Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Jan 22, 2021 at 5:32 PM
    #3441
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Can confirm. Dude got falcon punched by a backkicked 2x4 off a tablesaw in my shop class. Totally deserved it, but man that looked bad.
    spencermarkd likes this.
  2. Jan 24, 2021 at 1:58 AM
    #3442
    la0d0g
    running for the hills
    For crawling not hauling
    Sweet garbage can! Way better than my HD bucket.
  3. Jan 24, 2021 at 7:29 AM
    #3443
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    Sold
    PzTank likes this.
  4. Jan 25, 2021 at 7:25 PM
    #3444
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Finally upgraded from a homemade wooden back and sides on my 40 inch snap on box to a 41 inch husky top box
    Its great having so much more room, not sure what tools I am gonna fill it with but Im sure I will figure it out.
    I am hoping my snap on dealer can figure out how to make a snap on lock work for the top box, I already did it for my sunex roll cart, really nice only having one key to lock everything.
    If anyone likes the top box this is it, its really nice, not snap on/mac quality but very good.
    Honestly if snap on offered a top box with the same setup as the husky I would pay snap on prices.
    Picture of my old set up
    New set up
    6 gearT444E, markram, G.T. and 6 others like this.
  5. Jan 27, 2021 at 8:54 PM
    #3445
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Electromagnetic grinding pad is basically done. Just need to do some finishing work.
    mtip, markram, Pablo8 and 4 others like this.
  6. Jan 28, 2021 at 4:36 AM
    #3446
    joeyv141
    New Jersey
    Wouldnt the magnet keep the shavings as you are grinding from being blown out the way, will a blow gun be enough to remove the shavings?
  7. Jan 28, 2021 at 4:38 AM
    #3447
    mjbtaco
    Michael
    Montclair , so cal
    Clean up will be easy when its off. Also it wont be for heavy grinding, just clean up of flat parts i sell.
    Pablo8 likes this.
  8. Jan 28, 2021 at 5:23 AM
    #3448
    joeyv141
    New Jersey
    Ok, no heavy grinding
  9. Jan 28, 2021 at 8:59 PM
    #3449
    mjbtaco
    Michael
    Montclair , so cal
    So this was an unexpected purchase today
    mtip, Shayne, Tacman19 and 8 others like this.
  10. Jan 28, 2021 at 9:09 PM
    #3450
    mjbtaco
    Michael
    Montclair , so cal
  11. Jan 29, 2021 at 4:40 AM
    #3451
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    mjbtaco[QUOTED] likes this.
  12. Jan 29, 2021 at 8:56 AM
    #3452
    mjbtaco
    Michael
    Montclair , so cal
    Thanks! Its a 350lb magnet I've tried pulling it up but I can't. As long as the piece is flat and makes solid contact with it its pretty much stuck.
  13. Jan 29, 2021 at 9:53 AM
    #3453
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    Curious what happened to the Harbor Freight Titanium unit......
  14. Jan 29, 2021 at 10:15 AM
    #3454
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Ordered more Tekton sockets. 1/2” deep 6 points standard and 1/2” shallow 6 point standard and metric.
    mtip, rob1208, buyobuyo and 2 others like this.
  15. Jan 29, 2021 at 10:50 AM
    #3455
    mjbtaco
    Michael
    Montclair , so cal
    Wasn't a harbor freight welder, it was an Everlast machine. The gas solenoid stopped working. I looked at the warranty and its one of those where you pay to send it over and they determine if they will fix it then you pay to have it sent back to you . I didn't like that so I replaced it. I had a $500 lowes gift card so I bought the Lincoln with a lowes warranty. So now if I have any issues I just take it down to lowes and get a new one. I'm going to fix the everlast and sell it.
    Shayne likes this.
  16. Jan 29, 2021 at 2:49 PM
    #3456
    zimmmtaco
    Northwestern PA
    Thanks for the follow up... i am thinking about upgrading from my 3200hd Lincoln to a Harbor Freight Titanium 200, and the green color caught my eye....
  17. Feb 1, 2021 at 3:00 PM
    #3457
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Any electricians?
    I want to run 200 amp service to an external garage. Note I won't be doing the work, but want to know what I'm talking about when contacting an electrician.
    Can I run 200 amp service as a subpanel off the main panel, can I run it off the meter on the side of the house, or should I run it off the pole.
    I'm new to this, and like I said just want to have a little know how when talking to the electrician.
  18. Feb 1, 2021 at 3:06 PM
    #3458
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Most homes max out at 200 amp service
    If you need 200 amps just for this building you're looking at a second service from the pole
  19. Feb 1, 2021 at 3:14 PM
    #3459
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    What he ^^^ said but having two meters is not a bad thing. I have a separate meter on my house and on my shop. 200 amp panel on each. The kilowatt charge is the same for each. If you ever go into business for yourself, the separate meter would make it easier to dedicate to the business for tax purposes.
  20. Feb 1, 2021 at 4:09 PM
    #3460
    whitedlite
    USA!
    3RD Gen TRD 4WD
    That separate meter for business expenses is a great reason, plus I just talked to some people who’s opinion I trust he said go ahead and pay for it.
    Out in the garage welding or cutting metal and accidentally overheating the panel in the house isn’t worth it, plus if I ever want to sell and inspector sees something done wrong the money saved isn’t worth it.
    biggest reason to hire the meter install is liability. I’ll do the wiring inside, but let someone else handle pole to garage.
    thanks everyone. I’ll get 3 quotes soon.
    Hardscrabble and Ccwahoo like this.
