Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Jul 29, 2022 at 11:44 AM
    #5401
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have 4 8-foot 2-bulb fluorescent fixtures in my garage, and I upgraded the bulbs to LED bulbs from superbriteleds.com.
    IIRC, they cost about $250. Totally worth it. Significantly brighter, no flicker, no buzzing in the winter. And, I should never have to mess with the bulbs again.
    I pulled the ballasts out, as these bulbs wired direct to AC.
    I appreciate the upgrade every time I go in the garage and turn on the lights.
  2. Jul 30, 2022 at 12:38 PM
    #5402
    G.T.
    G.T.
    CONUS
  3. Aug 4, 2022 at 2:22 PM
    #5403
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Not tools specifically, but got a bunch of cabinets. Wal-Mart had these one sale/clearance awhile ago so I decided to pick some up. have to say...its been an adventure. I ended up placing two orders..one for 5 and the next for 6.
    Wal-Mart themselves have been awesome to deal with. The shipping company they use for freight (Pilot) sucks. The shipping company pretty much just stacked the boxes on a pallet and didnt bother to secure them to said pallet. My first order of five.....well I got three of them. Two of them were beat to crap box wise. One was missing the hardware and had some good dents/bent pieces. The other just had some cosmetic damage. They were all supposed to be 36" wide ones but i ended up with a 48" wide one out of the three i did get. So cant complain there. The end point freight company (Pilot picks up from Wal-Mart and delivers to a freight company close ot you to finish the delivery apparently) was awesome and had documented the damage, filled out some paperwork for me, and had taken pictures in case I needed them.
    With all that....I had to call up Wal-Mart. Took a bit as the lady apparently had to get help. But ended up refunding the two missing ones and then gave an additional 50% off the two damaged ones which more than covers me having to pick up some hardware.
    The second order of six was in worse shape. Same shipping method of just tossing them on a pallet and not securing them. So four out of the six had beat up boxes. The two I pulled out at home seemed to be in good shape though. We will see what Wal-Mart does for these four when I give them a call.
    But all that aside....the build quality is decent. I've got some interesting plans for one or two of them so Ill post when I modify them a bit. Adding casters to them was also a nice move on my part. makes them easy to move around the shop...which Im sure I will be doing plenty of as I finish the interior.
    Bagman, Grumpy, Gunshot-6A and 5 others like this.
  4. Aug 4, 2022 at 4:31 PM
    #5404
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    those are great! i have something similar i acquired from work. Nice with the wheels also. great find.
    Drainbung likes this.
  5. Aug 4, 2022 at 6:07 PM
    #5405
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    The wheels are nice that's for! Least for now since I'll be moving them around to work on the interior. Definitely don't want to move them to much as the mount for them is a bit flimsy and could bend /break if it hit something. It's just a riv nut in a 3/16 thick piece of sheet metal
  6. Aug 5, 2022 at 8:52 AM
    #5406
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I was wondering about that. I've considered putting some metal cabinets on casters for my garage but assumed I'd need to build a wood or steel base for them to ensure they're rigid enough.
  7. Aug 5, 2022 at 6:53 PM
    #5407
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I'd say some of it depends on how the base of the cabinet is. For example these are two different types that Im adding casters to. The first you can see doesnt really sit flush and ends up with a lot of "stick out". Its also just a rivnut. So its fine for moving it around to clean under it or just moving from point a to point b every so often but i wouldnt want to be moving it daily.
    The second is flush with the bottom so it doesnt have as much play to it. Its a lot sturdier feeling. This is the type I would want if moving it around often.
    Course building a base is the best route for these "cheaper" type cabinets. O and dont mind how loose things seem in the pictures. Nothing was actually tightened down
    Pablo8 likes this.
  8. Aug 6, 2022 at 4:12 AM
    #5408
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Very cool. I have added nice casters to my grinder stand, my smoker, table thingie, I even redid an HD dolly with large softer wheel casters. It usually involves drilling and nutting.
  9. Aug 6, 2022 at 8:00 AM
    #5409
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
  10. Aug 6, 2022 at 9:00 AM
    #5410
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Recently did a bit of reorganizing in my main tool box, in an effort to avoid getting a bigger one. I'll still probably end up with a bigger box to try and combine my two boxes into one. Also, if you use your box professionally, and open the drawers a hundred times a day, don't get the Milwaukee branded boxes. The drawer slides are garbage. The drawers are also just generally too small.
    Happy with the cheap magnetic holders off Amazon I cut to size for the screw drivers.
    IMG-20220602-WA0006.jpg IMG-20220602-WA0008.jpg IMG-20220602-WA0010.jpg IMG-20220602-WA0009.jpg IMG-20220602-WA0007.jpg IMG-20220602-WA0011.jpg
    szidls, Grumpy, Bkicks333 and 4 others like this.
  11. Aug 6, 2022 at 12:20 PM
    #5411
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Sometimes the smallest tools lead to the biggest victories..
    Squirt, joeyv141, MY50cal and 7 others like this.
  12. Aug 6, 2022 at 12:21 PM
    #5412
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :yes:
  13. Aug 6, 2022 at 12:59 PM
    #5413
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Ooh... that scratches an itch like no other! :thumbsup:
    geekhouse23[QUOTED] likes this.
  14. Aug 9, 2022 at 7:27 AM
    #5414
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    TFW you successfully back out a busted bolt.
  15. Aug 9, 2022 at 8:30 AM
    #5415
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Fukr gonna snap in two just looking at it!!
  16. Aug 9, 2022 at 1:55 PM
    #5416
    OffroadJet
    Sebastian, FL
    Had a sprayer that stopped working. Opened her up found a broken spring. Went to home cheapo and got a spring set. Better than factory!!
    Grumpy, Gunshot-6A, mjbtaco and 6 others like this.
  17. Aug 9, 2022 at 3:14 PM
    #5417
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Picked up this big girl. M18 Fuel 1/2" impact. Would still like to get a 3/8" stubby impact but need to wait for a deal. :spending:
  18. Aug 9, 2022 at 3:21 PM
    #5418
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    is that the mid-torque, or high torque?
    dumontrider[QUOTED] likes this.
  19. Aug 9, 2022 at 3:41 PM
    #5419
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thinking of adding a die grinder to the mix, pneumatic.
    Recommendations for something inexpensive, but also not cheap chinesium crap that'll fail after 2-3 uses?
  20. Aug 9, 2022 at 5:23 PM
    #5420
    dumontrider
    La Habra, CA
    14 GX460
    High torque. Had a chance to borrow one when I was changing my truck diff out. Those ring gear bolts are tight as hell if you don't have a jig to stop it from turning! This gun didn't even have to try. The mid torque may have done the job but I don't know, so I didn't want to buy one to find out.
    Drainbung and DarthPow[QUOTED] like this.
