Gas consumption in deceleration
Discussion in 'Technical Chat' started by Warren Thompson, Aug 5, 2009.
  1. Aug 5, 2009 at 9:13 PM
    Warren Thompson
    Warren Thompson [OP] GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    I have always wondered. I have a Taco 4.0 6 cylinder and do much offroad. My question is this... when I use the engine compression stroke to decelerate going down hill (foot off gas pedal), is there gas being fed through the injectors into the cylinders?? Is fuel still being consumed in the engine? Does the computer know when compression is being used to slow the engine and shut off the gas flow?
    To me, it sure makes sense that gas flow to the injectors is shut off in deceleration, but is it???
    Thanks for any help.
  2. Aug 6, 2009 at 4:30 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    For the first few seconds, there is still gas flow into the cylinders. Once the computer realizes the truck is coasting, it will shut off the fuel. Its very noticeable in a truck with a manual when the fuel shuts off because the truck will slow down faster but you may not even notice with an auto.
  3. Aug 6, 2009 at 5:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Actually, its pretty noticable in the Autos also. :)
  4. Feb 18, 2010 at 12:12 AM
    scocar
    scocar hypotenoper
    Is this the case with 1st gen V6 manuals, too? My 93 22RE manual never did this, but I've been noticing something strange like this in my "new" 2001. It's like a two-phase deceleration when I let off the gas, more noticeable at lower speeds. It's buggin' me, makes me wonder. I just lubed the driveline (which made soem other clunking go away), so that isn't an issue.
  5. Feb 18, 2010 at 12:57 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    yeah, it does as the other guys have said. my scangauge reading "9999" for gas mileage on deceleration proves it too. :)
  6. Feb 18, 2010 at 9:37 AM
    scocar
    scocar hypotenoper
    Huh. So just to be clear, I see you have a 2nd gen, and this thread started regarding a 2nd gen 4.0, but you know this to be true of the 1st gen 3.4 V6 5VZE? Did you have a scanguage in a 1st gen at some point, or see someone else's do this?:confused:
    Just curious, because we are talking about different trucks and engines. I always appreciate demonstrable facts rather than hearsay or opinion on stuff like this, so I like your idea of being able to prove it with a scangauge (which obviously I don't have). This issue is kind of hard to search the threads for...
    Thanks for your input.:D
  7. Feb 18, 2010 at 1:00 PM
    RelentlessFab
    Eric
    Sparks, NV
    Well I was talking about a 2nd gen, but 2 guys I know have 1st gens, 1 w/ the 2.7 and one with the 3.4, that have scangauges. I try and see what theirs reads on decel next time im in their trucks.:cool:
  8. Feb 18, 2010 at 1:18 PM
    scocar
    scocar hypotenoper
    Dood, that would be awesome. Thanks.:thumbsup: I think half the confusion about techincal dicsussions on this site results from cross-generational vagueness and assumption. Just go check out the hubcentric lugcentric discussions....:goingcrazy:
    I'm sure lots of puzzled first genners without scangauges would appreciate the info.
