Gas / Oxygen Air Sensor Question.....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fatherof2, Oct 10, 2014.
  1. Oct 10, 2014 at 7:24 AM
    Fatherof2
    Fatherof2 [OP] Well-Known Member
    Massachusetts
    2004 DC TRD
    Hi Gang,
    I have a 2004 TRD DC V6, and the "Check Engine" light came on.
    The garage ran a scan, and told me that it was the gas/oxygen air sensor? I think I have that right. He said that it will hurt my gas mileage and will eventually hurt my cat converter.
    I would really like to do this fix myself to save money. Is that easy to do? How much for the part? Any recommendations on the best/cheapest place to buy it?
    Thanks so much guys!
  2. Oct 10, 2014 at 7:48 AM
    EdFlecko
    EdFlecko Well-Known Member
    Ed
    Sacramento, California
  3. Oct 10, 2014 at 8:48 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
  4. Oct 10, 2014 at 8:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  5. Oct 10, 2014 at 9:13 AM
    EdFlecko
    Ed
    Fatherof2 - It's not a hard job, but the instructor makes the point of not just relying on the running of a scan, i.e., he use a meter to test the sensor, etc., etc.
    Ed
  6. Oct 10, 2014 at 9:19 AM
    Indy
    Indy Master of all I survey.
    An error on a sensor just means the sensor isnt putting out the data the computer wants. It doesnt mean the sensor is the problem. It may be doing its job and telling you there is a problem upstream of it.
    Having said that every o2 code ive had has been a failing sensor.
  7. Oct 10, 2014 at 9:20 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    well in the video he is taking something off he already had loose (its a how to video after all so he cant have things not come off lol) it is easy IF you presoak it with wd40 or some other penetrating fluid first, those things get locked on with rust and whatever so they are so tight they will snap off if you don't add something to penetrate and lube the threads first to break the seal. its also good to run the engine for 30-45 seconds to just "warm up" the pipe but you don't want it hot. a cold pipe has a death grip on those threads so if its warm but not hot to the touch it makes life easier. as you unscrew it if you feel it tighten up then turn it back in and then start unscrewing again, sometimes if it starts binding on you you have to make 2 turns out (or stop when it gets tight) and then turn it back in a turn to clear the threads so it comes out without stripping them.
    add some electric grease to the wire connection, I didn't do this and got a few false codes after just from a dirty or not so good connection so I went back and added the grease and never got anymore codes. I think without the grease water gets in it and gives strange signals.
  8. Oct 10, 2014 at 9:27 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Great stuff everyone!
    I am going to Autozone today to confirm which sensor it is.
    I will hit it with WD40 first.
  9. Oct 10, 2014 at 12:48 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Just back from Autozone.
    Turns out that it is the Bank 1, Sensor 1......which I guess is on the passenger side.
    Is this one a bit more tricky to replace?
  10. Oct 10, 2014 at 1:23 PM
    EdFlecko
    Ed
  11. Oct 10, 2014 at 1:38 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
  12. Oct 10, 2014 at 1:39 PM
    Fatherof2
    Massachusetts
    2004 DC TRD
  13. Oct 10, 2014 at 2:48 PM
    EdFlecko
    Ed
  14. Oct 10, 2014 at 3:34 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    If that is the correct one you need (upstream or downstream), then yes. I just replaced mine not too long ago. Only pain was access for my large hands. Should be pretty easy
  15. Oct 11, 2014 at 5:53 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Confirmed with Rock Auto!
    Man, the garage wanted like 350 bucks to do the job.
    Autozone wanted 180 for the part.
    The good folks here directed me to Rock Auto where I bought the part for about 110 with shipping!
    Thanks everyone!!!!
    Part should be here soon. Meanwhile I am hitting the nuts with Liquid Wrench a couple times a day in preparation.
    Wish me luck!
    Thanks again all!!
  16. Oct 12, 2014 at 4:17 PM
    mikegli
    mikegli Well-Known Member
    Orlando
    04 Tacoma TRD
    I just did my upstream 02 a month or two ago. I had to replace the nuts that hold the sensor to the exhaust pipe. Aside from that, get some anti seize, maybe some line wrenches, and a little patience.
  17. Oct 12, 2014 at 10:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you know what the actual code is? The upstream oxygen sensor hearing element failure code is P0135 and is fairly common and an easy fix.
    http://www.youtube.com/watch?v=VW05zlOEvLw
  18. Oct 14, 2014 at 5:53 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Pretty sure the code on my truck was P0031 for bank 1 sensor 1.
  19. Oct 18, 2014 at 11:09 AM
    Fatherof2
    Massachusetts
    2004 DC TRD
    Hi Gang,
    I got the sensor replaced today!
    Thanks again to everyone who posted!
    One of the keys for me was to soak the bolts and threads of the bad sensor for several days before trying to remove it. I hit the think with liquid wrench 5 or 6 times over the course of several days. The came right off!
    It was actually a bit tougher trying to disconnect the plug than it was to get the bolts off. It was very beneficial for me to really examine the new plug so that I was clear on where the tabs were that needed to be depressed to free the connection.
    I have a 2004 TRD 4 Door with the 3.4, and the connection was easily accessible from under the truck. It was a quick and easy job that saved me 250 to 300 bucks!
    Here is a picture of the bad sensor. You can see is pretty rusty after 120,000 miles! The liquid wrench made that a non event.
    New sensor is in! (Not a great picture............sorry.)
    The new sensor clipped right in. Getting the old one disconnected was the hardest part. Once you know where to press on the old one, it came right apart. Not difficult if you know where to look.
    Hope this helps someone else out.
    Thanks again!
  20. Apr 17, 2015 at 9:09 AM
    NancyKB76
    NancyKB76 New Member
    Texas
    '04 Tacoma PreRunner SR5 DoubleCab
    Hello
    I replaced the O2 sensor on my 2004 Tacoma and have driven my truck for a while and the CEL is still on. Any ideas would greatly be appreciated.
    Thanks
