Garage Shop: Tools
Discussion in 'Garage / Workshop' started by T4RFTMFW, Jan 26, 2019.
  1. Feb 13, 2020 at 9:55 PM
    #1641
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Been really happy with my band saw. I push it beyond its limits at times and it shuts down but it always comes back for more. Broke my first blade today but luckily I had a back up.
  2. Feb 13, 2020 at 9:56 PM
    #1642
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Is that a WEN?
  3. Feb 13, 2020 at 10:00 PM
    #1643
    mjbtaco
    Michael
    Montclair , so cal
    Yup!
  4. Feb 14, 2020 at 6:00 AM
    #1644
    G.T.
    G.T.
    CONUS
    Agreed, zip tie a couple coils in to stop it fighting you.
    Drainbung likes this.
  5. Feb 14, 2020 at 2:14 PM
    #1645
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Blades get expensive after awhile. Going slower will yield better results also, if you don't mind me saying.
    I have no idea what kind of experience you have, so forgive me if I'm over-stepping.
  6. Feb 14, 2020 at 2:27 PM
    #1646
    mjbtaco
    Michael
    Montclair , so cal
    Lol no worries. I've had this blade for about a year. At like $15 I'm not too sad about it. I do try to go slow, sometimes I'm not very patient tho haha
    MSN88longbed[QUOTED] likes this.
  7. Feb 15, 2020 at 7:17 PM
    #1647
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I wanted to make it easier to move my Grizzly mill around. I started with the old tabletop from my lathe. I cut it to 36".
    Next I took a cheap set of 4 1/2" rubber HF wheels and used the lathe to cut down one side to countersink elevator bolts.
    That way it would rest on the rubber.
    I installed a set of workbench folding wheels and mounted the mill on the new mobile platform. It moves around with ease.
    With the legs folded it now sits on the rubber and is more sturdy than it was before.
  8. Feb 16, 2020 at 6:30 AM
    #1648
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    GENIUS. Full pic of mill and how much does it weigh?
  9. Feb 16, 2020 at 8:16 AM
    #1649
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    How are you guys getting oil out of driveways/concrete. Borrowing my dads bobcat and put a board under it but had a finish on top so the oil ran right off.
  10. Feb 16, 2020 at 8:23 AM
    #1650
    medic2230
    Murph
    Bama! Roll Tide
    Dawn dish soap and a little scrubbing. Then try one of the concrete cleaner solutions and pressure wash with both. Seems to get most of it with the Dawn. Just don’t let it sit or it will be harder to get rid of.
  11. Feb 16, 2020 at 8:29 AM
    #1651
    drjkll
    drjkll Well-Known Member
    NC
    2019 DCLB TRD sport 4x4 cement
    Dry cheapo powder laundry detergent. Just sprinkle a bunch on and let it sit for a day or so. We used to do this at the shop I worked at back in the day. Been doing it ever since. The longer you let it sit the less scrubbing. Usually mother nature's rain will take car of it.
  12. Feb 16, 2020 at 8:43 AM
    #1652
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Simple Green neat. Pour it on. Let it soak. Scrub with a bit more and hose off.
  13. Feb 16, 2020 at 2:40 PM
    #1653
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Oil dry ground in with a boot. Or a piece of 4x4 on the end of a broom handle works great.
  14. Feb 16, 2020 at 8:07 PM
    #1654
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    The mill weighs about 365 Lb. Add another 20 Lb for the stand and 30 Lb for the vice.
  15. Feb 16, 2020 at 10:47 PM
    #1655
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Starting fluid, the cheap stuff from Autozone or Walmart.
    Spray down the oil stain real good so it blast out the oil that has impregnated in the concrete. Soak up the residue with cotton shop towels. It dries in a hurry so no waiting for the concrete to dry to see if you got the stain out.
    Obviously, soak up as much of the liquid oil 1st with a towel or sawdust. Just don't use cat litter. That stuff doesn't work for fuck all.
    It works amazing! You can thank me later.
    six5crèéd likes this.
  16. Feb 17, 2020 at 4:14 AM
    #1656
    la0d0g
    running for the hills
    For crawling not hauling
    Brake cleaner.
    CXYyuppie and six5crèéd like this.
  17. Feb 17, 2020 at 4:34 AM
    #1657
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    That's a neat little milling machine! (I say little because I run a 3 axis at work)
  18. Feb 17, 2020 at 7:07 AM
    #1658
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Pick up an oil drip tray.....cheap pieces of metal with a small lip. Can be picked up for under 20 bucks. Work great to contain dripping fluids under stuff.
    For clean up...
    Obviously first choice is the metal drip tray as it can just be wiped up.
    Pig mats are my go to when I know something with be leaking oil. Just toss them down before hand or after it starts dripping.
    https://www.amazon.com/New-Pig-Heav...JE9HKA4C39G&psc=1&refRID=PZXD4V2HZJE9HKA4C39G
    Then if it's more of a spill....kitty liter works great to absorb it. And is cheap. Just spread a thin layer over the spill and wait a few minutes then sweep up. But...and big but....it only works well on smooth surfaces. Porous concrete or in cracks it won't do well.
    For small cleanups....regular shop towels and favorite degreaser. Wipe up much as I can then spray with degressor to finish.
  19. Feb 17, 2020 at 7:18 AM
    #1659
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Never had any luck at all with cat litter. Doesn't clean and doesn't really absorb oil. Surprised no one has tried Simple Green. It is very good degreaser. Soaking and a little action with stiff brush and water, hot if you can. Takes even old grease and oil out of concrete.
  20. Feb 17, 2020 at 7:34 AM
    #1660
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Guess I'm the odd ball since kitty liter has always work great for me and absorbs oil and hydraulic oils just fine.
    mallege likes this.
