gas light on, how long til truck dies?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StatutoryAPE, Mar 4, 2011.
  1. Mar 4, 2011 at 3:24 PM
    StatutoryAPE
    StatutoryAPE [OP] Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    The other night i was driving home from work and my gas light came on. I was on the freeway driving 55 and set the trip. I didn't wanna stop to fill up yet cuz i didnt wanna use my credit card and if i waited until midnight i would get my direct deposit. so i decided to cruise and see how long i could go. I made it 16 miles with the light on and i finally pulled over to filled up when the clock hit 12.
    Has anyone ever recorded how long it takes for the truck to die when the fuel light is on
    I have a 3.4 auto xcab w/ 32's, cai, superturbo muffler.
  2. Mar 4, 2011 at 3:26 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i wouldnt want to chance it any more then you did..You may have made it another 5 or so miles?
  3. Mar 4, 2011 at 3:39 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    my gas light likes to play games. it will come on and off for like 15 miles and then it finally stays on, once it finally stays on i will fill up and i usually fill up about 16 gallons. If i fill up when the light first starts to come on and off i will usually fill up about 15 to 15.5 gallons. But you really need to know what your initial mileage is so you can figure out how far you could actually go. But like Christian said, dont run it too low for too long or too often, you'll burn your pump up!
  4. Mar 4, 2011 at 3:45 PM
    r6jon
    r6jon Member
    Jon
    West Linn, OR
    02 PreRunner SR5 TRD
    The farthest I've gone with the light on was 48 miles and the tank took 17.5 gallons of fuel. I average 18.5 mpg.
  5. Mar 4, 2011 at 3:53 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    i thought the capacity was only 17 gallons?
  6. Mar 4, 2011 at 4:34 PM
    saltshaker
    saltshaker Well-Known Member
    johnny
    north carolina
    2011 TRD Off Road MGM AC
    AFE CAI, Fold-a-cover
    I work exactly 25 miles from home, after the light comes on to stay on my first gen I can go to work and back and drive around town a bit.
    But ima tell you, I get so nervous every time I look at that light my butt-hole draws up!
  7. Mar 4, 2011 at 4:36 PM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax, 1977 FJ40 Landcruiser
    Christ, fellas. Do a search on the topic. There are a lot of miles left after the light comes on...
  8. Mar 4, 2011 at 4:41 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Seriously! If you want to help others... then tell us HOW MANY GALLONS you put in when the light comes on. In your owner's manual it will tell you how many GALLONS your tank holds... I had a 2001 and it was a 20 gallon tank. I don't recall the point the light came on, but it was and is still between a 1/4 tank line and the E LINE on the gauge (which is still 2-3 gallons left in the tank).
    Now, my 2010 is a 21 gallon tank. The E light comes on always when I am down to 4 gallons left in the tank (17 gallons to fill)... At 17 MPG that means I can drive 68 miles before running out... Something NOBODY should ever do!
  9. Mar 4, 2011 at 6:49 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    my tank is 21 gal
  10. Mar 4, 2011 at 7:46 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Not too mention all the sediment and contaminants settle at the bottom so when you run it low on purpose all that gets sucked through your injectors..
  11. Mar 4, 2011 at 8:48 PM
    r6jon
    r6jon Member
    Jon
    West Linn, OR
    My manual shows 18.5 gallon fuel cells for 4WD and prerunner models.
  12. Mar 4, 2011 at 8:56 PM
    fltacoma
    fltacoma Well-Known Member
    daniel
    Shreveport, LA
    no truck as of yet :)
    1st gens and 2nd gens have different size fuel tanks.
  13. Mar 5, 2011 at 1:05 AM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    My low fuel light never comes on ;)
    Because I usually never let it get that low and because I don't think that the light works. lol
  14. Mar 5, 2011 at 10:10 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Neither does mine, but I think it must be broken. I'v intentially ran it as low as possible, finally filling up and putting in 17.4Gal!
    Is there an easy way to check the "low fuel" light to see if it is blown?
  15. Mar 5, 2011 at 10:16 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    4 minutes
  16. Mar 5, 2011 at 10:17 AM
    dustinclm
    dustinclm Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    '01 prerunner: i have a 18.5 gallon tank and if i fill up when the gas light comes on the first time i put 15.5 gallons in. so 3 gallons left in the tank until dry so multiply 3 gal. by what every your mpg is and BAM thats how far you can go,
  17. Mar 5, 2011 at 10:18 AM
    dustinclm
    Thibodaux, La
    :rofl:
  18. Mar 5, 2011 at 11:20 AM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    OMG There is a gas light? I never knew. haha
