gas/injector cleaner and treatment suggestions?
Discussion in '4 Cylinder' started by norcal4banger, Apr 19, 2011.
  1. Apr 19, 2011 at 8:10 PM
    norcal4banger
    norcal4banger [OP] 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    I'm wondering if this could help my recent idle problems and at least help clean shit out. Have you guys used Injector or gas treatment or cleaners? If no one knows what I'm talking about, its like this:
    What should I use? What do YOU use?
    **2.7 Four Cylinder 120k miles
  2. Apr 19, 2011 at 8:16 PM
    norcal4banger
    Jack
    Just at any autozone or something? I wonder if fuel injector cleaner is even the stuff I should use....maybe gas treatment or something?
  3. Apr 19, 2011 at 8:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd check the air filter and maf sensor. you'll get a rough idle and bad mileage if the maf is dirty. as for something for the gas tank......i've used seafoam and berryman b-12 chem-tool....and occasionally some techron.\
    seafoam is awesome.....the berryman is better for lawnmowers carbs and such.
  4. Apr 19, 2011 at 8:28 PM
    purple taco
    purple taco Well-Known Member
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    weapon-r intake,allpro 3"leaf springs,magnaflow exaust,ss break line,billy 5100's,allpro 1.5 greasable shackles,rear diff mod,u bolt flip kit,eibach 3"spring,light racing uca.blhm,plasti dip front/rear bumper, painted stock rims,04 gauge swap w/led,billet grill,tinted tail lights,bench to 4runner bucket seat,lockrite locker,bpv relocate,roof light bar/w 4hella 500ff,33x12.50r15 duratracs.
    Try seafoam it helped with my idle. Got it at wall mart.
  5. Apr 19, 2011 at 8:31 PM
    purple taco
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    Tacoman knows what he talking about.
  6. Apr 19, 2011 at 8:31 PM
    norcal4banger
    Jack
    air filter is the aFe dry drop in replacement, i installed it maybe a month ago. toyota just changed the plugs about two weeks ago and the idling issues started about a week ago, I'm gonna take a look at the plugs in the morning.
    Maybe I'll fill up next with some premium chevron...if that will make a difference. How do I check and what is maf?
  7. Apr 20, 2011 at 10:56 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Most idle problems can be resolved by cleaning as illustrated above. You said Toyota just changed the plugs, and a week later the problem started? Probably not the plugs then, since it was not a problem until a week after install, but you could double check the gaps just in case the Toyota Monkey did not. A good fuel system cleaner may also help clean out any deposits a 120,000 mile plus motor normally may have in the fuel injectors, etc. All this should resolve your issue...:cool:
  8. Apr 20, 2011 at 11:00 AM
    AC13JohnG
    AC13JohnG Señor Member
    Black 5 lug
  9. Apr 20, 2011 at 11:04 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    a lot of these additives dont actually work..ive seen a video on youtube where they tested various brands and the results all suffered -2%..i would just get some better oil and make sure its changed on time!
  10. Apr 20, 2011 at 12:25 PM
    norcal4banger
    Jack
    What would be a good oil to change to for my motor? I use Quaker State 530 now, and I do about 12000 miles every 6 months.
  11. Apr 20, 2011 at 12:52 PM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    if you can afford it,royal purple is great..if not,mobile 1 is half the price and just as great..if you treat your rig with just the basics like good quality gas and oil,it wont need the other additives,so splurge on better gas and oil..especially with the modern day engines,they are more advance than the older ones that did need an extra boost
  12. Apr 20, 2011 at 12:56 PM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    do what PSJ recommended though..clean the MAF and throttle,it will make a difference and in MPG's as well..im completely forgot to mention that
  13. Apr 20, 2011 at 1:01 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Seafoam helps a rough idle.I've used it in many generators that have sat for long periods and it straightens them right out.
  14. Apr 20, 2011 at 2:45 PM
    PurpleHayz
    PurpleHayz New Member
    Durham
    2011 SR5 5-lug 5spd
    Seafoam is decent, but Mopar Combustion Chamber Cleaner is the best I've seen (much better expansion). Lotta gear heads use the stuff (see here) though I don't advise you to do this in your garage, or even your neighborhood.
  15. Apr 20, 2011 at 5:56 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Run Dino and change the oil and filter every 4-5000 miles. Any top quality oil and filter will be fine. :cool:
  16. Apr 22, 2011 at 10:11 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Might not be a bad idea to check for any hoses that might've worked loose and could be causing vacuum leaks. Changing the spark plugs requires removing the intake silencer on top of the valve cover. The silencer has two little vacuum lines (sans clamps) that connect to sensors which, in part, help control idle and emissions. Also, the auxilary PCV "overflow" hose is connected to the rear of the silencer with a very weak clamp.
    Also, you can check the spark plug gaps, but don't try to gap them. If the dealership replaced them they're probably the stock Iridiums and will break the tips off inside the cylinder if you try to gap them.
    Clean the throttle body manually, clean the MAF sensor, and make sure that you didn't get any water-laden gas. I have used Techron with some success in the past, but am by no means trying to convince you to use it. These days most fuels have all of the detergents needed to keep the injectors and valves fairly clean, if you don't have a direct injection engine (which we don't).
