Gas Cap Troubles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurviveToRide, Jan 18, 2020.
  1. Jan 18, 2020 at 8:22 AM
    SurviveToRide
    SurviveToRide [OP] Lover of anything on wheels
    Elijah
    2009 Access Cab V6 6MT TRD Sport
    17" TRD Pro Wheels 265/70/17 A/T’s Jason Topper
    Hey TW! I’ve been seeing some strange issues with my gas cap. Firstly, I got a EVAP test done, and it turned out there was a huge leak. Well, we fogged the system and sure enough the smoke came pouring out of the gas cap! The thing is, a leak of this magnitude should have set off a Check engine light, but no codes ever showed up. Does anyone know why the CEL wouldn’t come on?
    Well, after I found out it was bad I did the normal thing and went to O’Reilly to get a new gas cap. Told the guy behind the counter all the information, watched him plug it in correctly, and their computer pulled up a million caps, THAT DIDNT FIT THE TRUCK! So I was there for a while and eventually gave up and went to NAPA. However, I had the exact same issue there. So now I know it’s not just a bug in one of their systems, it’s gotta be a problem with Toyota maybe? Why wouldn’t the right cap pull up? So anyways I went to Amazon and ordered it from there, installed it, and actually saw an improvement in gas mileage!
    DG92071 likes this.
  2. Jan 18, 2020 at 8:25 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah, I've had the EVAP code before. All I need to do is retighten the gas cap. It's pretty sensitive.
  3. Jan 18, 2020 at 8:29 AM
    SurviveToRide
    Elijah
    I just found it really strange that I didn’t get a code when it was leaking that bad. And I did try and loosen and re-tighten it a few times, that didn’t fix the issue for me.
    DG92071 likes this.
  4. Jan 18, 2020 at 9:27 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    It takes several driving cycles under certain conditions to throw an EVAP code. The gas cap seat on the filler neck is often overlooked. Keep the seat polished and apply vasoline to it. I've seen the seat chew up new gas cap O rings.
  5. Jan 18, 2020 at 9:31 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  6. Jan 18, 2020 at 9:48 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Toyota’s fault Napa, autozone etc don’t have the correct gas cap?
    4xdog likes this.
  7. Jan 18, 2020 at 10:09 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    I bought my OEM replacement gas cap from Amazon.
  8. Jan 18, 2020 at 10:31 AM
    SurviveToRide
    Elijah
    Not necessarily saying it’s their fault but maybe an issue with part numbers or something. It’s just too strange two auto parts stores couldn’t find it.
  9. Jan 19, 2020 at 3:08 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I had a similar experience with e brake cables. The book had different PNs for the passenger side, but just 1 for the drivers side. And of course it was too short for a dclb...
