Gas door hing rusty?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07SpeedwaySport, May 23, 2011.
  1. Apr 8, 2014 at 5:40 PM
    #41
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks for the reply Oz. Are hinges what you like it for :confused:
  2. Apr 8, 2014 at 6:34 PM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I've used it on hinges , tools , leaf springs , frame , toolboxes , tons of stuff
  3. Apr 9, 2014 at 1:00 AM
    #43
    george3
    New Jersey
    Thanks
  4. Apr 10, 2014 at 6:28 AM
    #44
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Thanks guys! I have over a dozen cans of Fluid Film at home, but haven't thought to spray it on my squeaky fuel door. Just coated the hinge and the entire inside of the fuel door with it last night. It opens smooth as butter now, no squeaking.
    I have to say that is one flimsy looking door hinge, better to keep up on it now while the truck is new before rust issues set in.
  5. Apr 10, 2014 at 7:10 AM
    #45
    1ToughTRD
    1ToughTRD Well-Known Member
    Chad
    Pittsburgh
    '13 TRD Sport
    (gone but not forgotten)
    Just had the fuel door hinge freeze from rust and then I bent the hinge opening it. This was on a '13 with about 32K miles, luckily it was replaced under warranty. And gas was never spilled on it, I do live in the rust belt though. As someone previously stated, they had to order the whole assembly and have it painted prior to install.
  6. Apr 27, 2015 at 3:22 AM
    #46
    TruckChick
    TruckChick Member
    Ah damn, mine just rusted off of my '07! I might try to get a welder friend to make new hinge brackets. Has anyone had luck with other solutions besides just buying a whole new fuel door?
  7. Apr 27, 2015 at 6:43 AM
    #47
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You can try welding, but that metal is way to thin, and you need everything perfectly aligned. I would say try it but be prepared for buying new door.
  8. Apr 27, 2015 at 7:33 PM
    #48
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Wow. Nobody ever hear about maintenance?
  9. Apr 27, 2015 at 9:42 PM
    #49
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Most drivers aren't that handy or savvy. And they shouldn't have to be. Its 2015 and the world is full of modern materials that wont corrode. People expect that simple things like fill cap doors, like those installed by every other manufacturer, wont rust and fall apart in just a few years. Same goes for frames. Modern materials and coatings have all but eliminated frame rot for every other manufacturer.
    BrookTrout likes this.
  10. Apr 27, 2015 at 11:48 PM
    #50
    Jimmyh
    SC
    2012 Prerunner SR5
    No it hasn't, all makes and models of cars and trucks rust.
    Really how much effort does it take when you fill up the gas to at least observe what is going on. Dab a little bit of white lithium grease on it every 6 months and call it good.
  11. May 1, 2015 at 11:56 AM
    #51
    TruckChick
    TruckChick Member
    I live at the ocean, i 4x4 on the beach, my '07 is from here originally.. its no surprise this part rusted for me, but I'm surprised other people have had the same issue. Nothing else on my truck is rusty, and my '88 has no rust problems. If I'd known the fuel door hinge would be a problem, I woulda greased it!
  12. May 1, 2015 at 1:38 PM
    #52
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I agree and disagree with you here. I have owned dozens of vehicles. Had plenty of trucks and cars over 300k miles. And you know one thing I have never in my life done? GREASED/OILED MY FILLER CAP LID. NEVER. Never had one rust off, or get stuck in my life. Seems like this is a poor design but at the same time a preventable problem.
    BrookTrout and TruckChick like this.
  13. May 1, 2015 at 2:26 PM
    #53
    fizik
    fizik Accidental Offroader
    Minnesota
    '13 DCSB SR5, '10 DCSB TRD OffRoad (deceased)
    The fuel door rusted so fast on my brand new 2010 that I was able to get it replaced under warranty. I recently purchased a used 2013 Taco and it was just starting to show signed of rubbing. Lubed it and it has been OK since. Having said that... I've never lubed the fuel door hinge on any of my other vehicles (going back to the 1980s... many of which were well over 10 years old before I sold them) and never had a problem until the Taco. Even the fuel door on Ma's 2006 Camry was as good as the day it was new when she traded it in last year.
    OTOH, I'm not replacing front end parts every other oil change like I was with the Mountaineer.
  14. Aug 11, 2017 at 5:23 AM
    #54
    BrookTrout
    BrookTrout Active Member
    Brook
    West Michigan
    Just bought a used 2011. The bottom hinge on the fuel door was/is rusting and rubbing. I cleaned it the best I could without doing more damage and put mountain bike grease on it. I know white lithium is the standard auto answer for this, but I like this bike grease better if you don't want to spray the lithium.
  15. Aug 11, 2017 at 5:47 AM
    #55
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    mine started to bind and broke off, poor hinge choice IMO
    I am going to try some Velcro soon since I don't like it missing
  16. Aug 11, 2017 at 5:56 AM
    #56
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Not sure why people get mad about this. Its the same as never changing your oil and then getting mad at Toyota that your engine seases.
    You need to maintain all parts of the truck. If you don't take care of your paint, it will degrade and the underlying metal will rust.
    Grease the door regularly and touch up any paint chips.
  17. Aug 11, 2017 at 6:02 AM
    #57
    knottyrope
    Knotty
    Bahstun
    people in New Jersey would never know since they cant pump their own gas
    never lubed up a fuel door on any previous vehicle
    Blockhead and BrookTrout like this.
  18. Aug 11, 2017 at 6:09 AM
    #58
    BrookTrout
    Brook
    West Michigan
    This is my first Toyota and the first vehicle I have ever had to do maintenance on the fuel door. And trust me I have driven some serious high mileage vehicles that were only kept on the road because of maintenance.
    I do hope to keep this truck on the road well past 300K. That's part of the reason I'm here to learn the tips and tricks to do that.
  19. Aug 11, 2017 at 8:58 AM
    #59
    knottyrope
    Knotty
    Bahstun
    my 95 F350 fuel doors work fine at 307k miles
  20. Aug 12, 2017 at 7:14 AM
    #60
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    I just replaced mine because i could barely open it. 2012, 94k. It was $99 at a body shop and took them 15 mins to swap out. Whole new door and hinge.
    edit: i had the same issue on my 11 while it was under warranty still and toyota replaced it.
    Muddinfun likes this.
