Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Feb 3, 2021 at 5:09 PM
    #3481
    G.T.
    G.T.
    CONUS
    This is the depth in most states.
    CXYyuppie[QUOTED] likes this.
  2. Feb 3, 2021 at 5:11 PM
    #3482
    CXYyuppie
    CXYyuppie Sarcasm Master
    Craig
    SE.LA
    2019 TRD Sport DCSB - Cement
    Stuff with some other black things
    I kind of thought so. Hell, if you dig much more than 36" in my area, you will hit water. :rofl:
  3. Feb 3, 2021 at 5:58 PM
    #3483
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    That new ratchet smell.
  4. Feb 3, 2021 at 6:04 PM
    #3484
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I've been wanting some extended flex head ratchets. I think I might get the tekton set.
    T4RFTMFW[QUOTED][OP] likes this.
  5. Feb 5, 2021 at 2:45 PM
    #3485
    ChuckTruck
    ChuckTruck Active Member
    Utah
    2017 Taco TRD
  6. Feb 5, 2021 at 4:44 PM
    #3486
    mjbtaco
    Michael
    Montclair , so cal
    Guess I'll be learning how to tig weld.
    Also upgraded the gun on my mig to this HTP flex head.
  7. Feb 5, 2021 at 5:11 PM
    #3487
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I have that ratchet and regularly use it at work, its very nice, especially for the price.
  8. Feb 5, 2021 at 6:30 PM
    #3488
    T4RFTMFW
    Let us know how you like them. I’m super happy with my Tekton stuff, but haven’t tried the ratchets.
    Wish it had a comfort grip to match my 1/4” and 3/8” 120XP ratchets but otherwise I love it. Minor complaint.
    I’ve been really happy with them all.
  9. Feb 5, 2021 at 7:16 PM
    #3489
    joeyv141
    New Jersey
    Comfort grips are nice and I've got three snap on with comfort grips, two of which I use everyday, but the issue I've run into is the handle is thicker and on rare occasions I cannot fit the comfort grip ratchet where a regular bare metal handle ratchet would fit.
    Tacman19 and T4RFTMFW[OP] like this.
  10. Feb 5, 2021 at 9:33 PM
    #3490
    6 gearT444E
    Deep South
    Herculiner Hootus
    I would always pick an underground service vs an overhead assuming the distance isn’t terribly far and you wouldn’t have to jack up a driveway or something. Do you have pad mount or pole mount service? It would be cheaper to rent a trencher and do the work up to the service yourself if adding a second meter. I ran a 100 amp direct buried triplex cable to my shop from my existing house panel. The cost was parts only and very doable. The electric company will always charge you an arm and a leg if they’re going to add a new service.
    Most meter sockets for residential are rated for 300 amps so to go to 400 amp you’d have to upgrade the meter socket to a 400 amp which can get pricey. You can run a 200 amp service off an existing 200 amp panel as long as the diversity factor calculation is performed correctly and the inspector is satisfied.
    2008taco likes this.
  11. Feb 7, 2021 at 7:09 AM
    #3491
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    My friends dad let me borrow his machete. It was super dull, had surface rust and some chips on the blade side. Unusable.
    The first pic was after a quick sanding to get rid of the surface rust. Got this bench sander and stared working. Second pic is just two passes on the sander. Youtube video is it finished.
    Its not perfect but man is it WAYYYY better. Now you can actually cut stuff with it. Also cleaned up the blade with a scotch brite pad and WD40. Worked out well. Happy to have this sander for other things that need to be sharpened. Axes, lawn mower blades, etc.
    https://www.youtube.com/watch?v=1FJ7kKw9I-g
    Pablo8 likes this.
  12. Feb 7, 2021 at 7:17 AM
    #3492
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Wow...............very nice. How much did the sander set you back at HF?
  13. Feb 7, 2021 at 7:25 AM
    #3493
    OffroadJet
    Sebastian, FL
    it was only $50. I bought 120 grit sandpaper belt also for another $4 or something (ill prob get other grits on Amazon). Sander comes with one 80 grit belt. Also bought the face shield. Im really happy with it. its super sturdy and comfortable.
    Pablo8[QUOTED], G.T. and SoCal_Erik like this.
  14. Feb 7, 2021 at 9:31 PM
    #3494
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Thanks - decent value
  15. Feb 9, 2021 at 2:39 PM
    #3495
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    well jus touching back on this after talking with many about the future sell of the house.
    The house build in 87 doesn't have a main disconnect. So I've decided to do the 400 amp service. I bought this meter socket, two of these 200 amp breakers, this 200 amp panel for the shop, I still need to order my 3 inch conduit, weatherhead.
    It's expensive, but once done it's done.
    6 gearT444E[QUOTED] likes this.
  16. Feb 9, 2021 at 5:29 PM
    #3496
    mjbtaco
    Michael
    Montclair , so cal
  17. Feb 9, 2021 at 6:49 PM
    #3497
    T4RFTMFW
  18. Feb 9, 2021 at 6:52 PM
    #3498
    T4RFTMFW
    Just ordered 2 packs. :woot:
    You the man!
  19. Feb 9, 2021 at 6:55 PM
    #3499
    T4RFTMFW
    Wait.. $10 shipped for 2 packs?
    Mine dropped down to $36.XX shipped.
    Bigdaddy4760 likes this.
  20. Feb 9, 2021 at 7:12 PM
    #3500
    mjbtaco
    Michael
    Montclair , so cal
    No its 10 flap wheels per pack what i posted is one pack. 1 pack for $10
