Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. May 27, 2023 at 5:29 PM
    #5841
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just copy swag offroads setup, super easy
    soundman98 likes this.
  2. May 27, 2023 at 6:05 PM
    #5842
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    That was the plan lol
    Kwikvette[QUOTED] likes this.
  3. Jun 4, 2023 at 7:28 AM
    #5843
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    who said harbor freight tool carts can't have stereo systems?
  4. Jun 4, 2023 at 7:56 AM
    #5844
    Kwikvette
    Fresno County
    4 run, 2 don't
    Little Class D amp? :rofl:
    That's awesome.
    They're so compact people make boomboxes out of shoeboxes even.
    Drainbung likes this.
  5. Jun 4, 2023 at 8:06 AM
    #5845
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Does it go to 11 ?
  6. Jun 4, 2023 at 8:13 AM
    #5846
    soundman98
    NW Indiana
    these little amps are awesome. this'll be my 4th project with something similar. this one went faster just mounting the box as previous audio projects i desoldered and extended all the knobs for remote control...
    this one is going to be ran off an m18 battery. current plan is a small repurposed vizio sub on the lower shelf, with some dayton audio exciters stuck to the top lid for 360 degree annoyance. i mean audio.
  7. Jun 4, 2023 at 8:14 AM
    #5847
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shiiiiiit maybe I need to give myself something to do aside from making small truck parts
  8. Jun 4, 2023 at 12:28 PM
    #5848
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Definitely want to see some pictures when your done. At the dealer I just have a M18 speaker in the roll cart but this would be so much cooler
    soundman98[QUOTED] likes this.
  9. Jun 4, 2023 at 6:05 PM
    #5849
    soundman98
    NW Indiana
    this is really just the beginning. i can't leave anything alone! yes, i'm an expert at turning a simple $200 HF service cart into a $1,000 service cart... my other simple 3-shelf service cart got 8" pneumatic wheels and a reinforced frame to support them...
    i did briefly start going down a rabbit hole of adding a 150w outlet to the tool cart with a remote-mounted battery, and integrated usb charging, as well as some lighting, but it was getting really excessive and overtly showy for my needs. i really only require usb charging and audio, so i'm trying to keep it simpler at utilizing the oem milwaukee usb m18 plug-on pack--it technically does everything i currently need. it's just not as sleek as an under-cart-mountable battery pack adapter, and i still might end up changing that to save on upper cart storage, as well as offer sleeker wire management.
    currently in the research phase is different wheels, soft-close drawer slides, as well as adding an . i briefly considered upgrading to the 5 drawer cart instead of my cheaper 4 drawer cart, but the drawer lock mechanism on the 5 drawer drives me insane, for minimal added tool storage space. also considered adding a 2nd folding shelf to the cart, but i don't need the folding capability of the shelf and the additional drawers and stowage space for tools while also offering a solid table top surface are what i'd end up utilizing more of...
    the end cabinet consideration is how the amp ended up being integrated into the side support as it is-- that side is where the end cabinet will go if/when i go that route.
    no one ever builds what i really want, so i build it myself!
    mtip, ToyRyd04 and RustyGreen like this.
  10. Jun 5, 2023 at 7:03 PM
    #5850
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Decided to try out these SPC spring compressors based on the recommendation of @Shmellmopwho a bit back. Got some Fox 2.5's waiting to be installed so we'll see how the compressors handle the 700lb springs. Probably not 100% needed, but the instructions state to use a compressor when adjusting preload. Molded case has some indentations that jumped out at me...
  11. Jun 5, 2023 at 7:09 PM
    #5851
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Someone on the design team has a sense of humor. :rofl::rofl:
    @Delta09
  12. Jun 5, 2023 at 7:13 PM
    #5852
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    That's a storage spot for a safety bracket that some kits come with.
    https://www.amazon.com/ReluxGo-Comp...=1686017469&sprefix=spring+co,aps,280&sr=8-12
  13. Jun 5, 2023 at 7:14 PM
    #5853
    Gen1FTMFW
  14. Jun 5, 2023 at 9:15 PM
    #5854
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    They work great. They don’t feel sketchy at all. You’ll be stoked how well they work.
    HEY THAT LOOKS LIKE A FLOPPY DONG SPOT IN THE MIDDLE!!!!!
  15. Jun 8, 2023 at 7:22 PM
    #5855
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    My old creeper finally gave up the ghost, so I had to make a Harbor Freight run over the weekend.
    Picked this new Icon one up, pretty happy with it. It has metal plates at the top so you can attach magnetic lights to it, also available at HF.
    The padding is nice and comfortable, but it does grab at you/your clothes when twisting and turning.
    They had tire chokes on sale for $5 so I picked up a few extra. Left them outside for a couple of days to air out/off gas so they didn't stink up the entire garage.
    And finally got a battery powered craftsman ratchet at Lowes.
    mtip, soundman98, la0d0g and 6 others like this.
  16. Jun 9, 2023 at 7:50 AM
    #5856
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    just got that craftsmans tool. def great to have
    -Rorschach- likes this.
  17. Jun 15, 2023 at 10:14 AM
    #5857
    OffroadJet
    Sebastian, FL
    New toy. Need to learn how to use it lol
  18. Jun 15, 2023 at 10:16 AM
    #5858
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    looking forward to a honest product review.
  19. Jun 16, 2023 at 10:11 AM
    #5859
    OffroadJet
    Sebastian, FL
    Who said i was honest?? LMAO
    I didnt get into it too much but initially its a pretty nice unit. I need to learn how to use it but i think i updated the TSB for my tacoma lol I got it mostly for my VW project car but yea seems good so far.
    I did have to update the device along with the different vehicle manufactures. I realized that i didnt need most of them as i will never work on a Daewoo or Peugeot, etc. So just updated the typical cars manufactures in the system. Ill keep you posted when i do stuff with it
  20. Jun 16, 2023 at 10:15 AM
    #5860
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Can you calibrate steering angle sensors and bleed abs with it? Those are the two functions I need, but don't want to spend $3k + yearly subscription for the snap on one
