Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Aug 12, 2019 at 8:45 AM
    #841
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Prolly gonna find one of Khaleesi's friggin dragons in there. :rofl:
    Blackout14 and stronghammer like this.
  2. Aug 12, 2019 at 8:46 AM
    #842
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    haha y'all are killing me the shed isn't THAT bad.
    Gunshot-6A, Blackout14 and G.T. like this.
  3. Aug 12, 2019 at 8:50 AM
    #843
    Gunshot-6A
    Conner
    Everett, WA
    Neither was Chernobyl :rofl:
    stronghammer[QUOTED] likes this.
  4. Aug 12, 2019 at 8:52 AM
    #844
    Gunshot-6A
    Conner
    Everett, WA
    That would be...unfortunate...for all parties involved.
    Me, the snake, my pants cleanliness
  5. Aug 12, 2019 at 8:53 AM
    #845
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Your first call should be to your codes department. You may have set backs for structures for your property that may limit what you can build and how close you can build it to your property line. And that distance can vary between the street side of your property, the back and the side. Best to see what you are up against before you get your hopes up or before you plan too much, and especially before you build.
  6. Aug 12, 2019 at 8:58 AM
    #846
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    once a building is built what's the worst that can happen?
    Gunshot-6A likes this.
  7. Aug 12, 2019 at 9:00 AM
    #847
    Gunshot-6A
    Conner
    Everett, WA
    Your neighbor gets pissed you ruined his view, gets REALLY deep down the building code rabbit hole, finds a technicality, appeals to the county and city zoning board, gets their buyoff, and makes you tear the entire roof off your newly renovated (and nearly finished) detached garage and make the structure 3 feet lower.
    One of my coworkers is watching a MAJOR pissing match go down in his neighborhood. We have an over/under going on whether it will end in an arson or a murder.
    Depending on code, the powers that be can also hold you hostage until a condition is fixed. For example, a house I was looking to buy had the deck built around the exterior breaker box. If the city had found out about that, they would have locked out the breaker and made the house unserviceable until the code violation was remedied.
  8. Aug 12, 2019 at 9:05 AM
    #848
    ACEkraut
    Aaron
    Durham, Maine
    PITA headache at the least. Codes departments do not look kindly upon construction without permits. And it would be hard to hide that construction. At the least they would be pissed off and make the process take longer. Probably at least fines if there were no violations and if there were violations then most likely they would make you correct the problems or even tear the structure down. And the fines could be a one time fine for not getting the permit before hand to an ongoing fine as long as the structure in violation stood and was not torn down or corrected.
    Edit: Often you can find out what the codes are right online as well as the penalties. But I always like a phone call at least and a personal visit at best.
  9. Aug 12, 2019 at 9:11 AM
    #849
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I live in a neighborhood without an HOA, houses are close where all of our backyards meet. I'm kinda on a hill and I dug down to make the ground flat, but it also will lower how height the building appears to neighbors. I'm in city limits, but not doing any permits strictly because my neighbors do not care.
    Great neighbors are a gift. Also you have to build the building nice of course, I'm not trying to put some junker behind the house. You will not be able to see the building from any road though is huge
    I've also though about just making a nice garden patio out of it and selling and moving to bigger place. Problem is I love my location too much.
    I’ve uploaded photos before, but here they are. Ground work is done, but this is a long process since it’s my brother and me doing everything until it’s time for a meta building.
    Drainbung, Blackout14 and Gunshot-6A like this.
  10. Aug 12, 2019 at 9:14 AM
    #850
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Personally emptying the garage doesnt gain a lot. It looks like a tight fit that if you had to jack stuff up the jack wouldnt be straight out, pulling a tire would be an annoyance being stuck between in it and the wall. If garage wall was 4+ft away from the car then getting rid of the shelving would help. Idk i get kinda claustrophobic and irritated when im backing into a wall continuously or stuck bewteen the car
  11. Aug 12, 2019 at 9:38 AM
    #851
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    you are correct, emptying the garage would solely allow parking and entering/exiting of the vehicle.
  12. Aug 12, 2019 at 9:39 AM
    #852
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    most if not all of the "walls" are rotten, as well as most of the shingles needing replaced. the interior structure itself is not bad, I've taken some of the walls off and some of it will need replaced. The big kicker is the plywood floor, it ALL needs replaced, which I can't replace it all without taking the walls off of it and starting from the ground up. Good news is it has a cinder block foundation that is good and I can build on that. I may get one of those "shed kits" and just build a new one in the location of this one.
    Blackout14 likes this.
  13. Aug 12, 2019 at 12:39 PM
    #853
    Sacrifice
    KS
    DCSB OR 4X4 LT
    If you cant work on it in there then i dont see the point personally. Unless you just dont want to get wet, which a carport does as well.
  14. Aug 12, 2019 at 12:42 PM
    #854
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    yeah there'd be no possibility of working on it, but the lady does just want somewhere she can park her car, so it can serve that purpose...but I have to have a shed or somewhere else to store all of the garage stuff in order for her to be able to park there.
  15. Aug 12, 2019 at 1:53 PM
    #855
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Hell I plan to build one next summer just to protect from hail. Already had 6 hail storms this year, last nights was golf ball sized. Figured KS would have similar weather.
    This was my cousins place.
  16. Aug 12, 2019 at 1:57 PM
    #856
    Gunshot-6A
    Conner
    Everett, WA
    Squirt, la0d0g, Fire Chicken and 2 others like this.
  17. Aug 12, 2019 at 2:03 PM
    #857
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    We get them bad here. People wonder what I got a brick house and don’t like vinyl fences or siding. Worked great on our place in NJ, here... don’t feel like replacing it every year.
    Gunshot-6A[QUOTED] likes this.
  18. Aug 12, 2019 at 2:14 PM
    #858
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Damn
    shane100700[QUOTED] likes this.
  19. Aug 12, 2019 at 2:22 PM
    #859
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Not really. If it does hail its typically smaller than a pea.
  20. Aug 12, 2019 at 2:37 PM
    #860
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Hmmmm... and a carport probably doesn’t do anything for your tornados though. I could see not wanting/needing one then. lol
    Our garage is a 1.5 car, when it’s my wife’s turn for her 4R, we’ll want something for both vehicles.
