Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Feb 17, 2021 at 2:03 PM
    #3561
    svdude
    svdude Well-Known Member
    jonathan
    That is a neat idea. There is probably not many better ways to maximize socket space specific to a drawer size. And for a little time invested, it will save a couple hundred bucks in socket organizers. I have probably 200 sockets so even a cheaper timken tray adds up when I have 1/4”, 3/8”, 1/2” and all of them are in std, metric, deep, shallow, 6pt, and 12pt. Not to mention sockets for torx, std/metric long and short allen, etc... Needless to say, I have a 30” deep drawer that’s 5ft wide and is full for sockets. Granted, most of them are shadowed in foam so they’re taking a ton of space.
    I’m not bending wrenches on aircraft anymore so I can simplify and maximize my toolbox organization. My wrench drawer was recently gone through since I took out my foam and added trays, I’m still shy on space there too.
    I may dedicate a few evenings and copy your idea.
  2. Feb 17, 2021 at 2:17 PM
    #3562
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I use Ernst rails as well. Front to back in the drawer. I really like them.
  3. Feb 17, 2021 at 7:42 PM
    #3563
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Nice find.
    RyanL[QUOTED] and Gunshot-6A like this.
  4. Feb 17, 2021 at 7:43 PM
    #3564
    T4RFTMFW
    The Ernst stuff looks good. Reminds me of the Tekton tray.
    EatSleepTacos likes this.
  5. Feb 17, 2021 at 8:29 PM
    #3565
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Used my tekton 3/8 drive torque wrench for the first time today.
    T4RFTMFW[OP] likes this.
  6. Feb 18, 2021 at 6:21 PM
    #3566
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Ernst is probably the best customizable socket trays Ive seen, I have two of the 3 rail ones for all my non hex sockets to be organized on.
  7. Feb 18, 2021 at 6:56 PM
    #3567
    T4RFTMFW
    I like them. Wish they had a flex head.
    DarthPow and mjbtaco[QUOTED] like this.
  8. Feb 18, 2021 at 7:11 PM
    #3568
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Old house:
    New house 13hrs south, still haven't set it up yet, but tons more storage/space and a small shop with more storage in the basement:transformer:
    jubei, JTFisherman, CXYyuppie and 5 others like this.
  9. Feb 19, 2021 at 8:12 AM
    #3569
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    a flex head torque wrench? wouldnt holding the wrench at an angle change the torque value?
    jubei, koditten and G.T. like this.
  10. Feb 19, 2021 at 8:33 AM
    #3570
    Hunterdc1
    Hunterdc1 Propane and Propane Accessories
    Brrrrother
    No I will not press 1 for English
    13 8 lug ltz gasser
    That's affirmative.
    koditten likes this.
  11. Feb 19, 2021 at 8:44 AM
    #3571
    joeyv141
    Virginia
    Little bit of flex head is ok and won't change the torque enough to matter, were talking maybe 10-15 degrees here.
  12. Feb 19, 2021 at 10:48 AM
    #3572
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Snapon makes a flex head but you could accomplish the same thing with a adapter. Just calc it before. I'd not want to dive into a torque situation without some guidance. I assembled hundreds of engines for Stan Mizell and he'd slap the shit out of you for something like that.
    LOL
    Zim
    https://www.utilityproducts.com/too...ffect the torque,on the torque wrench setting.
    2008taco and Bentrodder like this.
  13. Feb 19, 2021 at 10:49 AM
    #3573
    T4RFTMFW
    Something with the axis length.. someone smarter than me can probably break it down better.
  14. Feb 19, 2021 at 11:00 AM
    #3574
    LongRedAndSpringy
    LongRedAndSpringy Active Member
    CA 805
    2006 Impulse Red Tacoma SR5 DCLB 4WD
    Icon Stage 1 Lift Kit 265/r70/17 KO2's 17"x9" -12/4.5" Method 312's
    Got my tool chest in this past weekend. Up next is a socket organizer to be finished this weekend
    Gotta drill holes & add pegs, in the meantime the sockets are free to mingle (except for any 10mm, they are locked up)
    markram, Tacman19, Roll_Terps and 3 others like this.
  15. Feb 19, 2021 at 11:20 AM
    #3575
    DarthPow
    yea its because of the moment arm. basically the distance from the pivot point to where the force is applied. Thats the moment arm. thats what determines the torque. if you use a flex head and lift it up, you're shortening the moment arm, changing the amount of torque youre actually applying, so the reading isn't accurate anymore.
    2008taco and Gunshot-6A like this.
  16. Feb 19, 2021 at 11:35 AM
    #3576
    svdude
    jonathan
    You guys have it mixed up with the flex on the torque wrench. The torque setting is actual torque at the head, if you shorten the distance between the head and the end of the torque wrench, the torque at the head is the same. You just need to apply a little more pressure at the handle to get the same torque. For example, your torque wrench is set at 100 ft lbs, and you have a 12” handle, you’ll apply 100 lbs of pressure at the handle to get that torque. Now shorten the angle by half (45* of flex at the head), you’re still getting 100 ft lbs when the wrench clicks, you just need to pull the torque wrench harder to get that same torque. The wrench will click at 100 ft lbs regardless of the angle of the wrench. The angle just means your arm does more work to get that torque.
    Test it out, take a bolt and torque it down to x torque with the wrench at 45*. Then torque it down the the same torque with the wrench at 0*, the bolt won’t move any further.
  17. Feb 19, 2021 at 11:39 AM
    #3577
    svdude
    jonathan
    Your link refers to torque adapters. Yes, this does change the torque value because it changes the distance from the head of the wrench to the bolt being torqued. If I use a torque adapter, I always put the adapter 90* out from the handle of the wrench. This keeps the torque the same, if you’re using the torque adapter straight in line with the handle then you need to do the math based on the length of the adapter to get the proper torque.
    drjkll likes this.
  18. Feb 19, 2021 at 11:54 AM
    #3578
    DarthPow
    this is a valid point.
    svdude[QUOTED] likes this.
  19. Feb 19, 2021 at 12:18 PM
    #3579
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    NTD..Sold some two stroke stuff this morning and found a $50 gift card from my employer so I ran to home Depot during my lunch break..love it
    OLD
    jubei, CXYyuppie, Tacman19 and 2 others like this.
  20. Feb 19, 2021 at 12:52 PM
    #3580
    T4RFTMFW
    This is what I had in my head. :)
    DarthPow likes this.
