grumpy, Tacman19 and 5 others like this.
  10. Dec 12, 2020 at 8:58 PM
    #3130
    T4RFTMFW
    Any issues with their impact bits?
  11. Dec 12, 2020 at 9:10 PM
    #3131
    6 gearT444E
    Deep South
    Herculiner Hootus
    their u joint swivel sockets did not work well for me. The splined pin got loose and sent the joint flight across my shop one day. I got the impact rated one but obviously it’s not up to par for the task. I have since switched to a ball joint style swivel socket and am much happier.
  12. Dec 12, 2020 at 9:16 PM
    #3132
    mjbtaco
    Michael
    Montclair , so cal
    I've had the impact socket sets for a few years. No issues at all.
  13. Dec 12, 2020 at 9:24 PM
    #3133
    T4RFTMFW
    No the impact bits for the driver here.
  14. Dec 12, 2020 at 10:09 PM
    #3134
    mjbtaco
    Michael
    Montclair , so cal
    Oh lol I've used them a few times while doing break jobs. No issues.
  15. Dec 13, 2020 at 6:17 AM
    #3135
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I have a Genius 2D that I mounted under the seat on my ATV. It doesn't get the garage space in the winter, so I figured leaving the battery plugged in helps ensure it always starts when I need to clear snow.
    Might have to pick up one of these. It would take up less space than the jumper cables I keep in my truck.
  16. Dec 13, 2020 at 12:33 PM
    #3136
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    They still make those hammer powered impact drivers! Just proves somethings are to good to be phased out.
  17. Dec 13, 2020 at 12:37 PM
    #3137
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    I actually just bought one yesterday at HF. $8.99 then I had a 25% off my entire purchase no restrictions so it ended up being $6.75. (Uncle works for HF and it's some family deal he sends me a couple times a year :D) I have a couple old Honda's that use JIS screws, impacts help get those out with out stripping the heads.
    Drainbung likes this.
  18. Dec 13, 2020 at 1:03 PM
    #3138
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I've got 4 battery impact wrenches and 2 air impact wrenches but damn if there's nothing better then a hand impact driver to loosen a rusty rotor bolt.
    757 Taco, 6 gearT444E and Drainbung like this.
  19. Dec 13, 2020 at 3:30 PM
    #3139
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Anybody in here have any experience with the Rapidair Maxline brand of compressed air hoses and fittings for stationary shop set up ?
    specifically looking at the 1/2" Maxline kit
    Sorry / not sorry for the thread jack OP
  20. Dec 13, 2020 at 3:43 PM
    #3140
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    IN a and rotate is sometimes better than just a shocking rotate. I need to replace mine, I loaned it out, and of course they broke the #3 Phillips bit and some how managed to mushroom the end. Damn gorillas !
