Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Apr 11, 2021 at 7:53 AM
    #4161
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
  2. Apr 11, 2021 at 8:26 AM
    #4162
    6 gearT444E
    Deep South
    Herculiner Hootus
    the good old Zon. I got the part number for the brand on the one from the local hardware store and did a search, of course Amazon was first to pop up lol
  3. Apr 11, 2021 at 2:16 PM
    #4163
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    A——->Z man, if they ain’t got it, you don’t need it.
    Amazon was the only place I was able to source tires for my tractor, no dealer either could or price them realistically if they did. Washing machine parts? Yeah, they got em.
    6 gearT444E[QUOTED] likes this.
  4. Apr 11, 2021 at 7:01 PM
    #4164
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Anyone using a portable ac unit in their garage or shop? Summers pretty much here with 100 plus degreees approaching next week. Window unit doesn’t quite cut it so looking for suggestions. Garage is a 2 car so probably around 500-600 sq ft. Thinking of trying to keep the garage door closed and I have a back door to leave open for air flow and to dump the exhaust from the portable ac our.
  5. Apr 11, 2021 at 7:04 PM
    #4165
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    Avoid LG or LG compressor models, IMO.
    malburg114 likes this.
  6. Apr 11, 2021 at 7:13 PM
    #4166
    svdude
    svdude Well-Known Member
    jonathan
    I’ve used swamp coolers when I worked in aircraft hangars, they’re effective and low maintenance. Downside is they take a good amount of space for a 2 car garage. Maybe there’s a small model that will work well?
  7. Apr 11, 2021 at 7:22 PM
    #4167
    malburg114
    Las Vegas, NV
    I have a smaller one but it’s so old it doesn’t do much more than act as a fan. The size was the biggest reason for looking at a ac unit vs swamp cooler. I already have to move junk out everyday to work in the garage.
    not the greatest picture but no real extra
    room
  8. Apr 11, 2021 at 7:42 PM
    #4168
    T4RFTMFW
    She thicc.
    geekhouse23, Drainbung and malburg114 like this.
  9. Apr 11, 2021 at 8:24 PM
    #4169
    svdude
    jonathan
    Nice rig!
    I totally understand the lack of space. My garage is the same way with my tools, gym, bicycles, kids strollers, etc., I have to constantly move things around to do anything in my garage. When I was overseas in the military we used a wall mounted ac system in our living spaces. They used no space inside and just had a fan with control unit mounted to the wall while the ac was on the ground outside. Maybe that will fit your needs but they may be a little spendy.
  10. Apr 11, 2021 at 10:24 PM
    #4170
    6 gearT444E
    Deep South
    Herculiner Hootus
    yeah a small mini split unit would work best. Fan and evaporator would be on the wall out of the way, assuming one of the walls in the garage is an outside wall.
    Wyoming09 and malburg114 like this.
  11. Apr 12, 2021 at 4:15 AM
    #4171
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Whatever you decide on, check with your utility provider- they could have rebates going. Good luck!
    G.T. and malburg114[QUOTED] like this.
  12. Apr 12, 2021 at 4:30 AM
    #4172
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    This style one is nice to have around too. Easy to take to whatever you need to check (like a stud or the threaded hole you lost the bolt to)
    https://www.threadtoolsupply.com/metric-thread-checker.html
  13. Apr 12, 2021 at 5:56 AM
    #4173
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    I am, make sure you get a 2 hose model, the single hose models will cause suction that will pull in outside air from every where it can. I "converted" a single hose 15k btu to dual hose but it will not keep up with my 700 + Sq ft garage.
    Then I ended up with one of these (see below) it works ok but could be better. If I had the space for the outside condenser I would consider a mini split.
    https://www.ebay.com/itm/1519098397...NTP9eb88dPkyP97LnEn4oIWhravEtFl4aAg5qEALw_wcB
    malburg114[QUOTED] likes this.
  14. Apr 12, 2021 at 6:01 AM
    #4174
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Those work like shit.
    They will work for a small bedroom or bathroom.
    I used one for 2 months and sold it.
    Wyoming09 likes this.
  15. Apr 13, 2021 at 3:01 AM
    #4175
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do it right from the start you will be much happier .
    Those small units are ok for a room
  16. Apr 14, 2021 at 11:19 AM
    #4176
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Yeah, cat bites that dont get infected are a definite minority
    2008taco and PzTank[QUOTED] like this.
  17. Apr 15, 2021 at 7:26 AM
    #4177
    cynicalrider
    cynicalrider #NFG
    Jersey
    I've always had mine burn and swell, sometimes I alcohol them sometimes I don't, but never seen them like that dudes pic...
  18. Apr 16, 2021 at 7:32 PM
    #4178
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    $89? Had to.
    Slashaar, koditten, Tacman19 and 8 others like this.
  19. Apr 16, 2021 at 9:04 PM
    #4179
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I just picked one up a few weeks ago along with a swag offroad portaband table and I really am impressed so far with the Bauer portaband
  20. Apr 16, 2021 at 9:13 PM
    #4180
    mjbtaco
    Michael
    Montclair , so cal
    Nice!
    My friend who is a much better fabricator than I am recommend it. He said he was super impressed with it too. I might make my own table for it.
