Gas Mileage??? WTF
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Nov 22, 2010.
  1. Nov 22, 2010 at 3:32 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
    hey guys i've got a lifted 98 3.4l v6 with 33's.it has an magnaflow eshaust with complete K&N cold air intake (see pics). i just figured out the miles per gallon and im get about 8.5 at very best. I'm mostly driving to school and to friends house around town. Very few stop signs. So i was wondering whats going on? Its a manual and i usaully dont shift into 2nd and 3rd untill 2800-3100 rmps and i mostly drive around in 4th doing about 2100 rpms. is it my driving?
  2. Nov 22, 2010 at 3:41 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    it's the 33's and the v6....but still that's bad
    i'm trying to figure out why i'm only getting 15/16mpg....all stock with 265/75's..auto and a light foot most of the time
    might need a full tune up: filters, spark plugs, cap/rotor...i think those are dist motors not coil packs
  3. Nov 22, 2010 at 3:51 PM
    bowhunter11199
    ya i've be adding those gas addatives that are suppose to clean everything out. and the spark plugs are about 15,000 miles. so i dont know. mabey im a little heavy on the peddle but i drove my dad truck( 2006 f 150 2 in lift 32's v8) and it got about 13-14.
  4. Nov 22, 2010 at 4:50 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You may have an exhaust or intake leak. Anything that could cause the O2 to read lean will cause poor mileage.
  5. Nov 22, 2010 at 5:14 PM
    bowhunter11199
    so any ideas. like places/ things to check. or should i take it into the stealership or local auto store?
  6. Nov 22, 2010 at 5:19 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Check for exhaust leaks before or close to the O2 sensor. But you may need to take it in so they can hook up a scantool and watch the readings.
  7. Nov 22, 2010 at 5:31 PM
    bowhunter11199
    ill go through and change some stuff and see if it helps out but if i take it in do you have any idea what it would cost for them to figure out whats wrong/ fix it?
  8. Nov 22, 2010 at 7:41 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Keep your foot out of it, stock tires on mine in town 17.6-18.2 all city and I keep it as close to 2k rpms as possible. I expect that to drop a little as the weather gets colder.
  9. Nov 26, 2010 at 9:30 PM
    bowhunter11199
    i have tried shifting into 2nd in 2000 rpm its kinds jerky and it puts a lot of strain on the motor (and slow exceleration) cuz i still have stock gear ratio(4.10) but i dont think shifting a 3k rpms isnt that bad it would drop me to 8-9 mpg
  10. Nov 27, 2010 at 6:05 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Did you get your odometer calibrated after your tire upgrade? It wouldn't be off by much, but it would affect your mileage if you've gone father than it reads.
    I hotrod in my truck and it still gets 12-14 in town. It's stock with exhaust but that shouldn't matter too much.
  11. Nov 27, 2010 at 11:54 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I also have a lifted 98 V6 3.4L w/33's and this is what I get:
    City 12mpg
    Hwy 16mpg
  12. Nov 27, 2010 at 2:03 PM
    ricktaco
    ricktaco Active Member
    Oregon
    96 Tacoma 4x4
    Wow, this makes me think something is wrong with your truck. I have a 4x4 V6 96 model and I get 20 mpg in town. Don't drive on the highway so no idea what that would be.
    I run 31's but 33's can't hurt mileage THAT much.
    Maybe take it in and have it put on a diagnostic system to see if they can determine what's going on.
  13. Nov 27, 2010 at 7:43 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I might have done my calculations wrong...I'll track a couple fill ups on fuelly.com and post the results...
  14. Nov 28, 2010 at 8:02 AM
    1welder
    1welder Well-Known Member
    tony grace
    edgewood, tx.
    98' ext. cab
    toytec coilovers, bil 5100's, dakar leafs, e-locker rear,aussie front, 4x innovations sliders,cooper stt's 32x11.5x15, max 4 marathon seat covers,
    i also have a 98' with 3.4 w/32's. my truck never sniffs 3000 rpms and all i get is 14mpg. sea foamed it about a month ago with no real results i dont think. plugs probably got 10000 miles on them, air filter is clean. i cleaned the MAF about 5000 miles ago. has anybody replaced the O2 sensors with good results?, wanted to ask before i did it because they are a little pricey.
  15. Nov 28, 2010 at 8:22 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    my gas mileage barely changed at all from the stock size tires to 285's. it isnt ur driving, i shift at 3k for every gear. u could try removing your o2 sensors and giving them a cleaning before replacing them,since theyre fairly expensive.
  16. Nov 28, 2010 at 8:49 AM
    sctrdtaco03
    sctrdtaco03 Ah yeah that guy
    scott
    Port Orchard,Wa
    Taco
    first gen trd supercharger throttle body coolant delete gray wire mod rear diff breather extension King coilovers All pro uca's toytec 2" shackle extension rear billy 5100 water meth injection urd 6 injector upgrade other assorted goodies custom AZ pinstripe on sides
    I would go with a vacuum leak or exhaust leak I have 33's and a s/c and have a lead foot and get around 15mpg average.
    Spray carb cleaner around your vacuum lines see if the rpms change then look close at your exhuast see if there is black soot around a crack or anything. Besides that it could be a sensor throwing a lean condition in. just my 2 cents
  17. Dec 1, 2010 at 6:33 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    20 mpg City!!! that's amazing...You've well exceeded 15 mpg Edmunds specs...
    http://www.edmunds.com/used/2002/toy...156/specs.html
  18. Dec 1, 2010 at 7:00 PM
    ricktaco
    Oregon
    96 Tacoma 4x4
  19. Dec 1, 2010 at 10:14 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    How do you adjust the speedo. Mine seems to read low.
    Flash
  20. Dec 1, 2010 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Its not like the old days where you had speedo cable coming out of the back of the tranny. Its all fly by wire now.
    There is no way to adjust the speedometer/odometer in our trucks.
