Gas Mileage!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by cclax2145, Aug 14, 2008.
  1. Aug 14, 2008 at 9:27 PM
    cclax2145
    cclax2145 [OP] Well-Known Member
    Houston
    2002 prerunner SR5 Blacked out
    Deckplate mod, K&N drop in, blacked out tails and emblems, 3 inch toytec spacer/AAL lift, Alpine head unit, Boston acustics speakers, and 10 inch image dynamics sub (in custom seat/box), Alpine EQ, Flowmaster 40 series, and viper alarm system, 33inch bfg MTs, 15inch black steelys
    Hi ive got a 2002 tacoma pre runner v6 and ever since i bought it used at 60k miles i have been getting about 13 miles to the gallon city and im just not sure if this is normal for this model or if there is something wrong. Any help would be worth a lot. thanks
  2. Aug 14, 2008 at 9:32 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How many miles do you have on it? Have you changed the plugs, kept it properly maintained, properly inflated the tires, etc.?
  3. Aug 14, 2008 at 9:54 PM
    cclax2145
    Houston
    My truck now has 65k miles on it. Yea i recently looked at the plugs and they looked fine but im going to replace them tomorrow. Ive been keeping the tire pressure at the recomended pressure also.
  4. Aug 14, 2008 at 9:55 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    How's the airfilter look?
  5. Aug 14, 2008 at 9:56 PM
    cclax2145
    Houston
    just replaces it along with doing the deckplate mod.
  6. Aug 14, 2008 at 10:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    replace the fuel filter and switch over to synthetic and gear oils, as this will help some!! also......maybe put in a high flow air filter.....like the afe pro dry s!
  7. Aug 14, 2008 at 10:27 PM
    cclax2145
    Houston
    thanks do you think the fuel filter could help alot or could this be a bigger problem.
  8. Aug 14, 2008 at 11:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not necessarily.... unless you have some debris in your gas tank that's clogging up the system (filter/pump/etc)..?? Changing the fuel filter is relatively easy to do yourself and it's peace of mind.
    Auto or manual?
    Amoung everything everyone else has already said....
    How about running some fuel treatment /fuel injector cleaner through the tank?
    Call around to some of the auto stores and ask them if they still do FREE diagnostic screenings to read trouble codes on your computer. I'm not sure if they still do that. And...ASK them if their *Reader* will give you a history of codes (since your CEL light isn't currently on).
    The next thing...is to check your exhaust somehow to make sure it's breathing properly (CAT, muffler, etc). I think that has something to do with reading the intake vacuum? I have no clue...and would have to research that myself.
    How's the truck feel on power?
  9. Aug 15, 2008 at 9:48 AM
    cclax2145
    Houston
    Its an automatic and yea ive ran a total of 2 cans of that techron fuel injector cleaner. Tomorrow im going to change my spark plugs change the fuel filter, and just do any thing else that needs to be done. And i will reply back with how it goes.
  10. Aug 15, 2008 at 9:52 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    something else you can do...........get some seafoam and run some thru the brake booster line. that will clean out the intake pretty good. but also, get some seafoam deep creep and clean the throttle body really good. this will help greatly too man!!
  11. Aug 16, 2008 at 12:55 AM
    cclax2145
    Houston
    Thanks do u know of any forums or sites were people have documented how to clean the throttle body or could i just do it with the taco repair and maintnes manual
  12. Aug 16, 2008 at 4:36 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
  13. Aug 18, 2008 at 12:07 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    You might try increasing your Tire PSI.
    For better MPG you need to increase allot, but no so much it makes your tires where funny.
    Also normal tire loose 1-2 PSI every 30 days. So keep up on refilling with filter air.
    So the least amoutn of water get in the tire.
    Also play around with Spark Gap. if you ahve added other mods in to increase
  14. Aug 19, 2008 at 11:35 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Most of the time I get 18 to 19 MPG on my truck. That is combined city & freeway though, and also the truck is stock.....
  15. Aug 19, 2008 at 12:08 PM
    baloo
    baloo Member
    N. Illinois
    01 Taco 4dr 3.4L FlexFuel
    FlexFuel Conversion ISR mod DeckPlate Mod TrueFlowAir Filter XM/Sirius ScanGauge II Roadmaster Rear Suspension LINE-X Bedliner LINE-X'd Steptubes LINE-X'd bullbar LINE-X'd fender flares
    Ditto this. When using "recommended" tire pressure, go with the MAX pressure as printed on the sidewall of the tire, not the door tag.
  16. Aug 19, 2008 at 2:46 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I've been getting about the same mileage too. Last time I checked I was getting about 15, mostly city. I'm ganna put a bit more air in my tires, since there all at around 35 psi. See if it helps. Also get some fuel injector cleaner. I know that my plugs got changed at 90K miles, Im at just over 100k right now. So I dont really now what else I can do. I even cleaned the TB and AMF sensor.
  17. Aug 19, 2008 at 3:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    use some techron....good stuff, and have you changed your fuel filter??
  18. Aug 19, 2008 at 4:55 PM
    ETaco23
    Evan
    PNW
    no I havent. Is it farely easy to do?
  19. Aug 19, 2008 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    WHAT? Keep the plugs gapped at what is recomended. You are gonna open up a weird can of worms if you strat "playing" around with your spark plug gap.
    :rolleyes: Dont just "MAX" your tires. Use a ckalk or paint mark to find the correct psi for you tires. Maxing your tire psi can adversly affect handling and performance of the truck.
  20. Aug 19, 2008 at 5:05 PM
    YoYo_32757
    YoYo_32757 Well-Known Member
    So true! If you crash...you go BOOM!!!!!
    Not good....you might as well be kite surfing in a tropical storm.....
    Sorry...that's already been done.
