gas, 92 octane?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fce18, Nov 23, 2007.
  1. Nov 23, 2007 at 10:05 AM
    fce18
    fce18 [OP] New Member
    08 PRERUNNER
    hi all,
    i just got a 08 prerunner 2 X 4 taco, in the owners manual says that the recomended gasoline is with 92 octanes, so i was wondering if anyone knew what happens if i use 87 octanes gas? since is less expensive, or what happens if i mix gasoline, half and half ?
    thanks so much for your comments
  2. Nov 23, 2007 at 10:54 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    The computer in your truck will retard the timing for you if you run 87 octane. The truck will be fine, and run well. The only real benefit to running the 92 octane is a little more umph. I believe that the higher octane shows a 5 Hp and 5lb. ft. increase. If you know in advance you are going to be hauling or towing something, then fill up with 92. If you are just doing regular driving use 87.
  3. Nov 23, 2007 at 4:04 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I can tell you this: Last week I had an odd tapping/thumping sound. It was "deiseling" or, in other words, running like crap because of the 87 octane I've used recently. I put in a full tank of 93 and no more noise. Maybe a coincidence but I doubt it.
  4. Nov 23, 2007 at 5:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i noticed a really big difference from when i was running 87, and ive been running mid and premium for a while.
  5. Nov 23, 2007 at 5:41 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    I do mostly around town driving and 4 wheeling, so I run 91 to keep the motor running smooth, but If I am driving on a longer trip I'll drop down to 89 just because freeway miles are so much easier on the motor.
  6. Nov 23, 2007 at 6:06 PM
    Dcrooks84
    Dcrooks84 Sir Anal Loin of Beef
    Ohio
    05 double cab SR5 Pkg #8 lng bd 4X4
    Removed secondary air filter, Fog light anytime, Map light mod, Scan Gauge II, Polished Stainless Steel Westin E-Series Bull Bar, Black GrilleCraft Grille, Borla CatBack Exhaust
    Did they alter some thing with the engines? My 05 manual recommends 87 octane. I have the 4.0 v6.
  7. Nov 23, 2007 at 8:43 PM
    gegundez
    gegundez Well-Known Member
    Miami, FL
    07 TRD Prerunner Dcab
    Overpriced stereo and alarm. MBRP Dual Exhaust.
    In traffic crawl, I can't tell any difference, so regular gas and synthetic oil every 15k miles will do fine for now. When I retire in 20 years, I look forward to living anywhere with hills that it isn't so congested!!
  8. Nov 23, 2007 at 10:05 PM
    08toyo
    08toyo Active Member
    08 Prerunner DoubleCab 4x2 SR5 TRD Sport
    My 08 mentions nothing about using 93 octane. Manual says 87.
  9. Nov 24, 2007 at 4:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Same here.....
    I've been running 87 since I bought it (8 months ago). I only do trips to work & store - nothing major to warrant running the more expensive gas. If I were gonna tow or haul - I'd probably run mid grade.
  10. Nov 24, 2007 at 6:43 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Why wait 20 yrs ? How bad would it be if your time expired while in crawl, never getting your chance for the hills ? Live well friend ! Now back to the subject at hand, I have an 06, V-6 and I run 87 all summer long, no problems, no knocking, but come winter , every third tank I run high test for the cleaning property's, and yes there is an improvement in performance and the engine runs much smoother. Oh yeah nice rig, Drive on. :D
  11. Nov 28, 2007 at 8:29 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I recomend taking the middle ground. I run 89 and have no problems at all
  12. Nov 28, 2007 at 11:40 AM
    rjmcmillan
    rjmcmillan Member
    Calgary, Alberta
    2005 Tacoma Sport SB
    I used 87 for the past 2 years and recently started using 89. I'm on my 4th tank and getting between 10 to 15% more KM's per tank now than with the 87. Plus it is definitely running stronger. I'm thinking of testing 91 for a few tanks. With the extra KM's I'm getting per tank it off sets the additional cost of the fuel.
  13. Nov 28, 2007 at 12:14 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Mine truck feels much faster with the 91 and there are also some that claim you get enough of a better gas mileage to offset the extra cost of the gas. I really doubt that to be true though.
  14. Nov 28, 2007 at 12:15 PM
    rmd0311
    rmd0311 Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    Hmmm... My 08 manual clearly says 87... I run nothing higher than the manual recommends. Unless I'm towing something.
  15. Nov 28, 2007 at 12:30 PM
    rjmcmillan
    rjmcmillan Member
    Calgary, Alberta
    I was getting 410 KM's out of a tank with 87 with city driving.....now with 89 I'm getting 450 to 460 KM's out of a tank. Funny, I know the manual states 87 but a lot of the dealships recommend 89-91. I know I'm sticking with 89 or higher now.
  16. Nov 28, 2007 at 6:13 PM
    JJK
    JJK Active Member
    08 SR5 DC
    TrueTrac Limited Slip
    1mpg is all you need to break even at 15 cents per gal difference
    87 gas at $3.00 and 18mpg / 21 gal tank = 16.66 cents per mile
    89 gas at $3.15 and 19mpg / 21 gal tank = 16.57 cents per mile
    Mine runs a little stronger on the 89 gas too
    JJK
  17. Nov 28, 2007 at 6:30 PM
    sak3358
    sak3358 Well-Known Member
    Been running 91 since I bought it, with 6.7K on the OD. Going on a trip this weekend, I just may use 89 for the road, probably won't notice the difference.
  18. Nov 29, 2007 at 11:45 AM
    nd
    Nate
    Greenville, SC
    i can tell a difference between 87 and 89 but i cant tell any difference between 89 and 91+. i think our engines (V6) is most efficient at 89 octane. the higher octanes require higher compression ratios to get all the available energy from the gas. If your engine isn't built for higher compression then your just wasting the potention energy in the higher octane gas
  19. Nov 29, 2007 at 4:49 PM
    vivafire
    vivafire Well-Known Member
    Galveston,Texas
    07 PreRunner SR5 V6
    Add N-Fab side steps-debaged,cat-back exhaust from MagnaFlow and a Stage 2 intake system from AFE
    Only had my truck for 3 weeks and fill it twice with 87 with no problems.
  20. Nov 29, 2007 at 4:55 PM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    i'm going to be sticking with the 89 for awhile until i have a huge road trip to do, like the Alliance meet in the spring. hey ndcouch can you give me an address somewhere by where we're meeting so i can calculate my driving distance?
