Gas mileage upgrading from 16 x7 stock wheels to 17 x 8.5 SCS wheels
Discussion in 'Wheels & Tires' started by Hawkvenom, Jun 30, 2014.
  1. Jun 30, 2014 at 1:22 PM
    Hawkvenom
    Hawkvenom [OP] Member
    I have a stock 2012 v6 base prerunner 2wd double cab and I’m planning to upgrade my stock 16 x 7 wheels to 17 x 8.5 Stealth SCS wheels and was wondering if this will affect my gas mileage. I drive on the highway 50 miles a day so gas mileage is important. Below is my stock setup and what I plan to upgrade to. Will 4 pounds the extra weight make a difference. Any input is appreciated. Thanks.
    Stock wheel weight 16x7 : 32 lbs
    Stock tire weight 245/75/16: 23 lbs
    Total: 55 lbs
    SCS wheel weight 17 x 8.5 : 23 lbs
    Tire weight 265/65/17: 36 lbs
    Total: 59 lbs
  2. Jun 30, 2014 at 7:12 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    You will lose a little, probably like 1-2mpg. It's not just the weight, you going to taller tire. That weight for your stock tires doesn't seem correct. What tires are you looking at that are 36lbs?
    I went from stock wheels with 265/70/16 tires to SCS with 265/70/17 and I've lost about 1.5mpg. My tires are heavy though, might swap to something lighter to hopefully negate the loss in mpg a little.
  3. Jul 1, 2014 at 8:50 AM
    Hawkvenom
    Thanks for the reply. I was looking at the Dunlop Grandtrek AT20 which was 36 lbs. according to tire rack.
  4. Jul 1, 2014 at 8:56 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    if you upgraded to a 265/70/17 it might help your mpg a little. at least it did with me. 40lb tires, with 27ish i think, maybe heavier 17x9in rims and i get 19-21mpg on the highway. your speedometer will be dead on also, but your odometer will be off a little. multiply how far your odometer said you went by 1.04 and thats how far you really went. doing that also shows your correct mpg again.
  5. Jul 1, 2014 at 9:03 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    You ae correct on the weight of that tire. The overall diamater is 30.47 on your tires now and the new ones 30.56 and with the new width only being about 3/4" wider you shouldn't loose much at all if any.
  6. Jul 1, 2014 at 9:19 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You got your stock tire weight numbers flipped. Dunlop AT20 245/75-16 is 32 lb, not 23 lb. http://www.tirerack.com/tires/tires...ehicleSearch=false&fromCompare1=yes&tab=Specs
    The SR5 silver steel wheel is 29 lb according to this thread: http://www.tacomaworld.com/forum/wheels-tires/30754-wheel-specs-8.html
    Putting it all together:
    Stock wheel weight 16x7 : 29 lbs
    Stock tire weight 245/75/16: 32 lbs
    Total: 61 lbs
    Conclusion: You might actually gain milage with the wheel/tire upgrade.
  7. Jul 3, 2014 at 6:04 AM
    P33Rob
    P33Rob Well-Known Member
    Rob
    Watertown, NY
    13 Tacoma V6 TRD 4X4
    OME 3" Lift; Maxfit aeromax; Volant CAI w/scoop; TRD Exhaust; Step rails; SCS stealth 6 wheels; Bedrug
    Unless your now running LT compared to P rated tires i have those wheels and they are way lighter compared to my stock 17s. But when I put LT tires on I lost MPG from now on I am gonna keep P rated and save my LT for offroad and snow.
