Gas cutting out while driving
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROBBS-COMA, Apr 12, 2019.
  1. Apr 12, 2019 at 5:39 AM
    ROBBS-COMA
    ROBBS-COMA [OP] Well-Known Member
    ROBB
    Bethlehem PA
    2008 TACOMA 4DOOR TRD SPORT 4X4
    NONE YET
    Hi all, I've searched the forum quite a bit now and cant seem to find an answer. So i'm bringing it to the GURUS. Noticed while im driving or a quick right turn, the gasoline seems to shut off, I let go of the pedal and depress it again and it's fine. Its happening alot now these past few days. Anyone have an idea what it might be? (no check engine lights on or come on when it happens)
  2. Apr 12, 2019 at 5:40 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Possibly clogged fuel filter or fuel pump going out? It is located on the right side of the gas tank which would make sense why your vehicle shuts off only on right turns.
    El Duderino, Tigerian and Biscuits like this.
  3. Apr 12, 2019 at 6:36 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    Thanks, didnt know its located there. I'll start with the fuel filter first.
  4. Apr 12, 2019 at 7:06 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    There’s no fuel filter other that the one located on the fuel pump inside the tank.
    wilcam47 and will.i.was like this.
  5. Apr 12, 2019 at 7:07 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    So I have to go into the tank regardless, no way around that?
  6. Apr 12, 2019 at 7:08 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    correct. if you are going that deep may as well grab a URD fuel pump upgrade and replace the fuel pump and get an external filter setup at the same time. This is my plan around 100k miles which is coming up soon. a DW pump / kit from them.
  7. Apr 12, 2019 at 7:15 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    This is what baffles me, I read that it should be done at or around 100K but mine is just over 84k. Do it anyway just to "filter' out the problems. Haa see what I did there?
    Torspd and BassAckwards like this.
  8. Apr 12, 2019 at 7:18 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  9. Apr 12, 2019 at 7:40 AM
    nd4spdbh
    SoCal
    Yup thats it! I was going to opt for the Deatschwrks 255 pump as its E85 compatible and aparently quieter than the walbro 255 (not that id run E85, but extra ethanol protection is good in my book with lovely CA gas).
    and then i was also going to run a plastic flexible hose for pump to housing like stock rather than the submersible rubber line
    https://www.tacomaworld.com/threads/improving-the-urd-fuel-pump-kit.308651/
    Torspd, DriverSound and TireFire like this.
  10. Apr 12, 2019 at 7:49 AM
    nd4spdbh
    SoCal
    see
    TireFire[QUOTED] likes this.
  11. Apr 12, 2019 at 7:53 AM
    Muddinfun
    Muddinfun Well-Known Member
    Lightly push the brake pedal with your left foot while driving and see if it does the same thing.
    Torspd and DriverSound like this.
  12. Apr 12, 2019 at 7:58 AM
    nd4spdbh
    SoCal
    yeah true it could be a faulty brake light switch too.
    Jimmyh likes this.
  13. Apr 12, 2019 at 8:29 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    Yup it did it when i iressed on the brake, what now ?
  14. Apr 12, 2019 at 8:56 AM
    Muddinfun
    Brake switch needs adjusted.
    Torspd likes this.
  15. Apr 12, 2019 at 9:06 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Are you sure you have enough oil in the engine? Oil sloshes away from the oil pump intake when turning, sending unit sees low oil pressure and cut out the engine
  16. Apr 12, 2019 at 9:20 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    I can adjust the switch, what I don't understand is how does that lead to gasoline cutting out.
  17. Apr 12, 2019 at 9:21 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    Yup, just had Toyota do an oil change 2 weeks ago.
  18. Apr 12, 2019 at 9:33 AM
    Muddinfun
    It's Toyota's answer to "unintended acceleration". Ever since the guy killed his family because the throttle stuck and he was too stupid to put the trans in neutral, Toyota fixed it so that if you're on the brakes, it cuts the throttle.
  19. Apr 12, 2019 at 9:36 AM
    ROBBS-COMA
    ROBB
    Bethlehem PA
    NONE YET
    I get that but it still doesn't explain why it does it when just driving normally without using the brakes. Comes and goes.
  20. Apr 12, 2019 at 9:38 AM
    Muddinfun
    The switch is adjusted right on the edge of closed/open. When you go around a corner, the slop in the brake pedal causes the brake pedal to swing and the switch closes.
