Gas Octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BreezyTaco, May 9, 2009.
Which fuel octane do you use?
  1. 87
    2,159 vote(s)
    64.4%
  2. 89
    454 vote(s)
    13.5%
  3. 91
    773 vote(s)
    23.1%
  4. Other fuel additives
    57 vote(s)
    1.7%
  1. May 10, 2009 at 8:31 PM
    #41
    BreezyTaco
    BreezyTaco [OP] Well-Known Member
    Corpus Christi, TX
    Pioneer Indash GPS, JL Audio Speakers, FM Alarm, Euro Tail lights, Blue Dash Lights, Trailor Hitch, Painted Fiberglass A.R.E. Tonneau Cover
    Besides the gas octane given at the pump, what about other additives? Such as STP Octane boosts, is it for real or a scam? On ebay they sell these little magnet like things that clamp to your fuel hose, and supposedly align the hydrocarbon in the fuel, and thus promotes better mpg...scam or the real deal? When should you get your fuel injectors cleaned as well?
    #41
  2. May 10, 2009 at 8:33 PM
    #42
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont have a link for it....search on the 1GR-FE engine, and you should find stuff...
    The 1GR-FE is rated at 236 hp on 87 and 239 on 91. Torque is up 12 or so with 91 also.
    See this post:
    http://www.tacomaworld.com/forum/pe...0-87-vs-89-vs-91-octain-fuel-my-findings.html
    Over the summer I have been testing to see the "real world" difference between the 3 grades of fuel. My tests were done on a 155 mile loop from an elevation of 1080 ' up to 5500' and back. Average speed was targeted at 68 mph. Up hills I maintained 80-90. down hills I maintained 70. Temps for all three tests was 105*. Hills ranged from gradual to 6.5%. During this loop, the truck was being pushed pretty good, as anyone in AZ who has driven up north can attest to the amount of hills and twisty roads.
    87 octain yeilded 15.12 m.p.g.
    89 octain yeilded 15.51 m.p.g.
    91 octain yeilded 16.61 m.p.g. *
    *note: On the 91 oct. test, I was loaded with 200 lbs. more stuff than the other 2 tests, and still received better mpg.
  3. May 10, 2009 at 8:35 PM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    http://en.wikipedia.org/wiki/Toyota_GR_engine
    The 1GR-FE is the 4.0 L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane.
  4. May 10, 2009 at 8:37 PM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The magnets are a scam. I never use addatives in my fuel, as the Fuel companies are required to have a minimum amount of cleaners and detergents in the gasoline they sell. All "Top Tier" fuels are good, and what I use, without adding anything else to the tank.
    #44
  5. May 10, 2009 at 8:42 PM
    #45
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Word, I use 91 q time.
  6. May 10, 2009 at 10:32 PM
    #46
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Exactly why I still run 91 regardless. :)
  7. May 10, 2009 at 11:09 PM
    #47
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I couldn't tell a difference when I tried 91 octane. So I use 87.
  8. May 10, 2009 at 11:19 PM
    #48
    genxer36
    Sean
    Bethlehem,GA
  9. May 11, 2009 at 2:28 AM
    #49
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    On the manual fuel specs, it says "87(research octane number 91)". I'm sure Toyota wouldn't do their spec research with 91 octane if they didn't think it would produce better results.
    I got an average of about 19mpg with 91 octane compared to about 17.5mpg's with 87 octane.
  10. May 11, 2009 at 7:34 AM
    #50
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The ECU will adjust....
  11. May 11, 2009 at 7:54 AM
    #51
    geoff5093
    geoff5093 Well-Known Member
    Goffstown, NH
    2013 Subaru BRZ
    Mileage varies greatly, when I drive conservatively and don't drive 70+ on the highway I can obtain anywhere from 20-22MPG with 87 octane.
  12. May 11, 2009 at 9:04 AM
    #52
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I normall run 87. 89 just seems like a waste...2 higher for 10 more cents a gallon? no thanks. If im gonna spend a little more might as well go with the 91
  13. May 11, 2009 at 11:04 AM
    #53
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Even at the gas station they try to scam you with the amount of cleaning additives on different octanes but a lot of people don't know that it the fuel only comes out of ONE hose, the amount of cleaning detergent has to be all equal even though they come out of different tanks. I've read a report on this somewhere when I researched ethanol gas. Also in California, I think we only get 87,89,91 and 100 over here and 100 is a rare find and labeled as racing fuel. We don't have 93.
    Here's some good reads on fuels, additives, etc...
    http://www.vettenet.org/octane.html
    http://www.nsxprime.com/FAQ/Miscellaneous/FuelAdditives.htm
    http://dirtbike.off-road.com/dirtbi...ACE-FUE/ArticleStandard/Article/detail/331518
  14. May 11, 2009 at 11:19 AM
    #54
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    +1
    It's usually $0.10 more per gallon to go from 87 to 89, and then another $0.10 to from 89 to 93. Doesn't make much sense to me...
  15. May 11, 2009 at 11:23 AM
    #55
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Same, people always ask why I hate ethanol and its funny, i just hate it, can't really explain other than we are causing our fuel consumption to start starving people
  16. May 11, 2009 at 11:26 AM
    #56
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^I hate it because we get less MPG with it. But yeah, using food for fuel is just plain stupid. We'll starve but we'll sure be able to get around in our vehicles to the empty grocery stores.
  17. May 11, 2009 at 11:29 AM
    #57
    DanGer
    See I am too young to even have had the opportunity to test it :(. Had my tacoma for almost a year so It has never been in an area without ethanol
  18. May 11, 2009 at 11:46 AM
    #58
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Here is why, with a math example
    20 gal tank filled with $2.00, 87 gas = $40
    20 gal tank filled with $2.20, 91 gas = $44
    Mileage = 20mpg with 87
    Mileage = 22mpg with 91
    2mph extra with 91 = 40 extra miles
    40 extra miles is worth $4 of 87 gas
    So it is a wash. 87 costs the same as 91
  19. May 11, 2009 at 11:50 AM
    #59
    DanGer
    That is my exact findings (give or take on the mileage). I spend more on fillups, but get better mileage. In the end I get the same price per mile so I just go longer between fillups
  20. May 11, 2009 at 12:22 PM
    #60
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    I think the v6 boys and girls are more prone to varying mpg with different octane than those with the 4-banger.
    Run what the engine needs and designed to be run on. You can only take advantage of the higher octane with a motor designed for it.
