Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Dec 16, 2020 at 5:16 PM
    #3161
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Anyone using one of the cheap-er digital inflators from Amazon? Like this style where you can use a quick connect with it? Or have a recommendation for one that isn't >$100?
    I was airing up some motorcycle tires today and realized how less-than-ideal my set up is. Right angle adapter, clip on analog gauge w/ an inflation pass through, then using one of the double sided inflators into that. Kind of annoying to use.
  2. Dec 16, 2020 at 5:19 PM
    #3162
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    I have the jaco and just got another version from Amazon’s twss.
    My complaint with the jaco is the button has gotten super hard to push and the valve leaks
    spencermarkd[QUOTED] likes this.
  3. Dec 16, 2020 at 5:21 PM
    #3163
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’ve gone through three cheaper gauges like that, all different brands, all failed for different reasons. All around the $35 mark. I now have a powertank inflator that’s around $80 and let me tell you, it is well worth the money.
    https://powertank.com/collections/tire-inflator-with-gauge
  4. Dec 16, 2020 at 5:31 PM
    #3164
    spencermarkd
    Spencer
    I was looking at that one, their rotating valve seemed kind of novel
    That one looks the business. I like that the valve is re-buildable, too. That might be the ticket, thanks for sharing :thumbsup:
  5. Dec 16, 2020 at 5:50 PM
    #3165
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They’re a quality American business and really care about preserving land and the wheeling/camping scene. Top notch customer service too. 10/10 would recommend.
  6. Dec 16, 2020 at 5:58 PM
    #3166
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I have a Power Tank inflator TIG -8200 that i bought for $73 a few years back. Super nice quality tool.
    Would buy another in a heartbeat. Makes inflating tires a breeze.
    spencermarkd and EatSleepTacos like this.
  7. Dec 16, 2020 at 6:00 PM
    #3167
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  8. Dec 16, 2020 at 6:22 PM
    #3168
    spencermarkd
    Spencer
  9. Dec 16, 2020 at 6:28 PM
    #3169
    Rockslide
    Rockslide Well-Known Member
    2019 Cement Tacoma Off Road
    Electrical work I would assume. The knockouts in junctions boxes and panels come to mind when i look at those...
  10. Dec 16, 2020 at 7:17 PM
    #3170
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Check out RHINO USA. I bought a gauge like this from their site.
  11. Dec 16, 2020 at 7:48 PM
    #3171
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Astro Pneumatic.
    spencermarkd likes this.
  12. Dec 16, 2020 at 8:50 PM
    #3172
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    What’s a good jack to get? I always bought craftsman before.
  13. Dec 16, 2020 at 8:56 PM
    #3173
    6 gearT444E
    Deep South
    Herculiner Hootus
    cant go wrong with the HF ones. I’ve got a 3 ton Pittsburg and a 4 ton Daytona. Next purchase will probably be a long reach or aluminum one. They are cheap enough if you get them with a coupon.
    Gunshot-6A and LarryDangerfield like this.
  14. Dec 16, 2020 at 9:39 PM
    #3174
    MARSHBUSTER
    Jim
    Alamogordo NM
    Daytona from Harbor Freight.
  15. Dec 17, 2020 at 5:53 AM
    #3175
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I have the Astro gauge but I didn't like the clip on chuck that it came with it so I got a different chuck from Amazon.
    T4RFTMFW[QUOTED][OP] likes this.
  16. Dec 17, 2020 at 5:57 AM
    #3176
    RichVT
    Rich
    Northern Vermont
    Pay attention to the max lift height in the specs. On some jacks (low profile) you'll use half their travel before you even contact the bottom of the truck and then you'll only be able to raise the truck a few inches.
    Gunshot-6A likes this.
  17. Dec 17, 2020 at 7:10 AM
    #3177
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Yes, but if your truck is lifted as high as it is supposed to be you shouldn't even need a jack.
    Drainbung likes this.
  18. Dec 17, 2020 at 7:12 AM
    #3178
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Yeah man, your truck should be lifted high enough where your wheels can just pop off with magic.
  19. Dec 17, 2020 at 7:15 AM
    #3179
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    That's what wheel spacers are for :stirthepot: :D
    Jeff Dartfrog, la0d0g and 2008taco like this.
  20. Dec 17, 2020 at 7:16 AM
    #3180
    rageman
    rageman Well-Known Member
    Keith
    2018 Barcelona Red Tacoma TRD Off-Road
    I only have 3/4 of my garage available. I have a cast clawfoot tub and tile, mortar, and fixtures for a bathroom taking up the other side at the moment.
    Grumpy, la0d0g, markram and 2 others like this.
