Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Apr 11, 2019 at 5:20 PM
    #321
    G.T.
    G.T.
    CONUS
    Carbon fiber is a conductor mate, likely a similar finish.
    T4RFTMFW[QUOTED][OP] likes this.
  2. Apr 11, 2019 at 5:42 PM
    #322
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    G.T. likes this.
  3. Apr 16, 2019 at 12:55 PM
    #323
    scocar
    scocar Patron of the Farts
  4. Apr 25, 2019 at 2:38 PM
    #324
    T4RFTMFW
    So.. I called Snap On for shits and giggles to see what kind of warranty I had on my screwdriver shaft. Since I first used it I noticed the bits are fairly difficult to remove. Yesterday I had a different bit installed and it was practically fucking stuck.
    Was able to get it out with some Channel Locks, but looked into the tip and noticed some of the metal seems rolled over in spots and uneven thicknesses on the 6 sides. Put a bit in today, and it’s fucking jammed in there again.
    2 minutes on the phone with the incredible nice customer service agent at the corporate mothership and they’re sending me a new shaft. $55 part!
    I’m super happy. I’ve heard hits and misses with SO, and it may be founded.. but this is the second time I’ve dealt with corporate directly and both times have exceeded expectations.
  5. Apr 25, 2019 at 2:49 PM
    #325
    G.T.
    G.T.
    CONUS
    I’ve found that more often than not the attitude of the one in need has a great deal to do with allot of situations. I call knowing it’s not the fault of the person going to speak with so I don’t take my frustrations out on them. I’ve been able to exchange many non-warrantied items by just being polite to the one that I’m interacting with.
    mtip, Gunshot-6A, la0d0g and 7 others like this.
  6. Apr 25, 2019 at 11:23 PM
    #326
    scocar
    I seem to recall mine being tight as a goddamn 12 yo when I first got it. But with experience, it came to understand the give and take required to develop a loving relationship.
    God that's fucked up.
  7. Apr 25, 2019 at 11:40 PM
    #327
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You do know the tools are meant to be used on machinery, not yourself right?
    and you're not 12 yrs old anymore might have something to do with it.
    Gunshot-6A and scocar[QUOTED] like this.
  8. Apr 26, 2019 at 8:47 AM
    #328
    G.T.
    G.T.
    CONUS
  9. Apr 26, 2019 at 9:36 AM
    #329
    scocar
    :anonymous:
  10. Apr 26, 2019 at 4:09 PM
    #330
    T4RFTMFW
    Good lord.
    Should’ve put the floor jack on top instead. What a noob.
    Jeff Dartfrog and Kolunatic like this.
  11. May 2, 2019 at 7:36 PM
    #331
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    505F8416-FCD0-420B-9F82-CA1F67340062.jpg 6DE58815-E500-40AF-8855-E50489C42C70.jpg
    Newest addition to the garage arsenal and I can't wait to use it!!
  12. May 7, 2019 at 6:46 AM
    #332
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Ahh my kind of thread. Recent acquisitions.
  13. May 7, 2019 at 7:41 PM
    #333
    T4RFTMFW
    Welcome duder! :cheers:
  14. May 7, 2019 at 7:51 PM
    #334
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Harbor freight has some but just do a Google or Amazon search and you should find plenty.
  15. May 7, 2019 at 11:26 PM
    #335
    mjbtaco
    Michael
    Montclair , so cal
    thanks! i tend to buy a lot of tools so i'll be posting some more lol
    Bigdaddy4760 likes this.
  16. May 8, 2019 at 1:53 PM
    #336
    mjbtaco
    Michael
    Montclair , so cal
    Some more tool pics I found on my phone lol
  17. May 9, 2019 at 8:15 PM
    #337
    T4RFTMFW
    Ordered the Snap On soft grip ratcheting stubby yesterday night direct off the SO website. Got shipping notification today, delivery Tuesday.
    Again.. I don’t know how things go wrong with their business dealings unless it’s bad truck owners.
    Also ordered the correct, shorter shaft my full size would normally come with. So in total for both, with the extra (brand new) non-con shaft I’m in $209 for the pair.
    2 thoughts come to mind.. first, what the fuck.
    Second.. no ragrets. Not a single one.
    mtip, scocar, mjbtaco and 1 other person like this.
  18. May 9, 2019 at 8:22 PM
    #338
    mjbtaco
    Michael
    Montclair , so cal
    Made a bunch of cuts today. Dickered a blade in the process but it still finished the job lol
    la0d0g and T4RFTMFW[OP] like this.
  19. May 9, 2019 at 8:56 PM
    #339
    scocar
    Well I've had mine for at least 25 years, never a hiccup, always my go-to driver. So look at it from a dollars per year perspective. The longer you have it, the cheaper it will get.
  20. May 9, 2019 at 9:01 PM
    #340
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    That's an outrageously blatant OSHA safety violation ……. no Safety Glasses.
