Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Dec 13, 2020 at 4:17 PM
    #3141
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I know a couple guys/friends who have them. No real complaints from them other than it can be annoying if you need more fittings since you (generally) cant just run out and get them. Will say the three setups i can think of two look meh (wavy lines) while one buddy spent time straightening it all out to look good.
    Copper lines are still my favorite look for lines a person will see. Rapidaire can be run in walls to hide things
  2. Dec 13, 2020 at 4:23 PM
    #3142
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    yeah , I'm planning to run a portion in the wall and some surface mounted but hidden , looks like a simple system to install whereas with copper I'm not confident enough with my soldering to bury it in a wall
  3. Dec 13, 2020 at 4:30 PM
    #3143
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    That’s what we’re here for, neighbor.
  4. Dec 14, 2020 at 9:03 AM
    #3144
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Yeah its a pretty simple system. Pretty much the only thing to consider is making cuts straight, burr free....pretty normal stuff. Itll definitely install quicker than copper (and be a bit easier to work with...like pex). I only started learning to solder and have to say its pretty easy to pick up with a good torch. Obviously ~50psi of water (on a well) isnt quite the same as ~100-150 psi of air but havent had any leaks so far!
    If i were made of money I'd have gone Pro Press
  5. Dec 14, 2020 at 9:22 AM
    #3145
    6 gearT444E
    Deep South
    Herculiner Hootus
    you could always chance it on the soldering and do a pressure test :) I think with the price of copper you'll find that it's not the cheapest solution but one of the cleanest IMO.
  6. Dec 14, 2020 at 5:34 PM
    #3146
    cynicalrider
    cynicalrider #NFG
    Jersey
    I need to pick one of these up. I used one once on a dirt bike motor at a friends house and always wanted to snag one for my shop.
  7. Dec 15, 2020 at 12:00 AM
    #3147
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Got some low profile ramps for the daily and the 5 lug Tacoma.
  8. Dec 15, 2020 at 5:46 AM
    #3148
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    If I would have held on to my Miata longer I would have gotten some of those. As it was I had to use the factory jack to get it high enough for my regular jack.
    mjbtaco[QUOTED] likes this.
  9. Dec 15, 2020 at 6:18 AM
    #3149
    mjbtaco
    Michael
    Montclair , so cal
    yeah figured i'd make it easy for myself and find some ramps lol.
  10. Dec 15, 2020 at 6:38 AM
    #3150
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Those look nice. I didn't see those back in 2014 when I bought Race Ramps for the WRX. I had to get a second mortgage. For the ramps.
  11. Dec 15, 2020 at 6:51 AM
    #3151
    mjbtaco
    Michael
    Montclair , so cal
    lol damn. These were $50 on Amazon
  12. Dec 16, 2020 at 8:13 AM
    #3152
    G.T.
    G.T.
    CONUS
  13. Dec 16, 2020 at 8:16 AM
    #3153
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Promote ahead of peers. :rofl:
    Drainbung likes this.
  14. Dec 16, 2020 at 9:23 AM
    #3154
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Good luck, keeping him.
  15. Dec 16, 2020 at 1:50 PM
    #3155
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    NTD; giving them a whirl as I'm fully aware Knipex is the way. These are replacing my toothless (once had teeth) Huskies..
  16. Dec 16, 2020 at 1:56 PM
    #3156
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I was sadly disappointed in those, they ARE NOT the same as Knipex And very cumbersome to use in comparison.
    geekhouse23[QUOTED] likes this.
  17. Dec 16, 2020 at 2:10 PM
    #3157
    geekhouse23
    I kinda went full send the last month and wanted new channel locks; these were inexpensive and gave them a shot. I'll see. Just couldn't invest in the Knipex at this point in time.
  18. Dec 16, 2020 at 3:04 PM
    #3158
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What’s the purpose of the thing on the ends of the handles?
  19. Dec 16, 2020 at 3:41 PM
    #3159
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Tooth picks
  20. Dec 16, 2020 at 4:18 PM
    #3160
    Blkvoodoo
    Kevin
    Near Clayton NC
    I have had Knipex Cobras 8” and 10” for years, and a pair of the 10” Alligators, I prefer the Cobras, I carry the 8” in my pocket often.
    I bought the Milwaukee pair because the were cheap and I needed something now, I was disappointed, they don’t grab like the Cobras do.
