Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Dec 8, 2021 at 6:02 AM
    #4941
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Ah. Very good. Smart, listen............yes sometimes we all leave the drain valve open. Never store with pressure ESPECIALLY if you ran it moist and cool.
    Venom[QUOTED] likes this.
  2. Dec 8, 2021 at 6:06 AM
    #4942
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    Is it a good idea it leave the drain valve open at all times, when not in use?
    I don't know if this is normal but it makes a weird sound for about 15 seconds right before it shut off when the tank is full. I doesn't make the sound while filling.
  3. Dec 8, 2021 at 6:16 AM
    #4943
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    If your shop is dry and clean - either open or closed, not a huge difference but open allows best drainage.
    Unknown on sound. Could be the pressure switch doing some kind bounce thing or just the pump itself as it works a bit harder.
  4. Dec 8, 2021 at 6:23 AM
    #4944
    Venom
    Kevin
    Massachusetts
    Should the sound be steady and even until the compressor shuts off?
    I only have a Viair air compressor to compare it to. Viair sound a lot better.
  5. Dec 8, 2021 at 6:27 AM
    #4945
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Best asking people who have the EXACT model as you.
    My old Craftsman is so damn loud I just don't even listen within 50ft without earplugs and muffs - yes the sound changes as the pressure builds.
  6. Dec 8, 2021 at 6:30 AM
    #4946
    Venom
    Kevin
    Massachusetts
    I don't know anyone with the same compressor.
    Thank you, Sir for all the replies!
  7. Dec 8, 2021 at 6:31 AM
    #4947
    Venom
    Kevin
    Massachusetts
    Thanks everyone for answering my questions.
  8. Dec 8, 2021 at 6:35 AM
    #4948
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    What exact model did you buy, I kinda forgot?
  9. Dec 8, 2021 at 6:38 AM
    #4949
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    So looking at the swag off-road band saw stand thing to go with the baur band saw. Anyone have thoughts on this?
    Gunshot-6A likes this.
  10. Dec 8, 2021 at 6:42 AM
    #4950
    Venom
    Kevin
    Massachusetts
    Pablo8[QUOTED] likes this.
  11. Dec 8, 2021 at 6:46 AM
    #4951
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
  12. Dec 8, 2021 at 6:55 AM
    #4952
    Venom
    Kevin
    Massachusetts
    I'm watching YouTube reviews videos to listen for the same sound. Most videos don't show when it cuts off or the sound has been modify to hear the person speak.
  13. Dec 8, 2021 at 7:08 AM
    #4953
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Most compressors “unload” the pressure tube to the tank on shutdown, this is a slight air rush pssssh when pump shuts off. This drains head pressure for the next start so motor isn’t pushing against it on spin up. Helps keep inrush amperage lower and less wear on motor and belt (if equipped)
    read directions, you’re likely supposed to run compressor for several minutes with drain open to seat piston seal and allow it to pump more efficiently after initial break in. Pretty common with oil free pumps.
    Venom and Pablo8 like this.
  14. Dec 8, 2021 at 7:16 AM
    #4954
    Venom
    Kevin
    Massachusetts
    When I get home later I'm going to read the owner manual.
    Pablo8 likes this.
  15. Dec 8, 2021 at 7:42 AM
    #4955
    la0d0g
    running for the hills
    For crawling not hauling
  16. Dec 8, 2021 at 7:57 AM
    #4956
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    All things SWAG Offroad are solid products. I don't own one, but have experience with it. It's a great option for semi-permanent bandsaw usage
    Brian422[QUOTED] likes this.
  17. Dec 8, 2021 at 8:27 AM
    #4957
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  18. Dec 9, 2021 at 5:08 AM
    #4958
    Venom
    Kevin
    Massachusetts
    I would if it was in English :boink:
    Like every review replies the manual sucks. I'm doing what everyone is doing, getting answers online.
  19. Dec 9, 2021 at 5:14 AM
    #4959
    Venom
    Kevin
    Massachusetts
    The hissing noise isn't what I'm hearing. I'm familiar with the noise. It more like a cracking type of sound.
    The owners manual doesn't say anything about a break-in period. I did find that information online. The replies were between 15 minutes to 30 minutes on break-in time.
  20. Dec 9, 2021 at 6:16 AM
    #4960
    cynicalrider
    cynicalrider #NFG
    Jersey
    @Chux loves his. I really like the idea of the portaband pro if I ever did it for both miter and table band saw applications. Only downside is you are limited to milwaukee cordless saws and only a couple kinds. Plus it's pretty pricey. The cheap ass in me will likely go with the Bauer and Swag table.
