Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Sep 1, 2024 at 1:49 PM
    #6401
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thanks for the reminder
    Does anyone need some grinding wheels?
    I'll never use them, and they're brand new
    Just shoot me $11 for shipping and they're yours
    BlackPearl likes this.
  2. Sep 1, 2024 at 2:21 PM
    #6402
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    I'll take them, $11 total for all?
    woodtickgreg likes this.
  3. Sep 1, 2024 at 2:26 PM
    #6403
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, all 6 of them
    You're just covering a flat rate box
  4. Sep 1, 2024 at 2:44 PM
    #6404
    joeyv141
    Virginia
    Money and address sent via venmo.
    Kwikvette[QUOTED] likes this.
  5. Sep 1, 2024 at 2:51 PM
    #6405
    Kwikvette
    Fresno County
    4 run, 2 don't
    Got it
    Shoot it out to ya this Tuesday; assuming post office is closed tomorrow!
    joeyv141[QUOTED] likes this.
  6. Sep 1, 2024 at 5:30 PM
    #6406
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i've fully transitioned to keeping a bunch of these around me. they work with every grinder, so when bouncing between my m18 cordless and my corded grinder, i just need one tool. but any place that sells grinders sells one of those tools as well.
  7. Sep 1, 2024 at 6:10 PM
    #6407
    joeyv141
    Virginia
    Not to shit on ziptieing the wrench to the cord which I do on my screw chucked drill, but may I introduce a awesome milwaukee innovative I have on my grinder and love, I will admit that if you tighten it really hard you can't undue it by hand.
    https://www.homedepot.com/p/Milwauk...Vx09HAR22xDaCEAQYAiABEgKWsfD_BwE&gclsrc=aw.ds
  8. Sep 1, 2024 at 6:12 PM
    #6408
    Kwikvette
    Fresno County
    4 run, 2 don't
    Interesting
    I have 5 total angle grinders, and don't use that tool for any of them
    Drainbung and Gen1FTMFW like this.
  9. Sep 1, 2024 at 7:19 PM
    #6409
    soundman98
    NW Indiana
    not for me.
    the only time i really need the tool is for cutoff wheels-- by the time it either blows up or is reduced to nothing, it's self tightened to the point that i need the leverage of the pin tool to get it apart.
    otherwise, i use flap discs for sanding, and those always stay large enough that i can undo them by the outer radius of the discs.
    Drainbung and woodtickgreg like this.
  10. Sep 2, 2024 at 11:26 AM
    #6410
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Same here. Only use wrenches on my die grinders.
    Drainbung and Kwikvette[QUOTED] like this.
  11. Sep 4, 2024 at 11:35 AM
    #6411
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    What table is this? looks fancy
  12. Sep 4, 2024 at 11:41 AM
    #6412
    Kwikvette
    Fresno County
    4 run, 2 don't
    Garage Shop thread, maybe I should post a latest of my garage :rofl:
    It's a PrimeWeld fixture table
    Going to be ordering another one to replace the table on the left - they're both 2' x 3' and both 3/8" thick but I'd like to have two tables that perfectly mate with each other for a large flat welding surface.
    #smallgarageshop
    dumontrider, jubei, rob1208 and 4 others like this.
  13. Sep 4, 2024 at 12:31 PM
    #6413
    BlackPearl
    Alex
    Toyota Tacoma TRD
    Looks good, I need me one of those. How are you liking it as far as quality/ usability
  14. Sep 4, 2024 at 12:35 PM
    #6414
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pretty much the same as my other table.
    I've had the other one for a year now and use it quite a lot, but needing more table top space for welding I plan to buy another fixture for the reasons mentioned above.
    Otherwise, had I built my other table for a much larger dimension, I don't think I'd be replacing it.
    I will add that the fixture table is significantly more flat than the other table; they don't advertise flatness anymore but the largest shim I can get to fit under my straight edge is .010 in the very center which is more flat than I need it to be.
    Straight edge is an OEM tools straight edge that's accurate to .001 +/-
  15. Sep 4, 2024 at 12:49 PM
    #6415
    BlackPearl
    Alex
    Toyota Tacoma TRD
    I've been kicking around the idea of building one myself but don't think ill get it that flat.
    I found langmuir sells a similar style table. ArcFlat Modular Fixture Weld Table | Langmuir Systems
    might have to just bite the bullet and get one or two tops for my small area.
    I do like the black coating on the primer table
  16. Sep 4, 2024 at 1:22 PM
    #6416
    Kwikvette
    Fresno County
    4 run, 2 don't
    They're the same table.
    Except that PrimeWeld has an actual finish on the surface, versus an uncoated one like the Langmuir and the bolt setup for affixing the legs are different.
    The biggest difference is the legs themselves. The legs offered by Langmuir are -
    Designed in a weaker manner, the threaded plate for mounting the feet sits inside the tube
    The feet are stamped out of thin steel
    The legs are I think 16 gauge?
    The welds holding the mounting plates are poorly tacked on (and have failed for many people)
    PrimeWeld's supplier welds a 3/8" thick plate at the bottom of the leg, so the weight rests on the plate itself
    The legs are much thicker, at 1/8" I think?
    The feet are also machined, with a thick rubber foot pad at the bottom
    And when you compare the pricing of the two, the PrimeWeld is a few dollars cheaper actually
    And lastly, Langmuir uses 4 small bolts to affix the legs to the table versus PrimeWeld's 2 larger bolts so take that for what it's worth
    But even if both were identical in every manner, I'd go PrimeWeld for the ridiculously amazing customer support
    soundman98 and Drainbung like this.
  17. Sep 4, 2024 at 1:27 PM
    #6417
    BlackPearl
    Alex
    Toyota Tacoma TRD
    and here I though id made up my mine. Haha back to more research. I do apricate the input.
    Drainbung likes this.
  18. Sep 4, 2024 at 1:31 PM
    #6418
    Kwikvette
    Fresno County
    4 run, 2 don't
  19. Sep 4, 2024 at 1:41 PM
    #6419
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  20. Sep 4, 2024 at 1:57 PM
    #6420
    Kwikvette
    Fresno County
    4 run, 2 don't
    What's wrong with pointing out quality customer service many of us don't seem to experience anymore :boink:
    soundman98 and BlackPearl like this.
