Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Sep 1, 2022 at 9:07 AM
    #5521
    Squirt
    Squirt Pepsi > Coke
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Yeah those old engines were torque monsters!
    This is one of the cooler steam engine videos I've seen...
    https://youtu.be/05zKt5fLPSs
  2. Sep 1, 2022 at 9:19 AM
    #5522
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    110 Case... that thing is an absolute MONSTER. I love it, they're so confident of a full pull that not only are are they wasting steam with the whistle, they throw in a spark show too! We have an 1905 Case 45; used it to pull a couple drunk cowboys & their pick-up out of the ditch a bunch of years back... They were pretty well amazed that this hundred year old, clanking noisy thing, moving at 2 1/2 mph even existed, and said there was NO way it would work... chained up to the truck (nose down in a 15' drainage ditch), got a good fire going, and put the cut-off into the far notch and opened up the throttle... up she came (There may, or may not have been a souvenir drive shaft displayed on the cab roof of the case for a couple of years... :D ).
    jubei, dumontrider, Drainbung and 2 others like this.
  3. Sep 1, 2022 at 9:21 AM
    #5523
    Squirt
    Squirt Pepsi > Coke
    Ben
    Oh that is AWESOME!!!! :rofl::rofl:
  4. Sep 1, 2022 at 10:49 AM
    #5524
    Kwikvette
    Fresno County
    4 run, 2 don't
    Of course, no problem!
    Just make sure to wear gloves when you spray and wipe everything down. I used WD40 to remove all the factory cosmoline; manual states not to use acetone.
    Cleaner you get it and all the crud off, the smoother everything goes together.
    And if your chuck arrives before your press, you'll see where in the install step you install it. It's literally just placing your wood to the bottom and tapping it upward. Held on by friction via a tapered shaft.
    Pablo8[QUOTED] likes this.
  5. Sep 1, 2022 at 12:35 PM
    #5525
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Situation 1.
    Want to gate this opening. It's about 8 feet wide. I'm open to ideas. Something nice. Without going broke. 4-5-6 feet high.
  6. Sep 1, 2022 at 12:42 PM
    #5526
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Problem 1.
    Brick molding made of cheap white wood rotted after 8 years. It used to be wet all winter. I cut back to good wood and sprayed daily with 99% alcohol. It is clean and dry now AND covered.
    How should I fill the gap?? No rush, critters can't pass. Ideas?
    dumontrider likes this.
  7. Sep 1, 2022 at 12:50 PM
    #5527
    tirediron
    I would just do something out of cedar (although these days, that may constitute going broke...), two sections so that the swing space and hinge weight are less.
  8. Sep 1, 2022 at 12:54 PM
    #5528
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Makes sense, but how would you anchor the gate posts?
  9. Sep 1, 2022 at 12:56 PM
    #5529
    tirediron
    Is that structure sitting right on grade????? :eek: I would consider using composite "lumber" (ie, "plastic lumber") as the facing and make sure that it's WELL sealed to ensure that moisture on the grade can't penetrate.
  10. Sep 1, 2022 at 12:59 PM
    #5530
    tirediron
    You could either put a hinge plate directly on to the house, or use a bracket and concrete fasteners for the base and brace the the top to the house. If you're really ambitious, cur the concrete, sink a piece of Sono tube and set in a piece of 'C' channel of the right height and then re-finish the concrete (that would be my preferred method.
  11. Sep 1, 2022 at 1:02 PM
    #5531
    Toyko Joe
    Toyko Joe Here for the pictures
    What is the intent of the gate?
  12. Sep 1, 2022 at 1:02 PM
    #5532
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yes and no. It's on a huge slab well above grade that slopes away from that corner. The that corner in the breezeway is and it was hardly covered. So stupid. The breezeway are concrete filled up to the slab, if you follow.
    Plastic = good idea
  13. Sep 1, 2022 at 1:03 PM
    #5533
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Just to keep dogs on inside. Some visual blockage as well.
  14. Sep 1, 2022 at 1:16 PM
    #5534
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Suddenly I realized I posted this in the wrong thread. Hahaha crap.
    Kwikvette and Toyko Joe like this.
  15. Sep 1, 2022 at 1:18 PM
    #5535
    Toyko Joe
    Kwikvette likes this.
  16. Sep 1, 2022 at 2:34 PM
    #5536
    tirediron
    Still, really bad building practice; that should be resting on a raised, impermeable layer of some sort. Might be worth talking to a pro and looking at whether it would be feasible/worthwhile to pull off that lowest level of trim and encapsulate things in epoxy (I'm thinking probably not, but...)
  17. Sep 1, 2022 at 3:00 PM
    #5537
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Pretty much how all garage.shops are built. ?????
  18. Sep 1, 2022 at 3:25 PM
    #5538
    Kwikvette
    Fresno County
    4 run, 2 don't
    Added another tool, forgot I ordered it until I saw it at my doorstep coming home from work today :rofl:
    EVO185HD saw
    It's their small 7 1/4" cold cut saw.
    I hate abrasive saws, and since I expect to buy a horizontal bandsaw, I wanted a small cut-off saw as well hence the purchase.
    Unfortunately, I didn't fully plan this purchase so it'll sit on my miniature catch-all table until I make a stand for it.
    Unboxing, here's what you get.
    Standard metal-cutting wheel; they offer specific blades for aluminum, stainless steel, and thin metal if you require to cut said items.
    Even get some PPE as well as some allen wrenches.
    So, everything I've read and heard about this thing is all positive with the exception of some plateforms not being fully flat.
    Fortunately, mine is flat.
    Installing the blade is a cinch, just need to remove 4 screws and swing the guard out. Otherwise, that's it.
    I'll report back once I've run some steel through it.
  19. Sep 1, 2022 at 4:41 PM
    #5539
    cynicalrider
    cynicalrider #NFG
    Jersey
    FWIW I love mine. I still don't get perfectly square cuts sometimes but it's good enough for fabrication. Only downside is it's loud af, and if you aren't careful you can burn the blade up easy.
    Kwikvette[QUOTED] likes this.
  20. Sep 1, 2022 at 5:14 PM
    #5540
    Kwikvette
    Fresno County
    4 run, 2 don't
    Do you have the big one or the small one?
    I was really putting off getting one due to the noise, but at least it'll be cleaner than an abrasive saw (even if all the chunks are just larger).
    I'll keep that in mind regarding the blade, thanks!
