Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Jul 20, 2019 at 3:08 PM
    #801
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    That sucks.
    la0d0g[QUOTED] likes this.
  2. Jul 20, 2019 at 6:47 PM
    #802
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    You don’t know your own strength! Reverse threaded btw!!
    Kidding- I’m assuming it was a defect. NEVER had one issue with mine. Hope the replacement works for you!
    Drainbung and la0d0g[QUOTED] like this.
  3. Jul 20, 2019 at 6:49 PM
    #803
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    I have the style below. Same concept, but not digital and has worked great for years.
  4. Jul 20, 2019 at 8:28 PM
    #804
    la0d0g
    running for the hills
    For crawling not hauling
    :muscleflexing:
  5. Jul 21, 2019 at 11:51 AM
    #805
    la0d0g
    Round two.
  6. Jul 21, 2019 at 11:54 AM
    #806
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Psst... Reverse thread :D:anonymous:
  7. Jul 21, 2019 at 12:18 PM
    #807
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Skip Arm Day...
  8. Jul 21, 2019 at 1:03 PM
    #808
    la0d0g
    :spy:
  9. Jul 21, 2019 at 2:06 PM
    #809
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Get a change to make sure this one wasn’t defected?! That sucks the first one broke so easy. Makes me grateful I never had that happen. I’ll be a little paranoid the next few times I use it now though!!
  10. Jul 21, 2019 at 4:16 PM
    #810
    la0d0g
    I did! Ran it to clean up some drywall lines. Worked perfectly :thumbsup:
  11. Jul 21, 2019 at 5:05 PM
    #811
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Glad this one worked!! Great little tool.
  12. Jul 24, 2019 at 9:01 AM
    #812
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Quick little job in the garage today.
  13. Aug 6, 2019 at 6:19 PM
    #813
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    $30 off coupon
  14. Aug 12, 2019 at 6:47 AM
    #814
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    got my little T4R in the garage yesterday after getting some shelving, tight fit and a struggle to get in and out of the doors.
    I think I'm going to build a carport and let this garage simply be storage/workspace and not for a vehicle..
  15. Aug 12, 2019 at 6:54 AM
    #815
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    did you build it yourself? do you have photos?
    I've wanted a carport since I've moved in, I think it will add value to the home. There are just so many trees and things dumping shit onto the vehicle parked in the driveway....I just don't know how I want to build one.
    Blackout14 likes this.
  16. Aug 12, 2019 at 7:05 AM
    #816
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    yeah that's pretty nice, my dad has a carport similar to that on his house. I'm not an artist, but here's the two options that I've come up with...super duper open to other suggestions lol
    both would be built to be wide enough for two vehicles to park under. the blue would obviously require turning to park underneath, but I kinda like it because then it would give me the ability to have whatever vehicle I'm working on covered and still have access to the garage.
    rob1208, whitedlite and Blackout14 like this.
  17. Aug 12, 2019 at 7:06 AM
    #817
    G.T.
    G.T.
    CONUS
    Check your local real estate tax laws to see if it’s actually attached makes your tax rate go up.
  18. Aug 12, 2019 at 7:07 AM
    #818
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    hm, interesting, never even thought of that...
  19. Aug 12, 2019 at 7:16 AM
    #819
    G.T.
    G.T.
    CONUS
    You’ll see deck builders out here build decks that are an inch off the back of the house for that reason.
  20. Aug 12, 2019 at 7:18 AM
    #820
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    very good point, it has been torn down and had to occupy a space for a few days before...that would be annoying having it block the garage.
