Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Nov 11, 2022 at 9:15 AM
    #5621
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice that it's way easier to adjust.
    But I can see it being really difficult if that nut was torqued down with an impact! :rofl:
    Yours is probably at the same setting now as mine's been since I got it.
    Pablo8[QUOTED] likes this.
  2. Nov 11, 2022 at 9:45 AM
    #5622
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    This is most likely correct. Only mine has a lot more oil than yours now. AHAHHAAHAHA
  3. Nov 11, 2022 at 9:48 AM
    #5623
    Kwikvette
    Fresno County
    4 run, 2 don't
    But did you lube the exterior for rust prevention :burp:
  4. Nov 11, 2022 at 10:28 AM
    #5624
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Yes, the raw steel parts, I did. I pretty much succeeded in not getting lube on the belt and pulleys. There definitely was some Chinese fish oil coating on some parts
    Kwikvette[QUOTED] likes this.
  5. Nov 11, 2022 at 10:33 AM
    #5625
    Kwikvette
    Fresno County
    4 run, 2 don't
    Flavored to taste :hungry:
    Zebinator and Pablo8[QUOTED] like this.
  6. Nov 12, 2022 at 2:36 PM
    #5626
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Works awesome
  7. Nov 23, 2022 at 6:40 PM
    #5627
    6 gearT444E
    Deep South
    Herculiner Hootus
    Here's my cheap ass home made "blowdown system" for the dryer condensate line (automatic) and the compressor drain (manual). It ain't stupid if it works LOL.
  8. Nov 27, 2022 at 4:31 AM
    #5628
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  9. Nov 28, 2022 at 7:40 AM
    #5629
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Toyko Joe likes this.
  10. Nov 28, 2022 at 11:24 AM
    #5630
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    la0d0g likes this.
  11. Nov 28, 2022 at 11:40 AM
    #5631
    la0d0g
    running for the hills
    For crawling not hauling
    Gunshot-6A[QUOTED] likes this.
  12. Nov 28, 2022 at 11:41 AM
    #5632
    Gunshot-6A
    Conner
    Everett, WA
    esp now that a lot of tool brands are making/including adapter plugs to create a impromptu dust collection system. Tried it on my jig saw and it was pretty neat.
    la0d0g[QUOTED] likes this.
  13. Nov 28, 2022 at 1:58 PM
    #5633
    la0d0g
    Got a flat on one of the 4runners sitting in my driveway. Tried to air it back up and realized the valve stem is rotted and ripped. Picked up this AME tool so I don't have to break the bead to swap the stem.
  14. Nov 28, 2022 at 2:15 PM
    #5634
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    How did it work?
  15. Nov 28, 2022 at 2:58 PM
    #5635
    la0d0g
    I'm waiting to get done with work to give it a shot. I'll report back.
    Kwikvette likes this.
  16. Nov 28, 2022 at 3:44 PM
    #5636
    cynicalrider
    cynicalrider #NFG
    Jersey
    I didn’t have good luck with mine because the hole for my stems was not large enough to let the valve stem go all the way into the wheel. So it would have a gap where the funnel ended and the wheel started.
  17. Nov 28, 2022 at 5:50 PM
    #5637
    la0d0g
    I didn't get to use the extraction tool since the rubber was so rotted when I pushed it in it essentially tore the valve backing in half. I was able to retrieve about a third of it with needle nose pliers prior to the rest of it dropping into the wheel :anonymous: it's a project truck so I'm not too concerned with it roaming around in there lol. The insertion tool worked like a champ and on the second attempt it seated well. Tire is holding air and back on the truck. I need to do one more that is rotted so I'll get another go with the extraction part.
  18. Nov 30, 2022 at 8:17 PM
    #5638
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Any ideas on what this thing is from? It looks familiar but I'm struggling to remember what it's for. Sharpie for scale
  19. Nov 30, 2022 at 8:18 PM
    #5639
    Kwikvette
    Fresno County
    4 run, 2 don't
    Looks like rod someone bent up.
    Got plenty in the garage.
    907rx7[QUOTED] likes this.
  20. Nov 30, 2022 at 9:19 PM
    #5640
    907rx7
    James
    Probably me, it'll go in the drawer of pointy things until I remember:notsure:
    Delta09, HisDad and Drainbung like this.
