Gas Pedal Whistle Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by UOFan, Jun 21, 2012.
  1. Jun 21, 2012 at 8:12 AM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    I just bought a 2001 4x4 Tacoma with 72k Miles on it. I notice that when I slightly press the gas pedal, there is some kind of high-pitched whistle coming from the truck.
    It almost sounds like a dog whistle, and it is relatively soft. It only happens when I press the gas pedal slightly, and when I press harder (or softer) it goes away completely.
    Anyone have this issue in the past? Any info would be greatly appreciated.
  2. Jun 21, 2012 at 8:20 AM
    XwesleysnipesX
    XwesleysnipesX Well-Known Member
    Eric
    Batesville, Indiana
    1996 2.4L 2x4 (sold). 2002 2.7L sr5 4x4 (sold)
    What kind of air intake system do you have?
  3. Jun 21, 2012 at 8:22 AM
    white toy taco
    white toy taco 505 Member
    Gian
    Albuquerque, NM
    02 4X4 Taco SR5 TRD V6
    All-Pro tube bumper, 5100's at middle setting w/OME 881's, rebuilt leafs w/ 2 chevy leafs, 265/75/16 Km2's, CloudyFab sliders, 6000k HID headlights (35w), 16" LED light bar,100w KC Daylighters,
    WTF? ive never heard of that. i have no idea what it could be since the pedal is cable drven. the only thing is maybe there is a small hole in one of your air hoses and you can only hear it when the engine is at low rpms
  4. Jun 21, 2012 at 9:12 AM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    I assume it is the stock air intake, I have only had the truck for 3 days so I haven't gotten around to familiarizing myself with the internals yet (first time Taco owner)
    Also @White Boy Taco
    What is the best way to check for holes? I assume it will be pretty small so I was thinking I could just electrical tape everywhere, then remove it overtime to find the source area (if this is the problem).
  5. Jun 21, 2012 at 9:26 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Make sure you dont have a throttle body spacer installed. All they do is whistle.
  6. Jun 21, 2012 at 10:43 AM
    white toy taco
    Gian
    Albuquerque, NM
    i forgot about that. good point
    well glad to add you to the Taco family! before you do anything, tacomaman06 has a good point. check if you have a throttle body spacer, if you dont know how to spot one, take a pic of your engine and we should be able to tell
    although with a throttle spacer, i dont think if you can run stock intake without modification but im not too sure
  7. Jun 21, 2012 at 10:51 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    The intake is flexible enough that a TB spacer should fit in no problem.
    OP it'll probably be a big chunk of aluminum attached to the manifold of the throttle body. It'll also probably be like red or blue in color (the makers of these are firm believers in the color making it produce more power, and everyone knows bright colors are faster :p ). If you have one it's probably the cause of your whistling. It won't hurt anything to leave it there but if you can't stand the whistling take it off and use it as a paperweight or something.
  8. Jun 21, 2012 at 11:47 AM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    Thanks you guys, I'm going to go check under the hood now, i'll also take a picture and upload it when i'm done.
  9. Jun 21, 2012 at 12:00 PM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    Here are the photos, I didn't see anything unusual. I am relatively unfamiliar with the most of a car's engine though, planning to learn on this truck.
  10. Jun 21, 2012 at 12:01 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    I dont see a throtle body spacer. but damn that is one clean engine bay
  11. Jun 21, 2012 at 1:03 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Just think of it as turbo/supercharger whine! My old explorer did that alot dunno why and never looked into it. Maybe a vacuum hose leak might be the source, I'm not certain though.
  12. Jun 21, 2012 at 1:49 PM
    MowTaco
    Kansas
    Does it happen in any gear and in neutral? Like if you're coasting fairly fast and just barely hit the pedal does it make the noise? Does it make the noise if you're in neutral or park?
  13. Jun 21, 2012 at 1:57 PM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    I'll drive around the block and check if it does in neutral. I know it does in gears 1-5
  14. Jun 21, 2012 at 2:34 PM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    Just finished, it didn't really whistle in neutral, it might have but it was substantially harder to hear. I went from 1500-2500 RPM in N. Maybe something to do with transmission? It only happens when I press the gas pedal VERY slightly.
  15. Jun 21, 2012 at 2:37 PM
    white toy taco
    Gian
    Albuquerque, NM
    this is pretty weird. i guess the only thing to do is to inspect all of the intake hoses
  16. Jun 21, 2012 at 3:13 PM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    Where exactly are all of the intake hoses located?
  17. Jun 21, 2012 at 3:36 PM
    white toy taco
    Gian
    Albuquerque, NM
    im not sure for the 4cyl. just look at the air box and intake manifold and inspect any hoses that come out of them
  18. Jun 21, 2012 at 8:20 PM
    Ninja
    Ninja The Lone Wolf of TW!
    Charles
    Arizona
    '04 Prerunner SR5 Reg. Cab
    Is the sound coming from the front of the truck or the back?
  19. Jun 22, 2012 at 8:46 AM
    UOFan
    UOFan [OP] Member
    NC
    2013 Sport 4D
    5100 Lift + AAL
    It sounds like it is coming from near the front, but it is hard to tell due to the pitch and volume being so high and low, respectively.
  20. Jun 22, 2012 at 2:05 PM
    MowTaco
    Kansas
    Just read you have a 5 speed... You sure it's not just the slight gear whine associated with a manual trans? I've noticed my truck is much less "refined" than other manual cars I've driven. The stick moves around like crazy and vibrates enough to satisfy the loosest of women. The whines and clicks of it changing gears are also very well pronounced, and I love it :D makes me feel much more "in tune" with the truck.
