Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Oct 17, 2022 at 9:37 AM
    #5581
    Madjik_Man
    Colorado Front Range
    Anyone here good with repairing ratchets (hand tool)?
    I bought a KTC BRSW3L and used it for the first time yesterday. It completely seized when the first bit of torque was applied. So I loosened up the screw to see if that would help disengage the pawl. No go.
    So I removed the screw and direction/backing plate to look at the mechanism. It looks pretty simple, so I put it back together. Still nothing. If I find that sweet spot of tightening/loosening the screw the pawl just skips across the teeth on the head.
    I followed these instructions (I believe this is a Proto roto head but the parts are the same)
    I'm at a loss. Wondering if there's anyone who can help get this thing back in order.
  2. Oct 17, 2022 at 3:58 PM
    #5582
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    I just bought 25 some odd diamond core bits for making stone earrings/plugs. Need to make myself a bit holder like this.
    williams63[QUOTED] likes this.
  3. Oct 20, 2022 at 3:40 AM
    #5583
    6 gearT444E
    Deep South
    Herculiner Hootus
    Road trip to pick this bad boy up last night!
  4. Oct 21, 2022 at 11:24 AM
    #5584
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Next time, I'd highly recommend Monoprice. They have a great selection and good prices on all the audio/video gear and accessories needed for home A/V projects. I get all my TV mounts, cables...etc from them now and we get most of our phone cases from them now too.
    OffroadJet and Kwikvette[QUOTED] like this.
  5. Oct 21, 2022 at 11:27 AM
    #5585
    Kwikvette
    Fresno County
    4 run, 2 don't
    You unlocked a core memory :rofl:
    I've ordered from them as well as Parts Express for misc. items in speaker building and in-wall stuff.
    Yeah I should've gone that route for sure, but I'll keep them in mind for future stuff thanks!
    clenkeit[QUOTED] likes this.
  6. Oct 21, 2022 at 12:13 PM
    #5586
    cynicalrider
    cynicalrider #NFG
    Jersey
    My last project has me itching for a drill press. Drilling metal I got by for a long time, hard for stuff to walk once you start. Last project had me drilling plastic and got some oblong shit that pisses me off. Opinions on this comparison?
    https://dailydiygadgets.com/wen-4214-vs-4214t/
    slander likes this.
  7. Oct 21, 2022 at 12:28 PM
    #5587
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's, very interesting considering that I had thought the only difference was the table and that's it.
    I'd opt for the T if I was drilling wood often, and I mean a lot. Or is it PVC? You'll benefit from the higher speeds.
    But the non-T has handled any and all metal I've thrown at it which so far has been 1/8", 1/4", and 3/8". Drill bit comes more into play here.
    Larger chuck and larger motor would deal with much larger holes in thicker stuff which I'll never run into.
    Hell, look at everything Evan gets done on a smaller HF drill press!
  8. Oct 21, 2022 at 12:44 PM
    #5588
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Given those 2, T probably not needed.
    But....that table drill press only has a 2in stroke. That's the down side that you'll realize later, good for straight drilling holes. But odd pieces (like drilling out a knuckle or something) won't be able to do.
    I picked up a 1968 floor drill press, $50, 3pulley/belt design so multiple 18 I think speed settings. Has an 8in stroke so much better and work well with my 3axis vise mounted.
    So if you need space, table top is probably good for holes, but creating/modifying items, search FB marketplace for a floor model.
    Edit looks more like $125-250 prices lately.
  9. Oct 21, 2022 at 7:35 PM
    #5589
    cynicalrider
    cynicalrider #NFG
    Jersey
    Nah almost never plastic, just this one scenario. I do like the idea of a 1/2" chuck though.
    My lack of shop space is the biggest deterrent on a floor model.
  10. Oct 21, 2022 at 8:52 PM
    #5590
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lack of shop space was also a reason why I didn't go with a floor standing setup; lots to be had for a Benjamin or two.
    The 4214 I have has a 3 1/8" stroke which exceeds the 2 1/2" I needed.
    That and you can always swing out the drill if you need to drill into something that won't fit on the platform; just need to sit whatever you want onto something to bring it up to the press.
  11. Oct 23, 2022 at 7:19 PM
    #5591
    Roll_Terps
    Roll_Terps Well-Known Member
    Maryland
    2017 SR DCSB White
    So I don’t have a garage, but have a workbench in a nook of our finished basement. With my job’s HQ moving further away I’ve found myself working at home a bit more and wanted a 2nd screen without sacrificing surface space. Snagged a monitor mount from the old HQ so I can swing it out of the way when not being used.
    jubei, Jeff Dartfrog, Delta09 and 8 others like this.
  12. Oct 23, 2022 at 7:26 PM
    #5592
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    HumanScale?
  13. Oct 24, 2022 at 7:51 AM
    #5593
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    Gauges aren't my thing but that's pretty cool! Nice work on those.
  14. Oct 24, 2022 at 7:55 AM
    #5594
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Garage coming together
    E9002C98-C04F-45A4-8C26-BD726890C92E.jpg 771E29A3-3A7C-4E16-B237-584B8EC3B8D9.jpg
  15. Oct 24, 2022 at 8:06 AM
    #5595
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Looking good. What brand uppers are those?
    Gunshot-6A likes this.
  16. Oct 24, 2022 at 12:44 PM
    #5596
    IPNPULZ
    going to be fun!
    I’m not sure as they were custom built by the contractor…..
    MY50cal[QUOTED] and Drainbung like this.
  17. Oct 28, 2022 at 9:55 PM
    #5597
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    You inspired me to get a garage tv.
    32" 1080p smart tv at wally world on clearance for $148, getting the $15 hf mount tomorrow. Wanted 1080 over 720 because I also placed some orders to upgrade my daily desktop computer and take the old components along with some other random parts I have laying around to make myself a garage PC and I can't stand 720 desktop resolutions.
    Kwikvette[QUOTED] likes this.
  18. Oct 28, 2022 at 10:27 PM
    #5598
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good stuff!
    1080 TV in the garage as well just because I *might* put a PC in there....once they get built that is.
    907rx7 and spencermarkd[QUOTED] like this.
  19. Oct 29, 2022 at 8:09 PM
    #5599
    spencermarkd
    Spencer
    Pretty happy with the tv. Perfect size to slip in between the cart lid and the bottom of my speakers. The mount attaches to the wall right where the crease is, so it’ll swing from where it is in the photo to almost directly above the bench easily
  20. Oct 31, 2022 at 6:03 AM
    #5600
    cynicalrider
    cynicalrider #NFG
    Jersey
