garrett electric turbocharger
Discussion in 'Performance and Tuning' started by xxOkieTacoxx, Sep 18, 2012.
  1. Sep 18, 2012 at 9:11 PM
    xxOkieTacoxx
    xxOkieTacoxx [OP] Well-Known Member
    Jake
    Texarkana, TX
    99 Tacoma SR5 3.4L 4x4/ 16’ DCLB TSS
    3.4L V-6 W/ custom intake,Flomaster super 44 dumped, 15" Incubus Alloy Wheels W/33x12.50 Yokohama Geolander MT'S, Bilstein 5100 Adj W/ OME 881coils, Pro Comp rear leafs W/ Bilstein 5100 shocks, Manual Hubs, Diff. Drop,Custom front bumper w/ winch W/ keyed disconnect and 2 250,000CP running lights, relocated blinkers, front bumper removed, radiator guards, custom skid plates, Rhinolined interior,
    What about my idea of a rheostat on the electric turbo?
  2. Sep 19, 2012 at 7:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Google the Megasquirt 3 ECU. That can do what you are looking for, as far as tuning.
    Don't want to cut into the factor ECU? Get a plug n play extension harness from urdusa.com so that you can wire into it.
    Most people I have seen that turbo'd their 3.4's did a custom rear mount or mid mount.
    A good place to ask questions about headers and turbos for your engine in general, would be www.lceperformance.com. Call them.
    Generally speaking, it is easier to do a twin setup, on V engines. That being said though, I have a single on mine. ;)
    4.88 are way to much for what you seem to be looking for. I think that Toyota has something between a 4.10 and 4.56. You would just have to find which vehicle came with it. Like I said. I think.
  3. Sep 19, 2012 at 1:42 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  4. Sep 19, 2012 at 1:46 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Might be a Garret turbo housing but I highly doubt they have anything to do with the electric components bolted to the back of the thing where the exhaust would normally tie in.
  5. Sep 19, 2012 at 7:40 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    No offense to the OP, but is this thread a joke? While it is technically possible, the amp draw to get any real performance gain would not make it feasible at the puny human level of technology. Unless you have a flux capacitor. Which isn't real. :eek:
  6. Sep 19, 2012 at 8:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It won't be workable for street use at full power.
    It'll be even less useful "throttled" back.
    Not to mention that you'd smoke a rheostat at anything over 50%.
    You would need a high current electronic speed control.
  7. Sep 20, 2012 at 3:31 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    This thread is a joke. You own a 4,000lb V6 truck. What do you expect you bought a boat. There is no magic mod that can make these trucks fast. Once you accept this life will be much easier.
  8. Sep 20, 2012 at 3:32 AM
    Yamaha Dave
  9. Sep 20, 2012 at 6:48 AM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Believe me I know there's no magic mod I was just contemplating the possibility that it might work since it integrated an actually turbo impeller not some shitty RC engine plastic fan turbine. And yes a speed control module is what would have to be used for the high amp draw. Im on my cell phone so I was trying to use little words. Lol. When your 19 and have a wife and a 4 month old boy its hard to make yourself buy a turbo or s/c setup, though I make great money at my job (ammonia refrigeration) I kinda have my priorities straight when it comes to money. I was just being hopeful. I knew it was probzbly a piece of junk but it seemed more feasible than anything in the electric turbos that I've seen.
  10. Sep 20, 2012 at 7:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You need to look up the 2010 Turbo Tacoma in the 2nd Gen Build section. It is fast. Getting valve body upgrade done today. Custom intake manifold tonight. Re-dyno tomorrow. :thumbsup:
    You want a turbo, you need to do it right. Don't cut corners, or your will pay for it more than once.
